Is there entanglement other than 50/50 energy? of the pump photon
In summary, during the creation of entangled photons through SPDC, it is possible to obtain photons with energy splits of 60/40, 70/30, etc. by adjusting or removing the filter. This means that one of the entangled photons will have 60% of the energy of the pump photon, while the other will have 40%. This has implications for spin or momentum entangled photons and could affect their behavior in experiments such as double slit interference, Bell's experiments, and the delayed choice quantum eraser. Non-linear optics can be a complicated process, but it is possible to control the desired pairs by collecting them at specific angles. The fidelity of 60-40 splits may be affected, but further research is
San K
911
During the creation of entangled photons (say via SPDC as described, for example, at the bottom of this post):
Do/can we also get photons that are say 60/40, 70/30 etc? ..if we remove/adjust the filter etc...
i.e. the entangled photons are not exactly half the energy
but
one of the entangled photons have 60% of the energy of the pump photon and
the other entangled photon has 40% of the energy of the pump photon.
What does that mean for, say, spin or momentum entangled photons?
How would such photons behave? in experiments like
1. double slit interference...would we have modified/skewed interference pattern?
2. Bell's experiments...i.e. would we have a 60-40 correlation between spins etc?
3. Delayed choice quantum eraser etc.
etc
Principle of type-II parametric down conversion to
produce directed beams of polarization entangled photons
An incident pump photon can spontaneously decay into two photons which are entangled in momentum and energy. Each photon can be emitted along a cone in
such a way that two photons of a pair are found opposite to
each other on the respective cones. The two photons are orthogonally polarized. Along the directions where the two
cones overlap, one obtains polarization-entangled pairs. In the
figure, it is assumed that a filter already selects those photons
which have exactly half the energy of a pump photon.
Non-linear optics is complicated, there are as many possible processes as you can imagine, and all of their time reversals. All have an associated wave vector(energy) conserving process, and only a few of them have equal energies for output photons.
When the writer specifies the "type" of crystal, this is a polarization definition. It has to do with the crystal axis and how it projects the downconverted photons to ordinary (o) polarization or extraordinary (e) polarization. It's complicated, but wikipedia has a good intro.
http://en.wikipedia.org/wiki/Nonlinear_optics#Frequency_mixing_processes
but
etc
Very good San! As Al says, there is conservation and there are many pairs produced that are not 50-50.
Experimentally, this is often controlled by how the desired pairs are collected. Pump photons that are not down converted go straight through the crystal. These are normally not desirable for collection. Down converted pairs are produced off-angle! The angle of deflection is related to the amount of momentum they have. So certain deflection angles represent 50-50 splits.
Generally 60-40 splits will still be polarization entangled although there may be a function whereby their fidelity is less. Not really sure.
Here is a great reference that tells a lot about the process, from a top team:
http://www.ino.it/~azavatta/References/JMO48p1997.pdf
Related to Is there entanglement other than 50/50 energy? of the pump photon
1. What is entanglement?
Entanglement is a phenomenon in quantum physics where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other(s), regardless of the distance between them.
2. Is 50/50 energy the only type of entanglement?
No, 50/50 energy is just one specific type of entanglement. There are many different types of entanglement, each with its own unique characteristics and applications.
3. How is entanglement different from other quantum phenomena?
Entanglement is different from other quantum phenomena because it involves the connection and correlation of multiple particles, rather than just one. It also has potential applications in quantum computing and communication.
4. Can entanglement occur between particles with different energy levels?
Yes, entanglement can occur between particles with different energy levels. The energy level of a particle is just one aspect of its overall quantum state, and entanglement depends on the correlation of all aspects of the particles' states.
5. How is entanglement related to the pump photon?
The pump photon is often used in experiments to create entangled particles. This is because the pump photon can be split into two lower energy photons, which are then entangled with each other. So, the pump photon plays a crucial role in creating entanglement between particles.
  • Quantum Physics
