Is there a minimum possible wavelength?
In summary, according to QM and general relativity, there is no minimum possible wavelength for waves on a thin, inelastic string of length ~ 10^{-6}m fixed at both ends. While string theory attempts to address physics on this scale, it remains speculative and there are physical constraints on how small a wavelength can be observed. The Planck length, while not a limit, does provide an estimate of the limitations of our current understanding of the laws of physics.
MadMax
99
Is there a minimum possible wavelength? E.g. if we have a thin, inelastic string of length ~ 10^{-6}m, fixed at both ends, according to QM, is there minimum wavelength for an oscillatory mode on that string? (All waves on the string can be assumed to travel at the speed of light.)
I would think so, because length is quantized in QM right?
Well, shorter wavelength = higher frequency = higher energy, so you're talkin' some seriously, seriously high energy radiation there.
THERE IS NO MINIMUM WAVELENGTH.
WRONG, length is not quantized in QM.
As far as I know, Planck lenght: 1.6 × 10−35 m, should give a limit to it.
"Planck length" is just a unit, not a limit.
Ok, but then, I don't understand this:
http://en.wikipedia.org/wiki/Planck_length
This thought experiment draws on both general relativity and the Heisenberg uncertainty principle of quantum mechanics. Combined, these two theories imply that it is impossible to measure position to a precision less than the Planck length
If lengths shorter than Planck length do exist, how can we measure them?
Strings Theory
You ask an interesting question MadMax. As other members have pointed out, there is in fact a Planck Length. This number gives us an estimate of the limitations of the laws of physics that we can be sure of. It is within the realm of complete uncertainty to measure a physical characteristic having a length less than this value. String theorists attempt to address physics on such a scale, but for this reason, string theory remains speculative philosophy.
To answer your question more directly, wavelength is quantized by its boundary and symmetry conditions. So, if you have a string of a specific length, then there is a zero-energy mode of vibration.
Furthermore, there is no mathematical restriction on how small the value of a wavelength can be... but there are physical constraints. From observation, we know that fundamental particles exist. String theory attempts to characterize these particles as fundamental strings with different modes, boundary conditions and symmetry conditions... but again... string theory is still only metaphysics at this point in time.
FAQ: Is there a minimum possible wavelength?
What is the minimum possible wavelength?
The minimum possible wavelength is the shortest distance that a wave can travel. It is determined by the energy of the wave, with higher energy waves having shorter wavelengths.
How is the minimum possible wavelength calculated?
The minimum possible wavelength is calculated using the formula λ = h / p, where λ is the wavelength, h is Planck's constant, and p is the momentum of the particle carrying the wave.
Is there a limit to how short a wavelength can be?
Yes, there is a limit to how short a wavelength can be. According to the Heisenberg uncertainty principle, it is impossible to know both the position and momentum of a particle with absolute certainty. Therefore, there is a minimum uncertainty in the wavelength, known as the Planck length.
Can the minimum possible wavelength be observed?
The minimum possible wavelength can be observed in certain phenomena, such as gamma rays, which have very short wavelengths. However, it is impossible to observe wavelengths shorter than the Planck length due to the limitations of technology and the laws of quantum mechanics.
How does the minimum possible wavelength relate to the electromagnetic spectrum?
The electromagnetic spectrum is a range of all possible wavelengths of electromagnetic radiation, including radio waves, microwaves, infrared, visible light, ultraviolet, X-rays, and gamma rays. The minimum possible wavelength is at the high end of the spectrum, with the longest possible wavelength being at the low end.
