Is there a principle of stationary action for QFT?
In summary, there is currently no equivalent principle of stationary action for QFT, although the Schwinger-Dyson equations can be seen as the "equivalent" of the Euler-Lagrange equations. However, the lack of an elegant framework for QFT is still a topic of interest and research. The path integral formalism is currently the most popular method for calculating in QFT, but it is not a direct analog to the dynamical law of classical mechanics. Attempts have been made to establish a more elegant framework, but so far, none have been successful.
jordi
197
Classical mechanics (and classical field theory) has the principle of stationary action (Hamilton's principle) as main principle. The Euler-Lagrange equations are derived from that principle, by using calculus of variations, on functionals (functions of functions).
Is there an equivalent principle of stationary action for QFT? I understand that the Schwinger-Dyson equations are the "equivalent" of the Euler-Lagrange equations, but instead of being differential equations in 1 (or 4) variables, the variable is a function itself (infinite dimensional).
I imagine that if the analogy works out, one should use functions of functionals (functions of functions of functions). Or maybe the "principle for QFT" does not look like a principle of stationary action at all.
So, is there some kind of "principle" that gives the Schwinger-Dyson equations in QFT, in the same way the principle of stationary action gives the Euler-Lagrange equations for classical field theory?
Thr fubdamental formulation of quantum mechanics involves quantum states as rays in Hilbert space, unitaty evolution via the Schroedinger equation, observables and the Born rule.
This can often be formulated using the sum over all paths formalism of the path integral. The "saddle point" approximation to the path integral recovers the classical least action principle.
Likes vanhees71 and jordi
Well, yes. What you say it is true for Quantum Mechanics. I was talking about QFT (of course, QFT is also Quantum Mechanics, but ...).
But my point is different: for sure there are several ways to quantize a theory: canonical quantization, path integral ...
But for example the path integral is very different from the dynamical law of classical mechanics: the path integral gives you the generating functional, and you build the correlation functions by functional differentiation of the generating functional. In perturbation theory, you just use the Feynman diagrams.
But maybe one would like to have a dynamical law, à la Hamilton principle, from which the Schwinger-Dyson equations could be derived. In the same way the Euler-Lagrange equations are derived from the Hamilton principle, using calculus of variations.
It is just more elegant to state the Hamilton principle as our "axiom" than the Euler-Lagrange equations (even though probably all conceivable calculations would be the same).
Analogously, it would be more elegant to have a Hamilton-like principle, from which the Schwinger-Dyson equations could be derived, rather than purely stating the Schwinger-Dyson equations as an axiom.
This quantum action principle by Schwinger seems quite mysterious (to me, an ignorant). Is there a "for dummies" paper or book?
It is far from intuitive and out of fashion, was never popular. It has been superseded by the path integral formalism, which turned out to be much more versatile.
Likes jordi
I understand that, thank you.
I would like that there could be a "principle" guiding to QFT. In the end, in classical physics this is a strong argument (Hamilton's principle leading to the Euler-Lagrange equations, and then to classical mechanics and classical field theory).
Instead, in QFT we "have the solution" (the partition function), but we do not have a principle, and even the equivalent equations to Euler-Lagrange, the Schwinger-Dyson equations, are not very emphasized.
Books usually start with canonical quantization, or with the path integral. For sure, this is for good reasons: path integral is the easiest way to calculate, especially with gauge theories.
But I am surprised about the lack of interest to put QFT into a more "elegant" framework. OK, maybe it cannot be done, or it is not wise to do so.
No one has found an elegant way to do this. One either has to live with the limitations in the state of the art, or improve it. But the latter is hard, since the easier possibilities have all been tried and failed to give an elegant framework.
Your answer makes sense.
FAQ: Is there a principle of stationary action for QFT?
What is the principle of stationary action for QFT?
The principle of stationary action for QFT (quantum field theory) is a fundamental concept in physics that states that the action (a mathematical quantity that describes the dynamics of a system) of a physical system must be stationary (unchanging) under small variations in the system's fields. This principle is derived from the more general principle of least action and is a key component in the formulation of quantum field theories.
How does the principle of stationary action apply to QFT?
In QFT, the principle of stationary action is used to derive the equations of motion for the fields in the system. By varying the action with respect to the fields, the equations of motion can be obtained, which describe how the fields evolve over time. This allows for the prediction of the behavior of the system and is a crucial tool in understanding the dynamics of quantum fields.
What is the significance of the principle of stationary action in QFT?
The principle of stationary action is significant in QFT because it provides a framework for understanding the behavior of quantum fields and their interactions. It allows for the derivation of the equations of motion and the calculation of physical quantities, such as particle interactions and scattering amplitudes. Additionally, it is a key principle in the development of quantum field theories, which are essential for describing the behavior of subatomic particles.
How is the principle of stationary action related to other principles in physics?
The principle of stationary action is related to other fundamental principles in physics, such as the principle of least action, which states that a physical system will follow the path that minimizes the action. It is also related to the principle of least time in optics, which states that light will follow the path that takes the least time to travel. The principle of stationary action is a more general principle that encompasses these other principles and is applicable to a wider range of physical systems, including those described by QFT.
Are there any limitations to the principle of stationary action in QFT?
While the principle of stationary action is a powerful tool in QFT, it does have some limitations. One limitation is that it only applies to systems that can be described by a Lagrangian (a mathematical function that describes the dynamics of a system). Additionally, it does not take into account the effects of quantum fluctuations, which can have a significant impact on the behavior of quantum fields. These limitations are still areas of active research in the field of QFT.
