Is there a proof for the Bessel function of order 1?
In summary, the Bessel function of order 1 is a special mathematical function used in physics and engineering, denoted as J1(x) and defined as the solution to Bessel's differential equation. It has various physical interpretations, can be calculated using different methods, and has several important properties including its oscillatory behavior and exponential decay. The Bessel function is also widely applied in heat conduction, wave propagation, and other areas of physics and mathematics.
alexmahone
304
Prove that $\displaystyle J_1(x)=\frac{1}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)d\theta$ by showing that the right-hand side satisfies Bessel's equation of order 1 and that the derivative has the value $J_1'(0)$ when $x=0$. Explain why this constitutes a proof.
Hi Alexmahone, :)
Let \(\displaystyle f(x)=\frac{1}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)\,d\theta\). By the Leibniz integral rule we get,
\[f'(x)=\frac{1}{\pi}\int_0^\pi\sin\theta\sin(\theta-x\sin\theta)\,d\theta\]
\[f''(x)=-\frac{1}{\pi}\int_0^\pi\sin^{2}\theta\cos(\theta-x\sin\theta)\,d\theta\]
Substituting these in the left hand side of the Bessel's equation of order one we get,
\begin{eqnarray}
x^2 \frac{d^2 f(x)}{dx^2} + x \frac{df(x)}{dx} + (x^2-1)f(x)&=&-\frac{x^2}{\pi}\int_0^\pi\sin^{2}\theta\cos(\theta-x\sin\theta)\,d\theta+\frac{x}{\pi}\int_0^\pi\sin \theta\sin(\theta-x\sin\theta)\,d\theta\\
&~&+\frac{(x^2-1)}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)\,d\theta\\
&=&\frac{x^2}{\pi}\int_0^\pi\cos^{2}\theta\cos( \theta-x\sin\theta)\,d\theta+\frac{x}{\pi}\int_0^\pi\sin \theta\sin(\theta-x\sin\theta)\,d\theta\\
&~&-\frac{1}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)\,d\theta\\
\end{eqnarray}
Using integration by parts on \(\displaystyle\int_0^\pi\sin \theta\sin(\theta-x\sin\theta)\,d\theta\) we get,
\begin{eqnarray}
x^2 \frac{d^2 f(x)}{dx^2} + x \frac{df(x)}{dx} + (x^2-1)f(x)&=&\frac{x}{\pi}\int_0^\pi\cos \theta\cos(\theta-x\sin\theta)\,d\theta-\frac{1}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)\,d\theta\\
&=&\frac{1}{\pi}\int_0^\pi(x\cos\theta-1)\cos(\theta-x\sin\theta)\,d\theta\\
&=&-\frac{1}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)\,d(\theta-x\sin\theta)\\
&=&-\left.\frac{1}{\pi}\sin(\theta-x\sin\theta)\right|_{\theta=0}^{\theta=\pi}\\
&=&0
\end{eqnarray}
\[\therefore x^2 \frac{d^2 f(x)}{dx^2} + x \frac{df(x)}{dx} + (x^2-1)f(x)=0\]
Also, \(\displaystyle f'(0)=\frac{1}{\pi}\int_0^\pi\sin^{2}\theta\,d \theta=\frac{1}{2}\)
If we consider the Taylor expansion of the Bessel function of the first kind, differentiation of term by term is possible since it is a power series. Therefore we get,
\[J'_{1}(0)=\frac{1}{2}\]
Hence,
\[J'_{1}(0)=f'(0)=\frac{1}{2}~~~~~~~~~~~(1)\]
The Bessel's equation should have two linearly independent solutions. If the order of the Bessel equation is an integer then the the two solutions are: Bessel function of the first kind and Bessel function of the second kind. (Read this.)
In our case the order is 1 and hence the function \(f(x)\) should be linearly dependent to either the Bessel function of the first kind\((J_{1})\) or the Bessel function of second kind\((Y_{1})\). But the Bessel function of second kind is not continuous at \(x=0\) whereas \(f(0)\) is finite. Therefore the only possibility is that \(f(x)\) should be linearly dependent to the Bessel function of the first kind. That is,
\[f(x)=\beta J_{1}(x)\mbox{ where }\beta\in\Re\]
Now it can be easily shown that, \(f(0)=J_{1}(0)=0\). Therefore \(\beta\) could not be found out by substituting \(x=0\). However if we differentiate the above equation and substitute zero,
\[f'(0)=\beta J'_{1}(0)\]
By (1),
\[\beta=1\]
\[\therefore J_{1}(x)=f(x)=\frac{1}{\pi}\int_0^\pi\cos(\theta-x\sin\theta)\,d\theta\]
Kind Regards,
Sudharaka.
FAQ: Is there a proof for the Bessel function of order 1?
What is the Bessel function of order 1?
The Bessel function of order 1, also known as the first kind of the Bessel function, is a special mathematical function that is used to solve a wide range of problems in physics and engineering. It is denoted as J1(x) and is defined as the solution to Bessel's differential equation.
What is the physical significance of the Bessel function of order 1?
The Bessel function of order 1 has several physical interpretations, including its use in describing the amplitude of oscillations of a damped harmonic oscillator and the radial component of the electric field of a charged particle moving with a constant velocity. It also has applications in diffusion problems, heat conduction, and electromagnetic wave propagation.
How is the Bessel function of order 1 calculated?
The Bessel function of order 1 can be calculated using various methods, including series expansions, recurrence relations, and numerical algorithms. It can also be expressed in terms of other special functions, such as the hypergeometric function and the modified Bessel function.
What are the main properties of the Bessel function of order 1?
The Bessel function of order 1 has several important properties, including its oscillatory behavior for large arguments, its exponential decay for small arguments, and its zeros, which are located at specific values of the argument. It also has symmetry properties with respect to the order and argument, and can be expressed in terms of other special functions.
What are the applications of the Bessel function of order 1?
The Bessel function of order 1 has numerous applications in physics, engineering, and mathematics. It is used to solve problems in heat conduction, wave propagation, diffraction, and vibration analysis. It also has applications in signal processing, image reconstruction, and quantum mechanics.
