Is there a solution for the behavioural contradiction in RT?
  • I
  • Thread starter Foppe Hoekstra
  • Tags
    Contradiction
In summary: I originally said.In summary, the conversation discusses a paradox involving the behavior of a rotating train-wagon and a stationary train-wagon. The paradox arises due to the different states of motion of the two wagons, which lead to differences in the distances between the dots they print on the rail. This paradox has been analyzed before and is resolved by considering the loss of simultaneity in circular motion compared to straight line motion.
Foppe Hoekstra
41
TL;DR Summary
A moving wagon fitted with printers at each end that simultaneously print dots on the rail makes the consequences of Lorentz transformations tangible. A lot of such wagons, forming a full circular train and a symmetrical rotating system, makes it clear that, within the scope of Lorentz transformations, the behaviour of a moving inertial system is incompatible with that of an infinitely small part of a rotating system, even though there are no differences between these systems to account for it.
In short:
Consider a train-wagon with rest-length L, having a printer on the front and the rear that can put a dot on the rail. Both printers have synchronised clocks. The wagon, being the moving frame MF, has a speed v, and at t0 both printers simultaneously put a dot on the rail. Lsf is the distance between these dots for an observer at rest along the rail, being the stationary frame SF. In accordance with Lorentz, Lsf = γL.
Next, we put a lot of the former train-wagons together, to form a full circular train of n wagons that are coupled by the printers, being the rotating system RS. The front printer of each wagon is the rear printer of the next wagon and therefore we have n printers. (To please Ehrenfest, the wagons are elastic enough to compensate for length contraction due to their velocity.)
At t0 (in RS) every printer puts a dot on the rail. Given the unbroken rotational symmetry we must assume that, in SF,
- there will be n dots on the rail,
- each dot will have the same distance to the next dot,
- the rear dot of wagon 1 will coincide with the front dot of wagon n, regardless of which wagon is numbered as number 1.
Hence, the distance between each pair of sequential dots will be L.
Now, for a close look to one unit of this rotating system. If n is taken infinitely large, pushing the radius to the limit ∞, this RS-unit has virtually the same movement as our straightforward going single wagon. The only difference is that the RS-unit is, compared to the contracted single wagon, stretched by factor γ.
So, the contradiction at hand is that in SF the stretched wagon prints its dots at a distance L, while the contracted wagon prints its dots at the larger distance γL, even though they both print the dots simultaneously in their own frame. How can this be? Somewhere the behaviour of the rotating system, or at least a very small part of it, should smoothly meet that of Special Relativity Theory in straight forward motion.
If a sequence of wagons is moving in a circle, then they are all moving in different directions relative to each other. There is no uniform simultaneity between wagons.
This problem in various guises has been analysed on this forum before if you search for it.
Fundamentally the paradox is resolved by considering the loss of simultaneity for wagons moving in a circle, as opposed to all moving together in a straight line.
Whatever the notion of time on each separate wagon may be, fact is that Lsf for the dots of a RS-wagon will be L. And that contradicts with Lsf of the single wagon.
Could you be more specific on where this problem has been analysed before?
I'm on my phone. Try a search.
I did one a while back to analyze why for circular motion, as the limit of polygonal motion you get absolute time dilation in the limit but symmetric time dilation for each polygonal leg.
The wagons are different lengths. The one on the circular track is stretched by its couplings to the adjacent wagon. The inertial wagon is not.
You keep writing as if the stretching forces (which, in an inertial frame, are due to wagons which are in motion) are irrelevant. They are not. They make the situation of the wagon on the track physically different from that of an instantaneously comoving inertial wagon. You did not seem to me to grasp this in your earlier rotating planet example and you seem to be making the same error here.
Edit: Never mind - shouldn't post when I'm in the middle of something else. See my later response.
It remains true that the circulating and inertial wagons are in different states of motion, and this is critically important. Just not quite for the reasons I stated in this post.
Is the measured stretching of the trains physical or an unphysical measurement effect that arises from differential velocity? If I am at rest next to a train car and I accelerate to a constant speed close to the speed of light away from the train and observe the train through a telescope, won’t I measure it’s length contracted? Has anything at all about the train actually changed or am I witnessing an optical illusion which depends on my relative velocity compared to a light emitting object?
You should open a new thread for that.
Neither. The train doesn't change. And length contraction has nothing to do with light signals. Length can be measured without EM radiation. It's not an optical illusion.
The answer is that you need to look more closely at the definition of length measurement. A length measurement entails finding the simultaneous position of the two ends.
The flat spacetime of SR has no universal simultaneity. This leads to length contraction if you measure the length of an object that is moving in the frame of reference in which the measurement is made.
Simultaneously in what frame?
What simultaneity convention does the rotating system use?
There are common characteristics of these "paradoxes" in SR. The "paradox" will ignore some critical parts of SR, like relativity of simultaneity, length contraction in different directions of motion, etc. The setup is usually one where the correct SR calculations are complicated and intuitively difficult. Then, while the problem statement includes no proper (or any) calculations, it asks others to explain it all with valid intuition and calculations.
Likes mfb and PeroK
Summary: A moving wagon fitted with printers at each end that simultaneously print dots on the rail makes the consequences of Lorentz transformations tangible. A lot of such wagons, forming a full circular train and a symmetrical rotating system, makes it clear that, within the scope of Lorentz transformations, the behaviour of a moving inertial system is incompatible with that of an infinitely small part of a rotating system, even though there are no differences between these systems to account for it.
In short:
"Simultaneous" is tricky in special relativity because of the relativity of simultaneity. Different observers have different notions of simultaneity.
For this specific example, using the standard definitions of "simultaneous", based on Einstein's simultaneity convention, when one cares out the procedure of point-wise synchronizing clocks on the train, the very last clock on the tail of the train will not be synchronized with the clock on the head of the train when they are compared directly, even though pairwise every other set of clocks in the train is syncrhonized.
If one uses a different defintion of simultaneity than Einstein's pairwise procedure, the description of the problem might change. But it's unclear what defintion you might be using and it's too much work to present a number of possible alternatives.
It's probably easier to learn about the relativity of simultaneity in non-rotating systems. The general topic is called "The relativity of simultaneity" and/or "Einsteins Train".
Likes FactChecker
See the Ehrenfest paradox.
In general: You can prove mathematically that special relativity is consistent, if something seems to be not working then you must have made a mistake.
Likes FactChecker
https://en.wikipedia.org/wiki/Ehrenfest_paradox"...According to special relativity an object cannot be spun up from a non-rotating state while maintaining Born rigidity..."
"...For physically reasonable materials, during the spin-up phase a real disk expands radially due to centrifugal forces; relativistic corrections partially counteract (but do not cancel) this Newtonian effect..."
"...Any rigid object made from real materials that is rotating with a transverse velocity close to the speed of sound in the material must exceed the point of rupture due to centrifugal force, because centrifugal pressure can not exceed the shear modulus of material..."
First, it is incorrect to claim that "there are no differences between these systems to account for it". The angular velocity ##\omega## is physically measurable and accounts for the difference between the systems. See also below:
For any rotating ring ##\omega=v/R## where ##v## is the tangential velocity and ##R## is the radius. Since ##v<c## then we have $$\lim_{R \to \infty} \omega = 0$$. So the angular velocity becomes zero and all angular effects disappear. Thus the angular and linear motion do smoothly transform to each other in that limit.
If the length of the wagons is much less than the radius of the track then one can reasonably Einstein-synchronise the clocks at each end of a wagon. But if one synchronises each front-of-wagon clock to its back-of-wagon clock this way, the cumulative effect of the "leading clocks lag" rule leads to the final clock (the back clock of the wagon behind the wagon where we started) showing a different time from the front-of-wagon clock. This tells us that either (a) we break circular symmetry somewhere, or (b) we do not use Einstein synchronisation. Either way gets us out of any paradox.
Likes PeroK
Yes. People often don't appreciate the need for Einstein clock synchronization, or properly deal with the consequences if they decides not to use it. It is possible not to use Einstein clock synchronziation, but it's tricky and opens up a whole diffeent can of worms. Many laws of physics that one learns in high school or college have been formulated assuming a standard, conventional, clock synchronization scheme, so they need to be modified if one chooses to abandon the standard scheme.
Most commonly, people assume that simultaneity is not dependent on the observer, and possibly even go further and think that if Einstien clock synchronization is observer dependent, it must be wrong, because they "know in their hearts" that the "one true simultaneity" is universal.
Unfortunately, this belief that simultaneity is universal is inconsistent with special relativity. I've seen a lot of people blame the theory for faults that trace back to a conflict between their beliefs about simultaneity being universal and what the theory of relativity demand.
A good clue for whether someone is falling into this trap is to note that they specify "clocks are synchronized" without adding the necessary details about what frame they are synchronized in.
Likes Ibix and FactChecker
Simultaneously in the moving frame (MF).
RS: From the full story: "Every printer has a clock that is synchronized when the train is at rest and thereafter the train is accelerated to a constant velocity v. Thus all clocks are accelerated in the same way and so all clocks will develop the same deviation in relation to SF. So all clocks will still be synchronized in RS when the train is at speed."
For "proper calculations" and the notion of relativity of simultaneity see the full text.
See my reply to A.T.
And by the way, the mathematical 'proof' of SRT is a circulair reasoning.
There are no proofs of SR, only deductions from some or other postulates, and that is linear reasoning.
When the angular and linear motion smoothly transform to each other in the limit, should not the distances between the dots do as well?
We use the synchronisation as described (see also reply to A.T.) and we certainly do not break circular symmetry! How on Earth would 'breaking the circular symmetry' look like?
A 'time gap' perhaps? Wouldn't that mean that if you travel around the world's axis (which we do at a daily basis by just staying at home) you would not exist for this time-gap-moment?
The circular reasoning I am referring to is the one in which it is claimed that 'the observed speed of light is independent of the speed of the observer' follows from RT. Where at the same time it is the main initial hypothesis, so of course it does. Which brings us to another point: namely that a consistent theory does not necessarily need to be true.
So you have adopted a coordinate system in which the time coordinate is referenced against a stationary clock in the center of the circular train tracks. That's fine. (The GPS system runs that way). But since you have discarded Einstein clock synchronization, the coordinate speed of light is no longer isotropic in your coordinate system. It is no longer equal to c in every direction.
Likes FactChecker
Clearly you break circular symmetry if you Einstein synchronise your wagon clocks. From the track's rest frame, the front clock of any wagon lags behind the back clock if you Einstein synchronise them. So the front clock of the wagon infront is even further behind. What happens when you get all the way round your circle to the first wagon that you synchronised again? There's your break in symmetry.
Nothing is happening to time. It's just that you cannot set clocks consistently in the way you want. The break in clock synchronisation behaves like crossing from one time zone to the next - nothing interesting happens, except that your watch suddenly doesn't agree with the wall clocks.
The actual cause of the synchronisation issue is very different, of course, but it's just a problem with experimental design.
Likes FactChecker
...and, additionally, the wagon clocks are not synchronised to the clocks on the instantaneously co-moving inertial wagon if you use this method.
So the prints by the circular train are simultaneous in SF, but the prints by the single wagon are not simultaneous in SF.
The issue here is not angular vs. linear motion.
The issue is that the wagons of the circular train are forced to keep a constant length in SF, so their clocks stay synchronized in SF. Your single wagon is not forced to keep a constant length in SF, so its clocks would desynchronize during acceleration in SF. If you setup your single wagon just like your train wagons (including forced constant length during acceleration) it will print the same dot distances as the train.
Likes Ibix
I deliberatly do not use the Einstein clock synchronization, so I do not have to worry about non-isotropic speeds of light or the Sagnac effect.
That is just why I do not use Einstein synchronization. The synchronization used is apllicable to both systems (MF and RS).
Imagine the loose wagon side by side with one of the wagons form the RS. They both have clocks that are synchronised in the same way and both simultaneously print dots on the rail. The only difference between them is that the RS-wagon is stretched by γ. Nevertheless it is the shorter wagon that puts its dots at the larger distance!
So if I stretch the single wagon by γ, just because of that the dots will suddenly be put closer to oneanother. I can't believe that.
Then what do you use for the single wagon?
That difference changes your synchronization, because the stretching happens during the acceleration, which is part of your synchronization procedure: "Every printer has a clock that is synchronized when the train is at rest and thereafter the train is accelerated to a constant velocity v."
If you apply the same synchronization procedure to the single wagon, it will print the same dot distances as the train wagons:
1) Synchronize the single wagon's clocks at rest in SF
2) Accelerate the single wagon, while forcing it to keep a constant length in SF
  • #31
I don't believe this is correct, assuming you mean "further apart as measured by the track rest frame". It would be correct if you were Einstein synchronising your clocks, but you aren't.
With Einstein-synchronised clocks, the "simultaneous print" of the wagons is non-simultaneous in the track rest frame. Thus the length contracted wagon produces a longer spacing because its back printer prints before its front printer (as described in the track frame).
But you aren't using Einstein synchronisation - all your clocks are synchronised in the track rest frame, even when they are in motion (I assume the clocks in the inertial wagon are not Einstein synchronised either). Thus the length-contracted wagon will print a short spacing.
  • #32
As soon as the clocks are accelerated they will no longer be synchronized along that direction (your choice of direction spoils any symmetry). I believe they will, however, return to synchronization if the train is brought to rest.
  • #33
Yup. A simple argument from symmetry guarantees this. No clock is treated any differently than any other, so they must all share the same reading when re-united.
  • #34
You're referring to Newtonian mechanics, of course?
<h2>1. What is the behavioural contradiction in RT?</h2><p>The behavioural contradiction in RT refers to the inconsistency between the predicted and actual behaviors of individuals in response to a certain stimulus or situation. It is often observed in decision-making tasks where individuals may behave differently than what is expected based on their preferences or beliefs.</p><h2>2. What causes the behavioural contradiction in RT?</h2><p>The behavioural contradiction in RT can be caused by various factors, including individual differences in decision-making processes, cognitive biases, and external influences such as social pressure or environmental cues. It can also be a result of conflicting goals or values within an individual.</p><h2>3. Is there a single solution for the behavioural contradiction in RT?</h2><p>No, there is no single solution for the behavioural contradiction in RT. It is a complex phenomenon that can be influenced by multiple factors, and therefore, there is no one-size-fits-all solution. Different approaches and strategies may be needed to address the contradiction in different contexts or for different individuals.</p><h2>4. Can the behavioural contradiction in RT be completely eliminated?</h2><p>It is unlikely that the behavioural contradiction in RT can be completely eliminated as it is a natural part of human decision-making. However, it can be reduced or managed through various interventions such as training programs, decision-making aids, or changes in the decision-making environment.</p><h2>5. How can the behavioural contradiction in RT be studied and understood?</h2><p>The behavioural contradiction in RT can be studied and understood through various research methods, including experimental studies, surveys, and computational modeling. By examining the underlying mechanisms and factors that contribute to the contradiction, researchers can gain a deeper understanding of this phenomenon and develop effective strategies for addressing it.</p>
Related to Is there a solution for the behavioural contradiction in RT?
  • General Math
17K
  • Math Proof Training and Practice
11K
  • Other Physics Topics
  • Mechanics
27K
