I Is there a name for this sort of differential equation?
The differential equation presented, f(z) + 2zf'(z) + f''(z) = 0, does not appear to be classified as a Hermite equation. The suggested general solution involves the probit function, expressed as f(z) = e^{-z^2} (c_1 + c_2 Φ(√3z)). It can be transformed into a Sturm-Liouville form, which is a recognized category of differential equations. This transformation confirms its classification within that framework. The discussion concludes with acknowledgment of the Sturm-Liouville connection.
Gear300
Is there a name to this sort of differential equation?
f(z) + 2zf'(z) + f''(z) = 0 ~.
I ran into it somewhere and it does not look to be Hermite. I think it has the general solution
f(z) = e^{-z^2} \big( c_1 + c_2 \Phi(\sqrt{3}z) \big)
\quad \textnormal{($\Phi(x)$ is probit function.)}
You might have to correct me on the solution, but is there a name to it?
Mathematics news on Phys.org
This can be transformed into
##\dfrac{d}{dz} \left ( e^{z^2} \dfrac{df}{dz} \right ) + e^{z^2} f(z) = 0##
This is a Sturm-Louville differential equation.
-Dan
Likes Euge, Office_Shredder, berkeman and 1 other person
Ah. Thanks.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
