A Is there a stagnation point in turbulent flows not involving solids?
When two free jets collide at an angle, a stagnation point typically forms in the impingement zone, around which streamlines are deflected. Recent analyses indicate that the collision may not be completely elastic, suggesting energy loss and potential turbulence in this zone. The presence of turbulence raises questions about the existence of a stagnation point, as it may be dynamically moving due to the turbulent flow. However, it is argued that a stagnation point can still exist as a fixed point where fluid velocity is zero, even in turbulent conditions. The discussion emphasizes the complexity of fluid dynamics in collisions and the potential for multiple fixed points in turbulent flows.
rdemyan
TL;DR Summary
Reference: https://www.physicsforums.com/forums/classical-physics.61/post-thread
When two free jets collide at some impingement angle (not necessarily a head on collision), the usual assumption is that in the impingement zone there is a stagnation point around which stream lines are deflected. From this stagnation point, a thin liquid sheet is created, which eventually breaks down into droplets at some distance downstream. Originally, all analyses assumed that there was no loss of energy in the impingement zone. However, more recent results seem to suggest that the collision is not 100% elastic. My question is: if there is in fact turbulence created in the impingement zone of colliding free jets (as a result of an energy release), can there be a stagnation point? Is a stagnation point possible in a turbulent impingement zone especially when only two liquids are involved and there is no solid object.
Welcome to PF.
If a steady flow is separated, by any collision, into one or more different paths, there must be a stagnation point. That stagnation point may be moving dynamically as a result of the turbulence.
Where there is counterflow, or an eddy, there must also be a fixed point.
I don't understand your comment regarding a fixed point. I assume you are stating that the fixed point is the stagnation point.
I am saying the inverse, that the stagnation point is a fixed point. The fluid there has zero velocity.
There may be other fixed points in a turbulent flow. If the flow divides into two paths at one of those points, then it is also a stagnation point.
https://en.wikipedia.org/wiki/Brouwer_fixed-point_theorem
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
