Is there still a collapse problem after decoherence?
In summary, Bob observes superposition of light paths when Alice does not open both of her slits. This difference is like that of the two cases where Alice does open both of her slits.
Heidi
418
40
Hi Pf,
I take the case of Alice and Bob in the EPR experiment. Here Bob does not measure spin projections but make a Young's double slit experiment. What Alice does on her side will not be known by Bob. She can decide to let her particles go freely to the left (in the environment of Bob).
Bob will see no interference. he cans suppose two things:
1) the which path information is known by Alice but he ignores the result so he is in a classical case of a probability problem , no more in quantum problem with ampkllitudes.
2) Bob knows what is decoherence , and how to use a reduced diagonal density matrix after decoherence.
in the two cases nothing can explain why the particle follow one path or the other. But is it still a collapse problem? we are now in the case where there is a lottery in Tokyo and that you read the results later in London. Would you talk about collapse problem.
How many photons participate in your young's double experiment ? Bob may not be able to judge there is interference or not by a single photon experiment. If many photon participates Bob observes that the setting is not Young slit but one slit.
Two slits and a sufficient number of particles (Bob receives them one by one) to see if there are interferences.
Thanks for clarification. I think Bob observing the pattern judges that only one of two slits is open each time. He observes a mixed state.
How could he think like that? he has a device with two open slits.
Oh I thought she and he shares a single double-slit and only she can operate the slits to open close.
You say each he and she has own double-slit. Double double-slit is too much complicated to me. Her slit door operation should effect his observation but not simple to analyze. For her incoming light is plane wave beam but for him light source is single source of two cases. I think photon interference takes place by his second slit even after her operation though pattern differs from the case of her no operation.
[EDIT]
Say ##A_1,A_2## are Alice's slits and ##B_1,B_2## are Bob's
If Alice does not do anything Bob observes superposition of light path
[tex]A_1B_1+A_1B_2+A_2B_1+A_2B_2[/tex]
where ##A_1B_2## means probability amplitude of path along ##A_1## and ##B_2## or so.
If Alice open only ##A_1## Bob observes superposition
[tex]A_1B_1+A_1B_2[/tex]
Difference is like that.
Just a reminder: neither Alice nor Bob will see interference while they are entangled. This is a peculiarly of entanglement. So the double slits on either side tell nothing useful.
Likes Heidi
Heureux de vous lire DrChinois,
My question was about the classicality of the situation of Bob. he has to add probabilities. is it worth to talk about collapse then. No one talks about that in a lottery.
FAQ: Is there still a collapse problem after decoherence?
What is the collapse problem after decoherence?
The collapse problem refers to the issue of how a quantum system transitions from a superposition of multiple states to a single definite state when it interacts with its environment, a process known as decoherence. This is a fundamental problem in quantum mechanics that has puzzled scientists for decades.
Does decoherence solve the collapse problem?
Decoherence is often seen as a solution to the collapse problem, as it explains how the quantum system appears to "collapse" into a definite state due to its interaction with the environment. However, it does not fully resolve the underlying philosophical implications of the collapse of the wave function.
Can decoherence be observed in experiments?
Yes, decoherence has been observed in many experiments, such as the double-slit experiment, where a quantum system is observed to behave like a classical particle when it interacts with its environment. This supports the idea that decoherence plays a role in the collapse of the wave function.
Are there any competing theories to explain the collapse problem?
Yes, there are other theories that attempt to explain the collapse of the wave function, such as the many-worlds interpretation and the objective collapse theories. These theories propose different mechanisms for the collapse and have not been fully accepted by the scientific community.
How does the collapse problem impact our understanding of the universe?
The collapse problem raises questions about the nature of reality and the role of consciousness in the universe. It also has implications for fields such as quantum computing and quantum cryptography, where the collapse of the wave function can affect the accuracy of measurements and predictions.
