Is there a way to compute the given area exactly?
  • MHB
  • Thread starter MarkFL
  • Tags
    Area
In summary, the author found a simple method for approximating the root of the equation $x= \cos x$. The f(x) is illustrated here and the procedure to follow is illustrated in a website.
MarkFL
MHB
13,288
Recently on Y!Answers the following question was posed:
Compute the area of the region bounded by:
$\displaystyle y=\cos(x)$
$\displaystyle y = x$
$\displaystyle x = 0$
I puzzled for a bit, did some calculations, but could not get away from using a numeric root-finding method for:
$\displaystyle f(x)=\cos(x)-x=0$
to determine the upper limit of integration.
I was curious if someone here might have an insight I missed. By the way, both people that responded also approximated the root.
On a side note, I recall seeing once that a simple method for approximating this root is as follows:
Make sure your calculator is in radian mode.
Enter any number on your calculator.
Take the cosine of this result.
Keep successively taking the cosine of the results, and your calculator will converge (slowly) to the desired root.
I can see why this works. If r is the root, then we have both:
$\displaystyle r=\cos(r)$
$\displaystyle r=\cos^{-1}(r)$
And from this we have:
$\displaystyle r=\cos(\cos(\cos\cdots\cos(r)))$
Finding the [real] root of the equation $\displaystyle x= \cos x$ is equivalent to find the limit of the solution of the difference equation...
$\displaystyle a_{n+1}= \cos a_{n}$ (1)
... starting from some initial value $a_{0}$. The (1) can be written as...
$\displaystyle \Delta_{n}= a_{n+1}-a_{n} = \cos a_{n} - a_{n} = f(a_{n})$ (2)
... and the procedure to follow is illustrated in...
http://www.mathhelpboards.com/f15/difference-equation-tutorial-draft-part-i-426/#post2492
The f(x) is illustrated here... https://www.physicsforums.com/attachments/516._xfImport
There is only 'attractive fixed point' in $x_{0} \sim .739085...$ and in that point is $f^{\ '} (x_{0}) \sim -1.67361...$ so that we are in the conditions of the Threorem 4.2 and the convergence is 'oscillating'...
http://www.sv-luka.org/ikone/ikone180a.jpg
Marry Christmas from Serbia
$\chi$ $\sigma$
FAQ: Is there a way to compute the given area exactly?
What is the formula for computing the area of a shape?
The formula for computing the area of a shape depends on the type of shape. For example, the formula for a rectangle is length x width, while the formula for a circle is π x radius^2. It is important to identify the type of shape and use the corresponding formula to calculate the area.
Can the area of a shape be calculated exactly?
Yes, the area of a shape can be calculated exactly as long as the dimensions and formula are known. However, it may involve complex mathematical calculations or the use of advanced tools such as integrals or calculus.
Is there a way to compute the area of an irregular shape?
Yes, there are methods for computing the area of an irregular shape. One approach is to divide the shape into smaller, regular shapes such as triangles or rectangles and then use the appropriate formula to calculate the area of each smaller shape. The areas can then be added together to get the total area of the irregular shape.
Can technology be used to compute the area of a shape?
Yes, there are various software and applications available that can help in computing the area of a shape. These tools use mathematical algorithms and formulas to accurately calculate the area of different shapes. However, it is important to verify the accuracy of the results.
How can knowing the area of a shape be helpful?
Knowing the area of a shape can be helpful in various fields such as architecture, engineering, and construction. It is also useful in everyday situations such as calculating the amount of paint needed to cover a wall or determining the amount of material needed to cover a floor.
