Is there a proof od negative numbers?
The discussion addresses the proof of why multiplying two negative numbers results in a positive number. A mathematical proof is provided, demonstrating that the equation ab = (-a)(-b) holds true through algebraic manipulation. The explanation emphasizes that the identity element is 1, and that multiplying by -1 changes the sign of a number. The conclusion reinforces that the absolute value of the product of two negative numbers is positive, confirming the rule. Understanding this concept is essential for grasping the fundamentals of negative numbers in mathematics.
Geekchick
77
Hi everyone!
This may be a stupid question but is there a proof of negative numbers? Specifically why does this work -a(-b)=c I was trying to explain it to someone and drew a blank.
Thanks!
Mathematics news on Phys.org
Are you asking why two negatives multiplied produces a positive? If so, here's a proof I once read:
Let x = ab + (-a)(b) + (-a)(-b)
Then, x = ab + -a(b-b)
= ab -a(0)
= ab - 0
= ab
However, we also have x = b(a -a) + (-a)(-b)
= (-a)(-b)
Therefore, ab = (-a)(-b). QED.
Hope that's what you wanted.
Thanks i just couldn't logically reason it!
1 is the identity and -1 can only change the sign. Since (-1) ab = -ab. Thus the absolute value of (-1)(-1) = 1. So we have only the choices (-1)(-1) = 1 or
(-1)(-1) = -1.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
