MHB Is there any sense with these squares?
  • Thread starter Thread starter kpkkpk
    Squares
The discussion explores a method of relating factorials to perfect squares by using the square roots of factorials and adjusting them to the next whole number. For integers from 4 to 16, except for 12, the difference between the square of the ceiling of the square root of the factorial and the factorial itself yields perfect squares. The example of 10! illustrates this process, where the adjusted square root leads to a perfect square difference. However, this method fails for 12! and larger factorials, raising questions about the underlying pattern. The conclusion suggests that while factorials can be expressed as the difference of two squares, the larger square may not always be the ceiling square.
kpkkpk
1 = 1^2
1 = 1^2
9 = 3^2
1 = 1^2
81 = 9^2
729 = 27^2
225 = 15^2
324 = 18^2
X
82944 = 288^2
176400 = 420^2
215296 = 464^2
3444736 = 1856^2
So, I am trying to find short method to find factorials. In order to achieve this, I imagined factorials as squares, one edge of which corresponding square root of said factorial. However, as these square roots tend not to be natural numbers but have decimal extension, I chose the next bigger number mimicking factorial edge. That slightly bigger edge I then squared and from it I subtracted the real factorial value in a hope to find a series of natural numbers of some sense...And actually at first I was quite delighted while finding series presented above corresponding factorials 4!, 5!, 6!, 7!, 8!, 9!, 10!, 11!, 13!, 14!, 15!, 16!
As an example, please, look at number 225 (=15^2) in the list above. It associates with 10! (=3628800) in the following way:
10! squared (=10^(1/2)) = 1904,940944...
So, I chose 1905 as enlarged edge of square: 1905^2 = 3629025
From that I subtracted the real value of 10!: 3629025 - 3628800 = 225 = 15^2.
In an analogous way I found other squares presented in the list...but not that one corresponding 12! as 12!^(1/2) = 21886,10518... and 21887^2 - 12! = 39169 is not a square of any natural number. The same problem continued with bigger factorials (17!, 18!, 19!, perhaps more?) as well.
Can someone find any sense with this list or is this just natures cruel joke to lead us into desperation?
Mathematics news on Phys.org
kpkkpk said:
1 = 1^2
$\color{red}{n=4:\ \bigl(\lceil\sqrt {4!}\rceil\bigr)^2 - 4! = 25 - 24 =} 1 = 1^2$
$\color{red}{n=5:\ \bigl(\lceil\sqrt {5!}\rceil\bigr)^2 - 5! = 121 - 120 =} 1 = 1^2$
$\color{red}{n=6:\ 27^2 - 6! = 729 - 720 =} 9 = 3^2$
$\color{red}{n=7:\ 71^2 - 7! = 5041 - 5040 =} 1 = 1^2$
$\color{red}{n=8:\ 201^2 - 8! = 49491 - 40320 =} 81 = 9^2$
$\color{red}{n=9:\ }729 = 27^2$
$\color{red}{n=10:\ }225 = 15^2$
$\color{red}{n=11:\ }324 = 18^2$
X
$\color{red}{n=13:\ }82944 = 288^2$
$\color{red}{n=14:\ }176400 = 420^2$
$\color{red}{n=15:\ }215296 = 464^2$
$\color{red}{n=16:\ }3444736 = 1856^2$
This is a neat investigation, based on the fact that for each integer $n$ from $4$ to $16$, apart from $12$, $\bigl(\lceil\sqrt {n!}\rceil\bigr)^2 - n!$ is a perfect square (where the ceiling symbols $\lceil\ \ \rceil$ indicate the next integer above the enclosed number). I have added some comments in red to the above quote, to emphasise the pattern.
So, why does this work for some integers but not for others?
We can write the equation $\bigl(\lceil\sqrt {n!}\rceil\bigr)^2 - n! = \text{square}$ as $n! = a^2-b^2$, where we want $a^2$ to be as close as possible to $n!$ (so that $a = \lceil\sqrt {n!}\rceil$) and therefore $b^2$ should be as small as possible. If we factorise the right side as $n! = (a+b)(a-b)$ then what we are trying to do is to express $n!$ as a product of two integers that are as close as possible to each other. This can be done as follows, starting with $n=4$: $$4! = 4\cdot 3\cdot 2\cdot 1 = (3\cdot 2)(4\cdot 1) = 6\cdot 4 = (5+1)(5-1) = 5^2 - 1^2.$$ In the same way, $$5! = (4\cdot 3)(5\cdot 2) = (11+1)(11-1) = 11^2 - 1^2,$$ $$6! = (5\cdot 3\cdot 2)(6\cdot 4\cdot 1) = (27+3)(27-3) = 27^2 - 3^2,$$ $$7! = (6\cdot 4\cdot 3)(7\cdot 5\cdot 2) = 71^2-1^2,$$ $$8! = (8\cdot 6\cdot 4\cdot 1)(7\cdot 5\cdot 3\cdot 2) = 201^2 - 9^2,$$ $$9! = (9\cdot 7\cdot 5\cdot 2)(8\cdot 6\cdot 4\cdot 3) = 603^2 - 27^2,$$ $$10! = (10\cdot 8\cdot 6\cdot 4\cdot 1)(9\cdot 7\cdot 5\cdot 3\cdot 2) = 1905^2 - 15^2,$$ $$11! = (11\cdot 8\cdot 6\cdot 4\cdot 3)(10\cdot 9\cdot 7\cdot 5\cdot 2) = 6318^2 - 18^2.$$ The way that I factorised $(n+2)!$ was to take the factorisation for $n!$, multiply the smaller of its two factors by $n+2$ and multiply the larger of its two factors by $n+1$. That way, I would hope to get a factorisation of $(n+2)!$ into two nearly equal factors. When we get to $n=12$, the result is $$12! = (12\cdot 9\cdot 7\cdot 5\cdot 3\cdot 2)(11\cdot 10\cdot 8\cdot 6\cdot 4\cdot 1) = 21900^2 - 780^2.$$ Here, for the first time, the larger of the two squares is not $\bigl(\lceil\sqrt {n!}\rceil\bigr)^2$. In fact $\lceil\sqrt {12!}\rceil = 21887 < 21900.$
So I think the best one can say is that (for $n\geqslant 4$) $n!$ can always be expressed as the difference of two squares, the larger of which is fairly close to $\bigl(\lceil\sqrt {n!}\rceil\bigr)^2$ but cannot necessarily be chosen to be equal to it.
Many thanks for you Opalg for detailed answer.
I also found this same series of squares from Online Ensyclopedia of Integer Sequences (OEIS) with code A038202.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
