Is there any chemical reaction with 0 time?
In summary, a chemical reaction is a process where reactants are transformed into products by breaking and forming chemical bonds. Time is important in chemical reactions as it affects the rate and efficiency of the reaction. There is a minimum amount of time, known as activation energy, required for a reaction to occur. Time can also be manipulated to control the outcome of a chemical reaction by adjusting factors such as temperature and concentration.
Noduagga
24
One that occurs immediatly?
Chemistry news on Phys.org
No.
Isn't there even an infinitesimal small time lag in quantum transitions?
You can talk about instantaneous reactions but still time is needed may be very very small faction of it.
Posts with bad information have been deleted. Thread locked to avoid attracting other sources of bad info.
Related to Is there any chemical reaction with 0 time?
1. What is a chemical reaction?
A chemical reaction is a process in which one or more substances, called reactants, are transformed into one or more different substances, called products. This transformation involves breaking and forming chemical bonds between atoms.
2. Can a chemical reaction occur with 0 time?
No, a chemical reaction cannot occur with 0 time. All chemical reactions require a certain amount of time to take place, even if it is only a fraction of a second.
3. Why is time important in chemical reactions?
Time is important in chemical reactions because it determines the rate at which the reaction takes place. The speed of a chemical reaction can be affected by various factors such as temperature, concentration, and the presence of a catalyst. In general, the longer the time allowed for a reaction, the more complete and efficient it will be.
4. Is there a minimum amount of time required for a chemical reaction to occur?
Yes, there is a minimum amount of time required for a chemical reaction to occur. This is known as the activation energy, which is the minimum amount of energy needed for a reaction to take place. Without this energy, the reaction cannot proceed.
5. Can time be manipulated to control the outcome of a chemical reaction?
Yes, time can be manipulated to control the outcome of a chemical reaction. By controlling the amount of time a reaction takes, scientists can influence the rate and extent of the reaction, and therefore, the final products. This is often done by adjusting factors such as temperature and concentration.
  • Chemistry
  • Chemistry
  • Chemistry
