I Is There A Study Showing The Observer Effect Ignoring Conscious Intent?
Adon
TL;DR Summary
Is there a study which shows that consciousness does not play a role in the Observer effect?
It's obvious that the Observer Effect can take place without conscious observation, for example with a photon and electron out in the wild, but I'm trying to find a single study which disproves the role of conscious measurement within the observer effect.
An experiment which I think would answer my question is this: the Two Slit Experiment but only one slit is observed while the other is not. If an electron passes through the slit which is not observed is detected as being a wave function but without the double slit interference pattern (since the possibility of the electron having come through the observed slit was eliminated when it was not detected), this would prove that the intent of detection does not play a role in collapsing the wave function, but material observation confirms where the electron is not, thus tightening the wave function. If the electron comes through the unobserved slit as a particle, then the intent of observation must play a role in the observer effect, since the particle would not have reacted with anything but the wave function would have collapsed simply because it "knew" it was being monitored indirectly.
There is no "Observer Effect". It's an urban legend perpetuated by non-technical and oversimplified descriptions of the theory, and you likely have been misled by these.
The double-slit experiment is usually misrepresented in these descriptions. In fact there is no "detected as a particle" versus "detected as a wave function" going on, there is no "wave-particle duality".
The particle-like behavior is that detections happen when a dot appears at a single point on the screen so we say that a particle landed there; and this happens whether there is one slit or two, whether there is a conscious observer or not, whether there are detectors at the slit or not.
When we send many particles through one at a time the dots build up a pattern, more dots in some areas and fewer in others. The wave function determines, by its interactions with whatever slits and detectors are present, what that pattern will look like, that is, what areas on the screen have a high probability of detecting a particle and which have a low probability.
There is no substitute for a real textbook, but if you have any interest in understanding what quantum mechanics really is, you might give Giancarlo Ghirardi's book "Sneaking a look at God's cards" a try.
Likes dextercioby, mattt, Vanadium 50 and 3 others
Adon said:
TL;DR Summary: Is there a study which shows that consciousness does not play a role in the Observer effect?
I think it is important to note that there is another effect that is often called "observer effect" and it is also very well known in quantum physics. It is related to the Heisenberg microscope and it is also misleading, but it also has nothing to do with consciousness.
Likes Lord Jestocost
Without disagreeing with anything said by Nugatory or pines-demon: Yes, there is proof that a conscious observer of which path in the Double Slit Experiment is not needed to "collapse" the pattern from one showing interference (wave-like) to one without interference (particle like).
Young's double-slit experiment with single photons and quantum eraser
In this experiment, polarizers are placed over each of the slits. At no time after is polarization observed or measured in any way. When the polarizers are oriented parallel, there IS interference. When the polarizers are perpendicular, there is NO interference (Fig. 9 in the reference).
Note that at NO time is the which slit information known or knowable (in this setup), regardless of orientation. It is possible to design the setup to gain which slit information and inform a conscious observer. But obviously the conscious observer is not necessary. QED.
Likes haushofer, pines-demon and PeterDonis
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
