Dreamlines
- 2
Cannot seem to find such a connection. The UHV vacuum sits around 1x10-8. The fitting needs to be rated for cryo temps.
Thanks
Thanks
A Quick connect to VCR fitting is a type of fitting used to connect two pieces of equipment, such as a vacuum chamber and a VCR, in a quick and secure manner. It is designed to be easy to use and can be connected and disconnected with minimal effort.
Yes, a Quick connect to VCR fitting can be rated for ultra-high vacuum (UHV) applications. However, it is important to check the specifications of the specific fitting to ensure it is suitable for your specific UHV requirements.
Yes, many Quick connect to VCR fittings are designed to withstand cryogenic temperatures. However, it is important to check the temperature rating of the fitting to ensure it can handle the specific cryogenic temperatures required for your application.
The main benefit of using a Quick connect to VCR fitting is its ease of use and quick connection and disconnection, which saves time and effort compared to traditional fittings. It also provides a secure and leak-free connection, which is crucial for UHV and cryogenic applications.
Yes, Quick connect to VCR fittings come in a variety of sizes and materials to fit different equipment and applications. Some common materials include stainless steel, brass, and PTFE, and sizes can range from 1/4 inch to 1 inch or more depending on the manufacturer.
