Is there a such thing as being outside of our sun's gravitat
  • B
  • Thread starter IgnorantofPhysics
  • Tags
    Outside
In summary: For our sun, the escape velocity is about 11.2 km/s. It is possible to travel faster, but at a cost: the object would be pulled away from the sun's influence and into space beyond it. In summary,There is no such thing as being outside of our sun's gravitational influence. Gravity's range is infinite. No matter how far away from the Sun you were, you would never reach zero influence from it.If you wanted to think of it in terms of Force then you could, perhaps, appreciate that the Force that's needed to move away from a distant
IgnorantofPhysics
Is there a such thing as being outside of our sun's gravitational influence? Please forgive my ignorance. I recall this formula
inverse-square.jpe
But, what ought I plug into it, along with the sun's mass, such that I could say "it's far enough out there that there is not even a tug resultant from F"?
Any thoughts are appreciated.
Nope. Gravity's range is infinite. No matter how far away from the Sun you were, you would never reach zero influence from it.
inverse-square.jpe
The Force is always with you, however far away you go but it is possible to 'escape' by having enough Kinetic Energy to beat the Gravitational Potential. This link on wiki explains it. It's Energy and not Force that counts in these situations.
If you wanted to think of it in terms of Force then you could, perhaps, appreciate that the Force that's needed to move away from a distant orbit around a star becomes less and less with increasing distance. A relatively small kick would take Pluto out of its present orbit but a bigger kick would be needed to shift it if it were at the same distance as the Earth.
Thank you Drakkith and SophieCentaur.
This is brilliant. I wish there were a universe simulator, that would let me change values so that I could learn what values are sufficient to make "kicks." This quote has helped me understand that maybe it is not the number F calculated in isolation among say our sun and the Europa moon of Jupiter, that is needed. Instead, it is the fact that FSun calculated among our sun and Europa is not a strong-enough F to have more influence than a FJupiter calculated among Europa and Jupiter; it's not a big enough force to do a "kick." If it is correct, then I just have to figure out what enough force is to say knock Europa out of its orbit.
Just look up escape velocity of the solar system and of the various planets.
It isn't the Force that counts. You would appreciate that a large force, applied over a very short distance, could make very little difference to Europa's position. A Force, applied over a distance represents the Work done - or Energy input and that's the important thing. (Work is equal to Force times the distance it acts over) You could look at the situation in terms of the amount of fuel needed (per kg of object, perhaps). The amount of fuel would relate to the Kinetic Energy added to the object. So a teaspoon of fuel out in Pluto's orbit would do the job of several kg of fuel at Earth's distance. The term 'escape velocity' (as Dave has pointed out) is the commonly used description of the KE per kg of a spacecraft . It's an easy to remember figure that tells you most of what you want to know. Whatever you do, you need to progress beyond using the Force as a meaningful measure of what's needed in space travel. Use Energy.
Deep spacecraft are being developed that use Ion Drives. These produce tiny forces but they are running all the time and can, eventually, accelerate a craft to very high speeds. They will do the job of a conventional rocket without needing to carry cast amounts of propellant (the stuff that's fired out the back of a rocket to make it go forward)
I have looked up escape velocity as DaveC426913 and SophieCentaur have suggested. Here is what I've learned in my own words:
An Escape Velocity is usually given assuming an object is on the surface of a specified mass. It is a speed, irrespective of direction, where if the object achieves that speed it would not change direction and fall back to the surface, nor perpetually fall into an orbit of the larger mass. I learned that at farther distances than the surface the Escape Velocity is a smaller value.
I also want to thank SophieCentaur's direction in helping me know that force is the improper focus; the focus should be on kgs of fuel needed to do work.
I am learning a lot today : ) Thank you everyone
Not so much "should" but fuel quantity gives a good idea of the Energy needed. The Energy word is more of a 'should'. It's just a bit more abstract.
Your point about Escape velocity is well made as that's the usual situation that it's used for. But you can also take it from a 'stationary' point elsewhere in space. (In which case, it will be a lot lot lower)
I just re-read this. The object can change direction, because the gravitational force will still be operating and, if the initial direction is not 'radial' it will have to be diverted. But not enough to pull it back. It will take an orbital path that is a hyperbola, which will never return. If the energy supplied is insufficient, the orbit will be an ellipse, which will keep the object going round the star (planet or whatever). Many comets have a hyperbolic orbit and only pass by once because their speed when at the closest approach is greater than escape velocity. This link may be of interest as it discusses the energy conditions for different orbit shapes. In a hyperbolic orbit, there is energy to spare.
FAQ: Is there a such thing as being outside of our sun's gravitat
Is it possible for an object to escape the gravitational pull of our sun?
Yes, it is possible for an object to escape the gravitational pull of our sun. This can happen if the object has enough velocity to overcome the sun's gravitational force.
How far does the gravitational influence of our sun extend?
The gravitational influence of our sun extends to the edge of our solar system, which is about 100 astronomical units (AU) away. This means that the sun's gravity can affect objects up to 100 times the distance between the Earth and the sun.
Can an object be outside of our sun's gravitational pull and still be in our solar system?
Yes, an object can be outside of our sun's gravitational pull and still be in our solar system. This can happen if the object is in orbit around another planet or if it is located beyond the sun's gravitational influence but still within the boundaries of our solar system.
What are the factors that determine an object's ability to escape the sun's gravitational pull?
The factors that determine an object's ability to escape the sun's gravitational pull include the object's mass, velocity, and distance from the sun. The greater the mass and velocity of the object, and the farther it is from the sun, the easier it will be for the object to escape the sun's gravitational pull.
Can an object ever completely escape the sun's gravitational pull?
No, an object can never completely escape the sun's gravitational pull. This is because gravity is an infinite force and will always have some influence on objects within our solar system. However, an object can reach a point where the sun's gravity is negligible and it is essentially free from its pull.
