Is there a procedure for designing some quantum circuits?
In summary, there is a well-established procedure for designing quantum circuits, which involves creating a circuit diagram, determining the necessary quantum gates and their order, and optimizing the circuit for efficiency and accuracy. This process also includes testing and debugging the circuit to ensure its proper functioning. The design of quantum circuits is a complex and crucial step in the development of quantum technologies and requires a deep understanding of quantum mechanics and computational principles. However, with the growing interest and advancements in quantum computing, there are various resources and tools available to assist in the design process. Overall, designing quantum circuits follows a systematic approach and is essential for the successful implementation of quantum algorithms and applications.
Haorong Wu
413
89
TL;DR Summary
Given a transformation matrix, is there a procedure for designing a circuit for the matrix?
In Nielsen's book, the chapter of quantum circuits does not describe explicitly any procedures to design a circuit.
For example, given the matrix of Fredkin gate, ##\begin{bmatrix} 1 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 \\ 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 & 1 \end{bmatrix}##, I think, the first step is to identify the transformation for every qubit. In this case, ##\left | x_1 , x_2 , x_3 \right> \rightarrow \left | x_1, \bar x_1 x_2 \oplus x_1 x_3 , \bar x _1 x_3 \oplus x_1 x_2 \right >##. Then how can I implement this transformation? Of course, according to the hint after the exercise, I know it can be designed by 3 controlled-swap gates.
However, in another exercise, the matrix of a partial cyclic permutation operation is ##\begin{bmatrix} 1 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 0 & 1 \\ 0 & 1 & 0 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 \end{bmatrix}##. Again, I calculated the transformation for every qubit which is ##\left | x_1 , x_2 , x_3 \right> \rightarrow \left | x_1 \oplus x_2 x_3 , x_2 \oplus x_3, \bar x _3 \oplus x_1 x_2 x_3 \oplus \bar x _1 \bar x _2 \bar x _3 \right >##. Then, without a hint, I can't figure out how to implement it, especially on the #### qubit.
So, is my procedure suitable? Or is there a better procedure I can follow? This kind of exercises give me a headache. I've tried them all day. Thanks for reading.
I couldn't find anything on a "boolean algebra" for quantum computing but did find this presentation:
https://people.maths.bris.ac.uk/~csxam/presentations/talk-bfa.pdf
and this short discussion on Quantum logic:
http://math-it.org/Quantum/survey/logic.html
The basis for quantum computation is not Boolean logic, but quantum logic. To date, there is still no appropriate quantum-logical calculus comparable to the classical calculus based on Boolean algebra. There are at least two essential differences between quantum and Boolean logic. One is that any quantum gate has to be reversible, i.e., input and output must always correspond uniquely to one another. In particular, the number of input and output qubits have to be equal. This is different than in the Boolean case, where most gates have two input bits and only one output bit. In fact, all basic binary operations of Boolean algebra (∧, ∨, ¬, XOR, NAND, NOR, ...) are 2-1 valued, which implies that they are not reversible: in fact, since 1 ∧ 0 = 0 ∧ 1 = 0 ∧ 0 = 0, you cannot deduce from the result “0” which values the input bits have had.3
Another difference between quantum and Boolean logic is that quantum gates can transform a qubit basis, say {|0>, |1>}, to another, for instance {|0> + |1>, |0> - |1>}, just as a vector basis can be changed by reflections or rotations. This property is impossible in Boolean logic, where any operation transforms to one of the two values 0 or 1. In other words, the basis is never changed in Boolean logic.
Years ago when I first learned digital electronics, I learned to convert truth tables to boolean expressions, reduce them using boolean algebra rules and then transformed the reduced expression into a simple circuit. I've not seen something similar in Quantum Computing perhaps because of the nature of the game.
One last reference :
http://oxfordquantum.org/
This problem in general is known as quantum gate/circuit synthesis, or quantum compiling. This paper from 2004 that I found has been cited almost three hundred times.
As for your questions, 1) Isn't the Fredkin gate already a controlled SWAP? What are the sets of gates allowed for your compiling? 2) Can you find a circuit for just the cyclic permutation? The quantum Fourier transform turns the permutation into a phase gate on each individual qubit.
Likes jedishrfu
Related to Is there a procedure for designing some quantum circuits?
1. What is a quantum circuit?
A quantum circuit is a model used to represent quantum algorithms and perform quantum computations. It is composed of quantum gates, which are analogous to classical logic gates, and qubits, the basic unit of quantum information.
2. How is a quantum circuit designed?
There is no one set procedure for designing a quantum circuit. It involves identifying the problem to be solved, selecting appropriate quantum gates and qubits, and arranging them in a sequence to achieve the desired outcome.
3. What is the difference between a classical and quantum circuit?
A classical circuit operates on classical bits, which can only have a value of 0 or 1. A quantum circuit operates on quantum bits (qubits), which can exist in multiple states simultaneously, allowing for more complex computations and potentially faster processing.
4. Are there tools available for designing quantum circuits?
Yes, there are various software tools and programming languages specifically designed for designing and simulating quantum circuits, such as Qiskit, Cirq, and Quil.
5. Can anyone design a quantum circuit?
While anyone can learn the principles of quantum computing and design a quantum circuit, it requires a deep understanding of quantum mechanics and complex mathematics. It also requires access to specialized hardware for testing and running the circuit.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Linear and Abstract Algebra
