I Is there a way to calculate how rocket exhaust gas spreads out in empty space after leaving the rocket?
  • I
  • Thread starter Thread starter Albertgauss
    Exhaust Rocket
Calculating how rocket exhaust gas spreads in empty space after ejection is complex due to the low temperature and pressure of outer space. The discussion highlights the lack of resources specifically addressing the expansion of gas particles outside the rocket, contrasting it with jet exhaust behavior in the atmosphere. A reference to the book "Liquid Propellant Rockets" (1960) is made, which contains a chapter on expansion processes relevant to this topic. The need for accessible and affordable resources on this subject is emphasized, as many available books are costly. Overall, understanding the dynamics of rocket exhaust in space requires further exploration of specialized literature.
Albertgauss
TL;DR Summary
Any way to calculate how rocket exhaust gas spreads out in empty space after leaving the rocketexhaust pipe?
I haven't found anything obvious about how rocket thrust gas particles would expand once they leave the thruster of the ship from which it is ejected. Inside the rocket would be the exploding gas, but outside the rocket the temperature would be ~ 3 Kelvin and zero pressure since outer space would be empty. I thought maybe there would be something similar to a jet exhaust particles expanding in upper atmosphere upon egress from the vehicle but I couldn't find anything there either. There seemed to be a lot of how heat thermodynamically expands once leaving a jet engine but nothing about how the actual gas atoms themselves spread out.
Just looking for something very basic here. Rocket fuel type? Whatever is available that people have used for this type of calculation as I don't know where to start on that, either.
There is a chapter on Expansion Processes in the book Liquid Propellant Rockets (1960).
Who is the author(s) and maybe a jpeg image? There are, surprisingly, a whole bunch of books by that name. Plus, some of the books look expensive that have/contain that name, so if a reprint is available, that would be better.
https://press.princeton.edu/books/paperback/9780691626000/liquid-propellant-rockets
https://www.abebooks.com/servlet/SearchResults?sts=t&cm_sp=SearchF-_-home-_-Results&ref_=search_f_hp&tn=Liquid propellant rockets&an=Altman
In case your library has it, it should also be in the old series High Speed Aerodynamics and Jet Propulsion, but I do not know the volume.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
