Is there a way to run TI-84 plus apps on the C-Silver Edition
  • Calculators
  • Thread starter jakebvt
  • Tags
    Apps Ti-84
In summary, it is possible to run TI-84 Plus apps on the C-Silver Edition calculator, but it may require technical knowledge and is not officially supported by the manufacturer. To transfer apps, a computer and special software called TI Connect are needed, along with a USB or TI Connectivity Cable. Not all apps will be compatible and it is recommended to check before transferring. It is generally legal to run apps for personal use, but may be a copyright violation. Running apps on the C-Silver Edition may void the warranty, so it is best to check with the manufacturer beforehand.
jakebvt
Is it possible to run TI-84 plus apps on the TI-84 plus C silver edition? If so, how do you do it? I'm not trying to run games or anything, just regular old apps.
When I try to send the files to my device I get an error message.
Computer science news on Phys.org
What is the error message?
Related to Is there a way to run TI-84 plus apps on the C-Silver Edition
1. Can I run TI-84 Plus apps on the C-Silver Edition?
Yes, it is possible to run TI-84 Plus apps on the C-Silver Edition calculator. However, it requires a bit of technical know-how and may not be officially supported by the manufacturer.
2. How do I transfer TI-84 Plus apps to the C-Silver Edition?
To transfer TI-84 Plus apps to the C-Silver Edition, you will need to use a computer and a special software called TI Connect. You will also need a USB cable or a TI Connectivity Cable to connect your calculator to your computer. Detailed instructions can be found online.
3. Can I run all TI-84 Plus apps on the C-Silver Edition?
No, not all TI-84 Plus apps will be compatible with the C-Silver Edition. Some apps may require specific hardware or software features that are not available on the C-Silver Edition. It is recommended to check the app's compatibility before attempting to transfer it.
4. Is it legal to run TI-84 Plus apps on the C-Silver Edition?
This is a tricky question as it depends on the specific app and your intended use. In general, it is not illegal to transfer and run TI-84 Plus apps on the C-Silver Edition for personal use. However, it may be a violation of copyright if the app is protected by intellectual property laws.
5. Will running TI-84 Plus apps on the C-Silver Edition void my warranty?
Most likely, yes. Altering the calculator's operating system or using unofficial apps can void the warranty. It is recommended to check with the manufacturer before attempting to run TI-84 Plus apps on the C-Silver Edition.
  • Computing and Technology
27K
21K
61K
22K
