Is there any reason for tensor indices being ordered one way or the other?
In summary: Contravariant and covariant vectors transform slightly different under coordinate transformations. A contravariant vector \mathbf{v}=v^{\alpha} transforms according to v^{\alpha}=x^{\alpha}_{, \beta}v^{\beta} while a covariant vector \mathbf{u}=u_{\alpha} transforms as u_{\alpha}=y^{\beta}_{, \alpha}u_{\beta} . It has to do with which vector space they live. For the vector space V in
CPL.Luke
441
if I have an expression
gca * dwab
is there any reason for the resultant tensor should be dwcb vs. dwbc?
Yes, because not all tensors are symmetric. With a non-symmetric tensor, Tcb ≠ Tbc, so if you change Tcb to Tbc, you've changed the value.
I guess the rule would be to keep left indices as left indices and right indices as right indices. In the example you give, I look at the sequence of indices "caab" and think of the two a's in the middle as "canceling out" - although that doesn't always work, when you're dealing with more complicated tensor products.
Think what happens when you transpose a matrix. If the matrix is symmetric about the main diagonal, its components are unchanged, otherwise there will be a difference. If you know that the tensor you're dealing with is symmetric in a given pair of indices, you're free to swap them; if not, just remember to keep them in the same horizontal order. If it's antisymmetric in a given pair of indices, swapping them has the same effect as multiplying by -1, so you can swap them and multiply by -1 to get back to where you started.
thankyou,
my question is more about why the order matters and how to determine the proper order in general. If you look at the first expression, its an expression to lower an index, but when this ndex gets lowered which side would it be on?
gca dwa b = dwcb
In general, the horizontal order doesn't change. Just turn a into c and bring it straight down.
what if I had written it
gcadwba or dwbagca
in general when the indices come down do they go to the front of the line? or is there a situation where they would go to the back of the line?
and what about the covariant indices, if they are raised do they go to the front or back of the line at the top?
I think the above two questions are really where I'm getting hung up...
thankyou
The indices move straight vertically.
thankyou,
I still don't see the difference between a rank (1,1) tensor such as wab and wba, I may have to do more reading.
CPL.Luke said:
thankyou,
Sorry...misread the OP's post
Saying that a tensor is of type [tex] (r,s) [/tex] means that it has [tex] r [/tex] number of contravariant indices and [tex] s [/tex] number of covariant indices.
A contravariant vector [tex] \mathbf{v}=v^{\alpha} [/tex] transforms according to
[tex]
[/tex]
while a covariant vector [tex] \mathbf{u}=u_{\alpha} [/tex] transforms as
[tex]
[/tex]
For the vector space [tex] V in a fixed basis [tex] \{\epsilon_{\alpha}\} [/tex], contravariant vectors are the row vectors [tex] x^{\alpha} [/tex] of contravariant components.
The dual space [tex] V^{*} [/tex] will have a dual base [tex] \{ e^{\alpha} \} [/tex] where the the covariant vectors are given by
[tex]
\mathbf{v}=\{e^{\alpha} \}v_{\alpha}
[/tex]
If [tex] V [/tex] and [tex] V^{*} [/tex] are isomorphic, then the space of tensors of a finite rank are symmetric about their indices...the tensors are invariant when you permute the indices.
That seems to go against what I learnt. Here's how I currently understand it. All corrections welcome.
In general, [itex]T_{\mu \nu} \neq T_{\nu \mu}[/itex], right? There will always be an isomorphism between [itex] V [/itex] and [itex] V^{*} [/itex] since they're over the same field and of the same dimension, therefore, if [itex]\mathbb{K}[/itex] is the field, and [itex]n[/itex] the dimension, [itex] V [/tex] and [itex] V^{*} [/itex] are each isomorphic to [itex]\mathbb{K}^n[/itex], which implies that [itex] V [/itex] is isomorphic to [itex] V^{*} [/itex]. If we have a metric, [itex]g[/itex], there will be a natural (canonical) isomorphism defined by the metric and its inverse:
[tex]g:V\to V^*: g_{\mu \nu} v^\nu=v_\mu[/tex]
[tex]g:V^* \to V : g^{\mu \nu}v_\nu=v^\mu[/tex]
If no metric is defined, only the horizontal order of indices relative to others at the same height matters:
[tex]T^{\alpha \beta}\;_{\gamma}=T_{\gamma}\;^{\alpha \beta}=T^{\alpha}\;_{\gamma}\;^{\beta}[/tex]
so you don't need to keep track of them and could just write [itex]T^{\alpha \beta}_{\gamma}[/tex]. This is because there's no natural answer to the question: "Which tensor with an up index here corresponds to the tensor with a down index?"
But if a metric is defined, that question does have a definite answer, so you do have to keep track of the horizontal order of indices relative to those of both heights, up and down, because
[tex]g_{\alpha \mu} T^{\alpha}\,_{\nu} = T_{\mu \nu}[/tex]
[tex]g_{\alpha \mu} T_{\nu}\,^{\alpha} = T_{\nu \mu}[/tex]
and
[tex]T_{\mu \nu} \neq T_{\nu \mu}[/tex]
unless it [itex]T[/itex] happens to be symmetric. But in general, there's no guarantee that [itex]T[/itex] will be symmetric.
Actually there isn't always an isomorphism between V and V*!
But that's more of an interesting factoid as we're clearly only interestred in the finite dimensional case where they are always isomorphic.
Ooh, thanks for that proviso, I hadn't thought of whether it would be different with infinite dimensions. Most of my reading has been confined to the case of finite dimensions. Is the rest okay?
Just by way of confirmation: "The index staggering is needed for when a metric is introduced since spaces are needed for the raising and lowering of indices" (Roger Penrose: The Road to Reality (Vintage 2005), note 14.3, p. 323).
FAQ: Is there any reason for tensor indices being ordered one way or the other?
1. What is the significance of the order of tensor indices?
The order of tensor indices is important because it determines how the tensor transforms under coordinate transformations. It also affects the number of independent components of the tensor and its symmetries.
2. Why are tensor indices often ordered from left to right?
This convention is commonly used because it follows the convention of matrix multiplication, where the left index corresponds to the row and the right index corresponds to the column. This makes it easier to perform tensor operations and write equations.
3. Can the order of tensor indices be changed without affecting the tensor itself?
No, the order of tensor indices cannot be changed without changing the tensor itself. The order of indices is an intrinsic property of the tensor and determines its behavior under transformations.
4. Are there any exceptions to the convention of ordering tensor indices from left to right?
Yes, there are some cases where it is more convenient to order the indices in a different way. For example, in some areas of physics, such as general relativity, the convention is to order the indices from right to left.
5. How does the order of tensor indices affect the complexity of calculations?
The order of tensor indices can greatly affect the complexity of calculations. In general, the more indices a tensor has and the higher the order of those indices, the more complicated the calculations become. Changing the order of indices can sometimes make calculations easier or more difficult, depending on the specific tensor and the operation being performed.
