Is there any evidence of a universe expansion jerk
In summary: This would cause the expansion of the universe to accelerate at a faster rate, leading to a higher Hubble constant. However, more data and analysis is needed to determine if this is a valid explanation.
arusse02
24
As stated in the question--is there any evidence of a non zero rate of change of the acceleration of the expansion of the universe. What is the evidence for it and is it negative or positive? Also if there is what would it take to determine if there was a jounce?
Space news on Phys.org
Yes. The expansion only started accelerating a few billion years ago (based on the curve of redshift vs. brightness and angular size for distant galaxies), so the rate of acceleration has obviously not been constant. The reason it has not been constant is that the relative proportion of dark energy vs. other types of energy density has not been constant, because the density of dark energy remains the same as the universe expands (as far as we know), while the density of matter (ordinary and dark) decreases.
Also, bear in mind that values are easier to measure than how much those values change: looking at the change instead of the value adds noise.
As PeterDonis mentioned, the rate has changed over time for sure because the matter density drops as the universe expands. Earlier, when matter density was higher, the rate at which objects moved apart was decelerating. As dark energy has become more dominant (because it doesn't drop in density much if at all as the universe expands), the distances between objects have started accelerating.
What we can't tell right now is whether or not dark energy has changed over time: that measurement is far too noisy at the moment.
One possible explanation for the Hubble tension is that dark energy is not a constant
Related to Is there any evidence of a universe expansion jerk
1. What is a universe expansion jerk?
A universe expansion jerk refers to a sudden change in the rate of expansion of the universe. It is characterized by a significant increase in the acceleration of the expansion, followed by a decrease.
2. Is there any evidence of a universe expansion jerk?
Yes, there is evidence of a universe expansion jerk. Studies of the cosmic microwave background radiation, the redshift of distant galaxies, and the distribution of matter in the universe all support the existence of a universe expansion jerk.
3. How does a universe expansion jerk affect the universe?
A universe expansion jerk can have a significant impact on the structure and evolution of the universe. It can cause the universe to expand at a faster rate, leading to a larger and more spread-out universe. This can also affect the formation of galaxies and other celestial bodies.
4. What causes a universe expansion jerk?
The exact cause of a universe expansion jerk is still unknown, but it is believed to be linked to the mysterious force known as dark energy. Dark energy is thought to be responsible for the acceleration of the expansion of the universe and may also play a role in the occurrence of a universe expansion jerk.
5. Could a universe expansion jerk lead to the end of the universe?
It is unlikely that a universe expansion jerk would lead to the end of the universe. While it can cause significant changes in the expansion rate, the universe is still expected to continue expanding indefinitely. However, a universe expansion jerk could potentially have other consequences that are not yet fully understood by scientists.
