Is there an experimental proof that an Earth/Moon barycenter exists?
In summary: The gist is the same, but it sounds less like the OP disbelieves that things have centre of mass, and it might garner some more concrete answers.In summary, there is skepticism about the existence of a barycenter between the Earth and Moon, but it is possible that it exists if calculations are done correctly.
  • #36
Orodruin said:
So, you have made a number of serious errors here.
Let's keep going.
Fifth, you still haven't given a clear description of your point. Are you arguing that the gravitational force is not-central? Or are you arguing that it is not linear? Both are wrong, but you seem to have them tangled up. Sixth, you are giving as evidence for your point that you are really, really good at things like multiple choice tests and word analogies.
Likes phinds, hutchphd, Orodruin and 2 others
Astronomy news on Phys.org
  • #37
Well, the EFEs are non-linear ... :wink:
  • #38
sophiecentaur said:
Would that be measurable? Actually, the shift in Earth's position is not that much less than its diameter so maybe not so daft after all. A few thousand km relative to a distance of a few hundred million km. That's around 10-5 radians which is no problem for astronomers. Edit: well, errr measuring stellar distances in parsecs relies on the full AU.
But I see @OmCheeto has beaten me to it and Mars would be the obvious choice.
According to my back of napkinish attempt so far, the first serious problem is that the Earth travels the distance of the barycenter offset in only 160 seconds. I'm starting to understand why no one would want to tackle this problem. And given that I can identify only 2 stars in the sky, this is well beyond my present capabilities.
  • #39
Let me keep going. Sixth, if you did your homework and Googled "push gravity", the very first link you would get is a Wikipedia article on what is commonly and erroneously called LeSage gravity. It's 430 years old and known to be wrong for well over a century. Either the OP didn't bother to look it up, or you did and decided to post anyway. I'll let the OP decide for himself which is better. Seventh, tossing around words like "bogus" is unlikely to win friends and influence people. Ignorance per se is not a problem - we all have things we are ignorant of. Being ignorant and judgemental is a different kettle of fish.
Likes russ_watters, Motore, hutchphd and 1 other person
  • #40
hutchphd said:
In your mensa group has anyone defined what is required to "prove" the existence of a barycenter? Operationally it is not clear to me how such a proof would be undertaken to your satisfaction.
No. This was just in casual conversation. I would assume that if the EM were rotating around a barycenter it would cause some sort of observable deviation from a smooth transit across the sky for, at least Mars and Venus. My friend was actually writing her doctoral thesis on gravity being a push force and not a pull force but never completed it. She has some of the same questions about the current concept of gravity that I do which led me here.
  • #41
The answer is:
$$ds^2 = -(1- \frac{2M}{r})dt^2 + (1 - \frac{2M}{r})^{-1}dr^2 + r^2d\theta^2 + r^2\sin^2 \theta d\phi^2$$
  • #42
Ron Hargrove said:
No. This was just in casual conversation. I would assume that if the EM were rotating around a barycenter it would cause some sort of observable deviation from a smooth transit across the sky for, at least Mars and Venus. My friend was actually writing her doctoral thesis on gravity being a push force and not a pull force but never completed it. She has some of the same concerns about the current concepts involving gravity that I do which led me here.
Of course, a barycenter is not a measurable point. But rotating around a barycenter would cause a "wobble" as the Earth rotates around that barycenter as it chugs along in its orbit which I feel should be able to be detected somehow. Yet again, I am only trying to find out if anyone is aware of any experiments that clearly show that the Earth is, in fact, rotating around an EM barycenter or is it just universally accepted as valid without being proved that it occurs?
Let me get to the crux of the issue. Two objects with mass are floating in the weightless vacuum of space. If they are near enough to each other they will move toward each other. How do you know it is an invisible force pulling them toward each other instead of an invisible force pushing them toward each other?
I realize that I am no expert in astronomy or physics which is why I came here to seek the council of people who are.
Thank you all for your input.
  • #43
Ron Hargrove said:
My problem with our current understanding of gravity started with that blasted simulation of the mass of the Earth warping space/time to create gravity. You know the one.
The problem with the "curved sheet" model is that the Earth only holds the moon in place because that diagram sucks so much. It's a very poor illustration of our actual models (a case of drawing what can be drawn, rather than explaining what's important). It looks nice and superficially comprehensible, though. And, as @Orodruin notes, it's talking about general relativity, not Newtonian gravity.
Vanadium 50 said:
Let's keep going.
Furthermore, there's a thorny question of what OP actually means to consider. The planets follow the paths they follow. Breaking their motion up into "orbit around the Sun" plus "orbit around barycentre" plus "effect from oblateness of Sun" plus "effect from Jupiter" plus, plus, plus is very much a human convenience. I'm not sure how you could remove "orbit around barycentre", except to set the Moon's gravitational effect to zero in your model (which, I think, is broadly what @Bandersnatch's order of magnitude estimate of parallax implicitly does). Presumably OP's contention is that this would have zero effect on predicted astronomical observations, and presumably the tides happen for some other reason unrelated to the Moon's gravity.
  • #44
The "bogus" part referenced accepting an idea just because everyone else does without proof that it is valid. That is how everyone came to believe the Earth was the center of the universe.
Your post has led me to learn of the Richard Feynman examined the Fatio/Lesage mechanism which may give me the answer I am looking for.
  • #45
Orodruin said:
My personal experience (that admittedly is over 20 years old) is that it is representative. I was a member for a year or so, but most people I interacted with and the local monthly publication gave the impression of people who somehow thought that having a (relatively) high tested IQ (it is not *that* high) made them superior and that any thoghts they had on things they were ignorant about would be pure gold.
That has not been my experience. While there are a few Mensa members around with delusions of superiority the vast majority are just common folks with brains that won't shut down or notice immediately when things don't add up. I like to say that a Mensan is just as likely to leave the house with their fly open as anyone else.
  • #46
Let me be honest. We've tried to answer your questions, but all you do is repeat your unwarranted assertion that the rest of us just swallow what we are told without proof. It's so insulting.
Like a previous poster said, it is like Mensa has hoodwinked you into thinking you are a being with a higher intelligence. And, although we slog away at learning and understanding the physics and mathemetics, all it takes is a casual conversation between you and your friend to blow apart everything we know and replace it with half-baked ideas that have no mathematical or experimental support.
It ain't that easy!
If you have any real intelligence you have to realize how absurd your world-view has become.
Likes PeterDonis, Vanadium 50 and russ_watters
  • #47
Yet again, my only question was whether anyone reading this thread was aware of experimental proof that an EM barycenter exists instead of just the theory that an EM barycenter exists which does not appear to exist to the knowledge of anyone who has read this thread.
  • Skeptical
Likes davenn
  • #48
Huh? Bandersnatch provided it this morning! Back of the envelope, neglecting barycentric movement, stuff would be misplaced on the sky by around a thousand times the error on published tables.
Likes russ_watters
  • #49
What I am looking for is historically verified observations that prove a barycenter rotation and not calculated and projected tables.
  • #50
Ron Hargrove said:
I and at least one other Mensan in my local group (yes, I am a member) have been pondering whether or not gravitation is actually a 'push' force and not a 'pull' force.
PF is not for discussion of personal speculation or past attempts at theories that have already been thoroughly debunked (of which "push gravity" is an example).
And you have been given multiple examples of such in this thread. You said you came here looking for input from experts. You got it. If you don't want to accept it, that's your problem, not ours.
Likes davenn, phinds and PeroK
  • #51
Huh? Various posters in this thread have mentioned lunar ranging, spacecraft navigation, and that planets appear where ephemerides calculations say they should be. All of these are observations showing that the barycenter exists. (There are also observations of double stars, which clearly orbit their common barycenter - it would be a strange universe indeed if gravity between stars worked differently than gravity between planets).
But even if none of that experimental evidence existed it would be mistaken to say, as you do in the first post and later, that the existence of the barycenter would be “just assumed”. The scientific claim about the barycenter is “If our current theories about gravity accurately describe the universe, then there is a barycenter”, and the existence of the barycenter is not an assumption, it is a deduction as solid as “if Euclid’s axioms are valid, then the interior angles of a triangle add to 180 degrees” - the conclusion follows inevitably from the premise.
Thus, any challenge to the notion of the barycenter is actually a challenge to the premise “our current theories about gravity accurately describe the universe”. That is, are there observations that disagree with the predictions made by our current theories about gravity? In the absence of such observations , I don’t need observational confirmation of the barycenter (although as noted above, there is an abundance of these) to conclude that it exists. It’s as valid a claim as the (completely untested) proposition that the next time I drop an object, it will fall just like the last time.
Likes davenn, russ_watters, Klystron and 2 others
  • #52
The OP question has been thoroughly answered. Thread closed.
  • Love
Likes Marc Rindermann and Tom.G
