Is there a way to break down the Culomb?
  • Thread starter swraman
  • Tags
    Break
In summary, the conversation discusses the breakdown of units in mechanics into length, mass, and time, and the possibility of breaking down the Coulomb unit into these three base quantities. It is determined that the Coulomb cannot be resolved into these three units and is instead defined as its own SI base unit. However, it is acknowledged that in other unit systems, units of charge can be defined in terms of length, mass, and time.
swraman
167
The thread on mass and force made me think...
Most units in mechanics can be broken down into a combination of length, mass, and time.
eg. power = mass * distance * time^-2 * distance * time^-1 (force*velocity)
Is there any way to break the culomb down into mass, length, and time?
Yes from the definition of the Ampere
"One ampere is defined to be the constant current which will produce an attractive force of 2×10^–7 Newton per metre of length between two straight, parallel conductors of infinite length and negligible circular cross section placed one metre apart in a vacuum"
And a coulomb is 1 Amp for 1 second.
However, the ampere is its own SI base unit, independent of the kilogram, metre, and second. In the SI system, the coulomb cannot be written in terms of these three base units.
However, in other unit systems, such as cgs (of which there is more than one type), units of charge are defined in terms of the other base units (centimetre, gram, second), but that is only due to the way they are defined, rather than anything physical.
The Coulomb cannot be resolved into mass, length, and/or time quantities. Electrical phenomena require the addition of a 4th base quantity to define them. The base electrical unit is the Coulomb, and all other electric/magnetic quantities are defined from the coulomb.
But, it is difficult to establish a measurement reference based on the Coulomb at this present time. If we define the amp as the current which results in a specific force between 2 conductors, it is precise and repeatable. So we define the amp per the above post, and the Coulomb is 1 amp * 1 sec. The Coulomb is actually more basic than the Amp, but it is easier to establish the Amp as the reference. I hope this helps. BR.
Claude
thanks
A coulomb is then equal to exactly 6.241 509 629 152 65×1018 elementary charges. Combined with the present definition of the ampere, this proposed definition would make the kilogram a derived unit.
http://en.wikipedia.org/wiki/Coulomb
FAQ: Is there a way to break down the Culomb?
Is it possible to break down the Culomb into smaller components?
No, the Culomb is a unit of electrical charge and cannot be physically broken down into smaller components.
Can the Culomb be converted into other units of charge?
Yes, the Culomb can be converted into other units of charge such as the Ampere-hour or the Faraday.
What is the relationship between the Culomb and other units of charge?
The Culomb is the SI unit for electrical charge and is equivalent to 1 Ampere-second or approximately 6.241 × 10^18 elementary charges.
How is the Culomb measured?
The Culomb is typically measured using an instrument called an electrometer, which detects and measures the flow of electrical charge.
Is there a way to manipulate or control the Culomb?
Yes, the Culomb can be manipulated and controlled through various methods such as using electrical circuits, devices, and techniques like induction and capacitive coupling.
