Is there any easy trick for solving this integral?
  • MHB
  • Thread starter skate_nerd
  • Tags
    Integral
In summary, the original integral using Green's Theorem for an outward flux calculation proved to be a challenging and unpleasant one. After trying numerous substitutions and strategies, including consulting WolframAlpha, the user was unable to find a solution without using multiple substitutions and partial fractions. They then considered converting to polar coordinates, but even that proved to be a messy process. Eventually, they were able to solve the integral using a complex analysis approach, but it required a long and complicated process involving integration by parts and partial fractions. The final result was approximately 5.20516, which matched the numerical value provided by WolframAlpha. Overall, this integral is one to be avoided if possible.
skate_nerd
176
In the middle of an integral using Green's Theorem for an outward flux calculation, I came up to a really gross integral. The double integral started out as
$$\int_{-1}^{1}\int_{-\sqrt{1-y^2}}^{\sqrt{1-y^2}}\frac{2}{1+y^2}\,dx\,dy$$
and I got it down to
$$\int_{-1}^{1}\frac{4\sqrt{1-y^2}}{1+y^2}\,dy$$
I tried thinking of numerous substitutions and by parts strategies...nothing seemed to work. I consulted wolframalpha and it gave me a solution using I think something like 4 substitutions and partial fractions which I would really rather not go through.
Any other ideas? Or is this just a terrible integral one would prefer to avoid?
With the substitution $y= \sin \frac{x}{2}$ the integral becomes... $\displaystyle I= 2\ \int_{- \pi}^{\pi} \frac{\cos ^{2} \frac{x}{2}}{1 + \sin^{2} \frac{x}{2}}\ dx = 2\ \int_{- \pi}^{\pi} \frac{1+ \cos x}{3 - \cos x}\ dx $ (1)
... and (1) can be solved using complex analysis approach...
Kind regards$\chi$ $\sigma$
I can't think of an easy way to do this one. I think converting to polar coordinates may ease the pain at the start, but from what you'll see below, it's still quite a messy process.
If you plot the region that's defined by the bounds of integration, it's a circle of radius 1 centered at the origin in the $xy$-plane.
If you do the conversion to polar coordinates, we see that
\[\int_{-1}^1\int_{-\sqrt{1-y^2}}^{\sqrt{1-y^2}} \frac{2}{1+y^2}\,dx\,dy \xrightarrow{\text{polar coordinates}}{} \int_0^{2\pi} \int_0^1\frac{2r}{1+ r^2\sin^2\theta}\,dr\,d\theta\]
The first intergral can be evaluated by making the substitution $u=r^2\sin^2\theta$; then $\,du=2r\sin^2\theta\,dr\implies \dfrac{\,du}{\sin^2\theta}=2r\,dr$. Thus,
\[\int_0^{2\pi} \int_0^1\frac{2r}{1+r^2\sin^2\theta}\,dr\,d\theta \xrightarrow{u=r^2\sin^2\theta}{} \int_0^{2\pi}\int_0^{\sin^2\theta} \frac{1}{\sin^2\theta} \frac{\,du}{1+u}\,d\theta = \int_0^{2\pi} \frac{\ln(1+\sin^2\theta)}{\sin^2\theta} \,d\theta\]
Now here's where all the fun begins.
We proceed to integrate by parts (w/o limits of integration for the time being). Take $u=\log(1+\sin^2\theta)$ and $\,dv=\dfrac{\,d\theta}{\sin^2\theta}=\csc^2\theta\,d\theta$. Then $\,du=\dfrac{2\sin\theta\cos\theta}{1+\sin^2\theta}\,d\theta$ and $v=-\cot\theta$. Therefore,
\[\begin{aligned}\int \frac{\ln(1+\sin^2\theta)}{\sin^2\theta}\,d\theta &= -\cot\theta\ln(1+\sin^2\theta) + \int \frac{2\cot\theta\sin\theta\cos\theta}{ 1+\sin^2\theta}\,d\theta\\ &= -\cot\theta\ln(1+\sin^2\theta) +\int\frac{2\cos^2\theta}{1+\sin^2\theta}\,d\theta\end{aligned}\]
Now, to integrate $\displaystyle\int\frac{2\cos^2\theta}{ 1+\sin^2\theta}\,d\theta$, multiply top and bottom by $\sec^4\theta$ to get
\[\int\frac{2\sec^2\theta}{\sec^4\theta + \sec^2\theta\tan^2\theta}\,d\theta = \int\frac{2\sec^2\theta}{(\tan^2\theta+1)^2 + (\tan^2+ 1)\tan^2\theta}\,d\theta = \int\frac{2\sec^2\theta}{2\tan^4\theta +3\tan^2\theta + 1}\,d\theta\]
Now let $t=\tan\theta\implies \,dt=\sec^2\theta\,d\theta$. Therefore,
\[\int\frac{2\sec^2\theta}{2\tan^4\theta +3\tan^2\theta + 1}\,d\theta \xrightarrow{t=\tan\theta}{} \int\frac{2\,dt}{2t^4+3t^2+1} = \int\frac{2\,dt}{(2t^2+1)(t^2+1)}\]
If things aren't bad enough at this point, things just got worse; it's time to use partial fractions! XD
We first note that
\begin{align*}\frac{1}{(2t^2+1)(t^2+1)}=\dfrac{At+B}{2t^2+1} +\dfrac{Ct+D}{t^2+1} \implies 1 &= (At+B)(t^2+1) + (Ct+D)(2t^2+1) \\ \implies 1 &= At^3+Bt^2+At+B + 2Ct^3+2Dt^2+Ct+D\\ \implies 1 & = (A+2C)t^3+(B+2D)t^2 + (A+C)t + (B+D)\end{align*}
Thus, we solve the system of equations
\[\left\{\begin{aligned}A+2C &= 0\\ B+2D &= 0\\ A+C &= 0\\ B+D &= 1 \end{aligned}\right.\]
It's easy to show that $A=C=0$, $D=-1$ and $B=2$.
Therefore, \[\begin{aligned} \int\frac{2}{(2t^2+1)(t^2+1)}\,dt &= 2\left[\int\frac{2}{2t^2+1}\,dt - \int\frac{1}{t^2+1}\,dt\right]\\ &= 2\left[\sqrt{2}\int\frac{\sqrt{2}}{(\sqrt{2}t)^2+1}\,dt - \int\frac{1}{t^2+1}\,dt\right]\\ &= 2\left[\sqrt{2}\arctan(\sqrt{2}t) - \arctan(t)\right]+C\end{aligned}\]
Since $t=\tan\theta$, we have that
\[2\left[\sqrt{2}\arctan(\sqrt{2}\tan\theta) - \arctan(\tan\theta)\right]+C = 2\sqrt{2}\arctan(\sqrt{2}\sin\theta) -2\theta+C\]
and thus
\[\int\frac{2\cos^2\theta}{1+\sin^2\theta}\,d\theta = 2\sqrt{2}\arctan(\sqrt{2}\tan\theta) - 2\theta + C\]
and furthermore we now have that
\[\int \frac{\ln(1+\sin^2\theta)}{\sin^2\theta}\,d\theta = -\cot\theta\ln(1+\sin^2\theta) + 2\sqrt{2}\arctan(\sqrt{2}\tan\theta) -2\theta+C\]
We must take note of something due to the oscillatory nature of $\dfrac{\ln(1+\sin^2\theta)}{\sin^2\theta}$ seen below over the interval $[0,2\pi]$:
If we were to evaluate the integral over $[0,2\pi]$, lots of things would be ignored and we end up with an answer of $-4\pi$ (which makes no sense). From the graph, it makes sense to evaluate the integral from $[0,\pi/2]$ and then multiply that result by 4 to get the entire area. With that said, it follows now that
\[\begin{aligned} \int_0^{2\pi} \frac{\ln(1+\sin^2\theta)}{\sin^2\theta}\,d\theta &= 4\int_0^{\frac{\pi}{2}} \frac{\ln(1+\sin^2\theta)}{\sin^2\theta}\,d\theta \\ &= 4\left[-\cot\theta\ln(1+\sin^2\theta) + 2\sqrt{2}\arctan(\sqrt{2}\tan\theta) -2\theta\right]_0^{\frac{\pi}{2}} \\ &= 4\left[ \left( -\cot\frac{\pi}{2} \ln\left(1+\sin^2\frac{\pi}{2}\right) + \lim_{b\to\frac{\pi}{2}^-} 2\sqrt{2} \arctan\left(\sqrt{2}\tan b\right) -\pi\right)\right.\\ & \phantom{=.4.} \left.-\left( \lim_{a\to 0^+} -\cot a\ln(1+\sin^2 a) +2\sqrt{2} \arctan(\sqrt{2} \tan 0) \right)\right] \\ &= 4\left[(\sqrt{2}\pi -\pi) - \underbrace{\lim_{a\to 0^+} -\cot a\ln(1+\sin^2 a)}_{=0\text{ by L'Hôpital's rule}}\right]\\ &= 4\pi(\sqrt{2}-1)\approx 5.20516\end{aligned}\]
Which luckily matches up with the numerical value provided by WolframAlpha (!)
(Whew)
It's a lot to read through, but I hope this makes sense! XD
EDIT: Ninja'd by chisigma by about an hour or so... >_>
Bacterius said:
...and that's how I felt once I actually finished computing this integral.
(I pretty much laughed out loud when I saw that picture...at 02:15 when everyone around my place is practically sleeping...thanks for that. (Tongueout))
Another method: switch the order of integration. You get
$$ \int_{-1}^{1} \int_{- \sqrt{1-y^{2}}}^{ \sqrt{1-y^{2}}} \frac{2}{1+y^{2}} \, dx \, dy=2 \int_{-1}^{1} \int_{- \sqrt{1-x^{2}}}^{ \sqrt{1-x^{2}}} \frac{1}{1+y^{2}} \, dy \, dx=4 \int_{-1}^{1} \int_{0}^{ \sqrt{1-x^{2}}} \frac{1}{1+y^{2}} \, dy \, dx=$$
$$=4\int_{-1}^{1} \tan^{-1} \left( \sqrt{1-x^{2}}\right) dx= 8\int_{0}^{1} \tan^{-1} \left( \sqrt{1-x^{2}}\right) dx.$$
This last integral would succumb, I think, to by-parts (might need to do that twice). You can see that I've used symmetry twice.
[EDIT]: A single by-parts is useful, but the remainder of the steps are a bewildering array of substitutions. This will eventually get you to the same sorts of integrals Chris L T521 did.
Speaking as a Physicist integrals like this are the reason that Mathematicians are included in research groups. (Bow)
-Dan
Wow. Chris L that was an impressively thorough solution. Kudos to you sir. I'd have to say Ackback wins the price for simplicity however. I'll try to solve it his way when I finish all this physics homework...
Maybe you didn't see my edit. My way leads to thickets of equations every bit as dense as Chris's, I'm afraid. I might possibly reach the thickets a tad quicker, but they're still there.
I kind of like Wolfram's solution.
It's 5.20516.
Unless you want a beautiful mathematical solution. (Lipssealed)
Ah Ackbach yeah I just saw your edit now. I have a feeling my professor didn't go through this homework himself...that integral is too mean and cruel
Ah, yes: the (in)famous "exercise for the reader".
Or the one that is slightly "too large to fit into the margin". ;)
FAQ: Is there any easy trick for solving this integral?
What is an integral?
An integral is a mathematical concept that represents the area under a curve on a graph. It is typically used to find the total value of a function over a given interval.
Why do I need to solve integrals?
Integrals are used in many fields of science and engineering to solve problems such as finding the velocity and acceleration of an object, determining the amount of energy in a system, or calculating the probability of an event occurring.
What makes solving integrals challenging?
Solving integrals can be challenging because there is no single method that can be applied to all integrals. Each integral requires its own unique approach and may involve multiple steps and techniques.
Are there any easy tricks for solving integrals?
Yes, there are some common techniques that can make solving integrals easier. These include substitution, integration by parts, and using trigonometric identities. However, these tricks may not work for every integral, and it is important to have a strong understanding of the fundamentals of integration.
How can I improve my skills in solving integrals?
The best way to improve your skills in solving integrals is through practice. By attempting a variety of integrals and learning different techniques, you can become more comfortable and proficient in solving them.
