Is there a typo in x_1 for the particular solution in this answer?
In summary, in question #1(b)'s answer, the value of x_1 should be 4 instead of -4 due to a typo. This can be verified through the PDF of the problem and the reduced row echelon form of the matrix obtained from the given equations.
s3a
818
In question #1(b)'s answer, should x_1 = 4 (instead of -4)?
PDF of problem #1(b):
https://www.dawsoncollege.qc.ca/pub...ms/201-nyc-05-computer_science-winter2011.pdf
Reduced row echelon form of the matrix I obtained from the given equations (in problem #1):
http://www.wolframalpha.com/input/?...ix+{{1,2,-2,3,2},{2,5,-3,4,5},{5,9,-8,11,12}}
If t = 0, then it should be the case that x_3 = 1 + 2*0 = 0, x_2 = 0 and that x_1 = 4 + 0 = 4 ≠ -4.
Am I right and the answer is wrong?
http://www.wolframalpha.com/input/?i=reduced+row+echelon+form+of+matrix+{{1,2,-2,3,2},{2,5,-3,4,5},{5,9,-8,11,12}}
Yes.
That is surely a typo.
If t=0, then x1 = 4 .
Likes s3a
Great, so it's not just me. Thanks. :)
FAQ: Is there a typo in x_1 for the particular solution in this answer?
What is a typo in a particular solution?
A typo in a particular solution refers to a mistake or error in the notation or expression used to represent a solution to a problem in science or mathematics. It can also refer to a mistake in the numerical values used in the solution.
How can I identify a typo in a particular solution?
To identify a typo in a particular solution, you can carefully check the notation and numerical values used in the solution. Look for any inconsistencies, incorrect symbols, or incorrect calculations. You can also compare the solution to known correct solutions or consult with other experts in the field.
Can a typo in a particular solution affect the accuracy of the solution?
Yes, a typo in a particular solution can greatly affect the accuracy of the solution. Even a small mistake in notation or numerical values can lead to incorrect results. It is important to carefully check for typos to ensure the accuracy of the solution.
What should I do if I suspect a typo in a particular solution?
If you suspect a typo in a particular solution, it is best to double-check your work and consult with other experts in the field. If the typo is confirmed, it should be corrected and the solution should be rechecked for accuracy.
How can I avoid making typos in particular solutions?
To avoid making typos in particular solutions, it is important to carefully check your work and proofread for any errors. It is also helpful to use clear and consistent notation and to double-check any numerical calculations. Collaborating with other experts and seeking feedback can also help in identifying and avoiding typos.
