Is there any way to derive the time dilation formula?
In summary, the formula for the relationship between proper time and dilated time interval between two events due to relative motion of reference frames can be derived using Doppler shifts and the relativity principle. This formula takes into account the fact that the speed of light is constant and that motion is relative. It shows that the clock of a moving observer appears to run slower than the clock of a stationary observer, with the time dilation factor given by the formula $\frac{1}{\sqrt{1-\vec{v}^2}}$. This derivation does not involve any special cases such as zig-zag motion of light pulse, making it a universal derivation.
Prem1998
148
I've already read the derivation in which we use the light pulse clock kept in a spacecraft such that the light pulse follows a zig-zag motion due to motion of the spacecraft being perpendicular to motion of the light pulse. Then, we apply Pythagoras theorem to derive the formula.
BUT this seems like derivation in a special case, not a universal derivation. I mean there won't be any zig-zag motion of light pulse if it is sent in the same direction as the motion of the spacecraft , so we can't apply Pythagoras theorem in that case to derive the same formula.
I just need a derivation which doesn't involve any zig-zag motion of light pulse or any other special case. A derivation which just derives the formula for the relationship between proper time and dilated time interval between two events due to relative motion of reference frames.
That's simple. The proper time of a moving particle is defined by (using natural units with ##c=1##):
$$\mathrm{d} \tau=\sqrt{\eta_{\mu \nu} \mathrm{d} x^{\mu} \mathrm{d} x^{\nu}}=\mathrm{d} t \sqrt{\eta_{\mu \nu} \frac{\mathrm{d} x^{\mu}}{\mathrm{d} t} \frac{\mathrm{d} x^{\nu}}{\mathrm{d} t}}=\mathrm{d} t \sqrt{1-\vec{v}^2}.$$
Thus you have
$$\frac{\mathrm{d} t}{\mathrm{d} \tau}=\frac{1}{\sqrt{1-\vec{v}^2}}.$$
Likes Dale
It's a special case of a clock. But, you only need to show time dilation applies in the case of one reliable clock and the conclusion is inevitable: that time itself is dilated. The only alternative is that there is something wrong with your clock. The reason a light clock is used is that one of the postulates of Special Relativity is that the speed of light is constant in all inertial reference frames. So, measuring the time light takes to travel a known distance is perhaps the only reliable clock at this stage of the theoretical development of relativity.
The problem if the light is shining in the direction of motion is that you also have length contraction to take into account. Until you've worked out length contraction, you don't know the relative lengths and you cannot immediately deduce time dilation alone. There is, therefore, an important point about the light clock: how do you know that the height of the clock (i.e. distance perpendicular to motion) is the same for both observers?
For example, if length were contracted perpendicular to motion for one observer, then that might equally explain the constant speed of light without time dilation.
You might like to think about this question: why can there be no length contraction for distances perpendicular to the motion?
It can be derived using Doppler shifts plus the relativity principle (equivalence of inertial frames) plus the fact that the speed of light is constant.
First, the nonrelativistic Doppler formulas: If you are sending light signals between two observers moving away from each other at relative speed [itex]v[/itex], then the frequency is shifted lower by a factor of [itex]\frac{1}{1+\frac{v}{c}}[/itex], in the case where the sender is moving and the receiver is at rest. If the sender is at rest and the receiver is moving, the frequency is shifted lower by a factor of [itex]1-\frac{v}{c}[/itex]. So nonrelativistically, there is a distinction in the Doppler formula for the two cases. Relativistically, there can't be a difference, since motion is relative; you can't say which one of the sender or receiver is moving. This is the clue to developing the time dilation factor.
Suppose that we are in a frame where Alice is at rest, and Bob is moving away from Alice at velocity [itex]v[/itex]. Every [itex]T[/itex] seconds (according to Alice's clock), she sends a light signal toward Bob, and every [itex]T[/itex] seconds (according to Bob's clock), he sends a light signal toward Alice. Let [itex]r[/itex] be the rate of Bob's clock, as measured by Alice. We can show that [itex]r[/itex] cannot be equal to 1, and in fact, has to be given by the time dilation factor.
If Alice sends a signal once every [itex]T[/itex] seconds, according to her clock. Since Bob is moving away from Alice, every signal has farther to travel than the last, so the time between signals as the arrive at Bob, is greater than [itex]T[/itex]. Alice computes that they arrive at Bob every [itex]\frac{T}{1-\frac{v}{c}}[/itex] seconds. However, if Bob's clock is running slow by a factor of [itex]r[/itex], then he will measure the time between signals to be shorter: every [itex]\frac{r T}{1-\frac{v}{c}}[/itex] seconds.
Now, let's consider the signals Alice receives from Bob. Bob sends the signals once every [itex]T[/itex] seconds, according to his clock. But since his clock is running slow by a factor of [itex]r[/itex], then according to Alice, he is sending the signals once every [itex]\frac{T}{r}[/itex] seconds. Since Bob is moving away from Alice, the signals take longer and longer to arrive at Alice, so (again skipping the derivation), the time between signals as they arrive at Alice is not [itex]\frac{T}{r}[/itex], but [itex]\frac{T (1+\frac{v}{c})}{r}[/itex]
So, Alice measures signals coming from Bob once every [itex]\frac{T (1+\frac{v}{c})}{r}[/itex] seconds, while Bob measures signals coming from Alice once every [itex]\frac{r T}{1-\frac{v}{c}}[/itex]. By the relativity principle, these numbers should be the same (because their situations are exactly analogous). So we must have:
[itex]\frac{T (1+\frac{v}{c})}{r} = \frac{r T}{1-\frac{v}{c}}[/itex]
Solving for [itex]r[/itex] gives:
[itex]r = \sqrt{1-\frac{v^2}{c^2}}[/itex]
The problem if the light is shining in the direction of motion is that you also have length contraction to take into account. Until you've worked out length contraction said:
If to derive the expression for time dilation when light pulse of the clock is in the direction of motion of the spacecraft , the expression for length contraction is required, then I want a derivation for the expression of length contraction which does not involve any light pulse clock..
You're fundamentally misunderstanding time dilation. It's time dilation, not clock dilation. If time dilates, it dilates. Full stop. Shining a light in a different direction is not going to change the laws of physics.
You only have to prove it one way. One proof is enough. It doesn't mean that relativity is not proven until someone comes up with a thought experiment that proves time dilation using an hourglass!
I completely understand the fact that if time dilation is proved for a light clock, then it is proved for any other clock or any other thing which is affected by time. I'm saying that the way it is proved for the light pulse clock seems like a special case to me. I posted this thread to find a proof which does not assume the motion of light pulse relative to the spacecraft in some suitable direction, like assuming it is perpendicular to the motion of the spacecraft . And, if for light pulse traveling in the same direction as spacecraft , the expression for length contraction is required, then I want a proof for length contraction which does not involve any assumptions.
Perhaps someone else can do that for you. But, you know, for me it would be a monumental waste of time. In the direction of the ship is also a special case. What you might ask for next is to prove it for light with an arbitrary velocity vector in the x-y-z directions. Or, perhaps, when the light clock is rotating within the spacecraft ?
The fact that the light clock is stationary with respect to the ship is also a special case.
One solution is to learn SR and prove it for yourself!
Anyway, you never considered the question I asked in post #3 about length contraction in the perpendicular direction. Explaining that is a valid step in confirming the normal derivation time dilation.
If you are happy with the derivation for the transverse light clock and you are happy with the notion that what is true for one clock is true for all then you have a proof for a light clock in a general orientation.
Likes SiennaTheGr8
Thanks, man. This does seem like the real proof.
There is said:
I'm sorry I didn't consider this question of yours. You're right. So, how do we know that the thing we call time dilation on the light clock wasn't actually due to the length contraction? Is this proved?
I think that makes sense. So, if the people on spacecraft have two clocks: one light clock in perpendicular orientation and one in any other orientation. And, if they do not agree, then the first principle is violated. Thanks, man. Now, I'm considering the question raised by PeroK: How do we know that the time dilation on the light clock was actually due to time slowing down and not due to perpendicular length contraction?
@Prem1998 I'm asking you to prove it! It's not as hard as you think. Consider two people moving towards each other. If they are not the same height, then ...?
I don't have a deeper understanding of relativity. I'm guessing that if they're not of the same height then, is it violating principles of relativity? Can you give me more hints?
If they are the same height. Or, better still, each has a vertical metre stick. Then, when they collide, which metre stick is shorter?
If you're assuming they're the same height, just moving towards each other, then why're you asking which one is shorter on collision?
Are you saying that both metre sticks must be the same height in both reference frames? Why? Why can there be no length contraction in this direction?
Perhaps they both measure the other's metre stick as shorter than their own?
So, does perpendicular length contraction happen?
It can't. The logic is as follows:
Assume the bottom ends of the metre sticks are lined up and collide. Let's take the stick on the left. Where does the top of that stick collide with the other. If it collides lower than the top of the one on the right, then it is shorter. But, that would be a valid measurement in both frames. Likewise, if it was above the top of the stick on the right, then it would be longer in both frames.
Any length contraction in the perpendicular direction would have to be absolute: one would be shorter in both frames. But, with the assumption than neither is absolutely moving, there's no reason that either must be shorter than the other.
The only conclusion is that they must be the same length of ##1m## as measured in both reference frames.
That then opens the door to use Pythagoras in the light clock experiment. You know the perpendicular length of the light clock is not changed by the relative motion.
Thanks, man.
You can use the Lorentz transformation to relate a proper time interval, Δτ, in one frame to the corresponding time interval in another frame, Δt, and you will get the time dilation formula.
Or you take the manifestly covariant way shown in #2. Usually it's more easy to work with tensors than to do the Lorentz transformation explicitly. In this respect I also have to rewrite my SRT FAQ, particularly the cumbersome treatment of the Thomas precession. There you can get much simpler and with better intuition using Fermi-Walker transport. As usual, learning the adequate math first, makes things simpler.
It's not apparent from the OP's questions that he is ready to deal with tensors, covariance, etc.
That's not true... the Bondi k-calculus approach uses the radar method... that's essentially the Doppler approach suggested by @stevendaryl . However Bondi's method uses "k" as the basis for everything... deriving velocity, gamma, time-dilation, length-contraction, transformations involving coordinate-position and coordinate-time, etc... later. Eventually, one learns that k is the Doppler factor... and if one studies it further, one learns that it's the eigenvalue of the Lorentz Transformation, which has the form of the exponential function of the rapidity.
[This was used in my insights: https://www.physicsforums.com/insights/relativity-rotated-graph-paper/ and https://www.physicsforums.com/insights/spacetime-diagrams-light-clocks/ which did use a "longitudinal light clock". (In my formulation, length contraction is a consequence of the approach, not a prerequisite.)]
Note that in Bondi's method that there was no need to appeal to a second spatial direction (as is done in the more typical transverse light-clock).
Then one should tell the OP that doing physics without tensors is too difficult to comprehend ;-).
Likes stevendaryl
Why isn’t simply deriving the Lorentz transformation enough? Time dilation is right there in it, and no special light clocks are needed.Edit- Oh snap. I just realized I bumped a two year old thread. Sorry, I saw it in the suggested thread section and posted.
Well, the Lorentz transformation of course is one way to derive time dilation. A much simpler way is to just write down covariant quantities. In this case the even invariant quantity is the proper time of a particle. It's described by a world line ##x^{\mu}(\lambda)##, where ##\lambda## is an arbitrary parameter. The particle's worldline must be time-like, i.e., using the west-coast convention for the Lorentz pseudometric, ##(\eta_{\mu \nu})=\mathrm{diag}(1,-1,-1,-1)## that means ##\dot{x}_{\mu} \dot{x}^{\mu}>0## (with the dot denoting derivatives wrt. ##\lambda##). Then proper time is defined by
$$\tau=\int_{\lambda_0}^{\lambda} \mathrm{d} \lambda' \sqrt{\dot{x}(\lambda') \cdot \dot{x}(\lambda')}.$$
It's clear that ##\tau## is the time the particle "experiences" in its rest frame (or more precisely it's the integral over all infinitesimal time increments in the momentaneous inertial rest frames of the particle along its world line). Since ##(\dot{x}^0)^2 \geq \dot{x} \cdot \dot{x}## everywhere along the world line ##\tau \leq t##, where ##t## is the time an observer at rest wrt. the inertial frame used to do the calculation. That's time dilation in it's coordinate-independent formulation, and it's the most simple resolution of all apparent "twin paradoxes".
It is enough - @pixel mentions this possibility in #22 above.
Likes Sorcerer
Perpendicular emission of light and reflection by mirror at ceiling of train or rocket is a good idea to consider behavior of time. This special case leads us to the general rule. Of course more strict and general mathematics is well established, if you prefer but I do not very well.
  • #31
Further to my post #30, go-return or your "a zig-zag" path of light scheme seems essential to define time.
You prepare a measure and emit light and accept light that was reflected at the other end of the measure.
This procedure defines proper time interval of the observer, I think.
I think further
-Time cannot be defined on mathematical point of spacetime. We need space for light to go-return that we can set as small as we like theoretically.
-QM might say something on fundamental uncertainty of deciding time and also space that matters setting length and position of the measure used for time decision.
  • #32
Funny thing, the light clock and the Pythagorean theorem is exactly how I derived the Lorentz factor for the very first time. But back then I thought special relativity was just taking a Newtonian physics relationship and multiplying it by the Lorentz factor, lol. Works for 3-momentum, though. ;). γ(u)mu
Related to Is there any way to derive the time dilation formula?
1. How is the time dilation formula derived?
The time dilation formula is derived from the theory of relativity, specifically the special theory of relativity. It is based on the concept that time is not absolute and can be affected by factors such as velocity and gravity.
2. What is the time dilation formula?
The time dilation formula is t' = t / √(1 - v²/c²), where t' is the observed time, t is the proper time, v is the relative velocity, and c is the speed of light.
3. Can the time dilation formula be applied to all situations?
The time dilation formula is a mathematical equation that can be applied to any situation where there is relative motion between two observers or when there is a difference in gravitational potential between two locations.
4. How does the time dilation formula affect space travel?
The time dilation formula is crucial in understanding and predicting the effects of time on space travel. It allows scientists to calculate the difference in time experienced by astronauts traveling at high speeds or in strong gravitational fields compared to those on Earth.
5. Is the time dilation formula proven?
The time dilation formula has been extensively tested and has been proven to be accurate in various experiments and observations. It is a fundamental principle of the theory of relativity and has been confirmed by numerous experiments and observations in the fields of physics and astronomy.
