B Is there a relationship between the harmonic mean and the standard deviation?
The discussion explores the relationship between the harmonic mean (HM) and the arithmetic mean (AM) in a sequence of numbers, highlighting that while the AM remains constant, the HM decreases as the values become more extreme. It emphasizes that the HM is more sensitive to lower values, which skews its calculation downward. The conversation also delves into the potential connection between HM and standard deviation (σ), suggesting that increased fluctuations in values could lead to a lower HM. Participants seek a rigorous mathematical expression for HM in relation to σ, indicating that the expectation of the distribution plays a role in this relationship. The thread concludes with a clarification on the distinction between HM and the expectation in the context of deriving a formula.
Feynstein100
I was doing a thought experiment on the harmonic mean. Let's say we have a sequence of 4 numbers:
100, 110, 90, 100
The arithmetic mean (AM) of this sequence is 100 but the harmonic mean (HM) is 99.4975.
Let's imagine that the initial and final values remain constant but the middle ones get more and more extreme.
100, 120, 80, 100
The AM is still 100 but the HM is now 97.9592
100, 130, 70, 100
AM = 100, HM = 95.2880
and so on
I think I understand why this happens. The AM is symmetric, if you will. So an equal movement above the mean will cancel out an equal movement below it. However, the HM is more skewed toward the lowest value in the sequence. As such, it only takes one low value to bring the HM down. And with each step, we have a lower minimum and thus a lower HM. This is basically a crude verbal proof. Is there a more rigorous, mathematical one?
I'm also interested to know if there's a relationship between the HM and the fluctuation (I guess the arithmetic standard deviation is a good way to represent this). I mean, there has to be, as higher fluctuations mean higher likelihood of lower values and thus a lower HM, right?
Basically, HM = f(σ)?
Mathematics news on Phys.org
Imagine a variable x with a distribution N(μ,σ2), i.e. a Normal distribution with mean μ and variance σ2. Think of x as μ + δ where δ = N(0,σ2), and (for simplicity) σ << μ. Can you derive an (approximate) expression for HM, where HM = 1/E(1/x)?
Sounds interesting. But what exactly is E in this case? 😅
The expectation (mean of the distribution).
Ah okay but isn't that literally the definition of the harmonic mean? Not sure what we'd get by proving it. I mean, I'm trying to find a relationship between HM and σ, not HM and E.
Also, in the example, the E remained constant whereas the HM kept decreasing, exactly illustrating my point. Although, oh wait. That was the AM, not E(1/x). My bad 😅
I wasn't asking you to prove HM = 1/E(1/x), but to use that definition to derive an expression for HM in terms of μ and σ.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
