I Is there such a thing as an active diamagnet?
  • I
  • Thread starter Thread starter cuallito
Active diamagnets, which would require a power source to block external magnetic fields, are not commonly recognized in scientific literature. The discussion highlights that traditional methods for magnetic shielding typically utilize materials like mu-metal, which do not require an active power source. The concept of an active diamagnet remains largely theoretical, as no practical examples have been identified. The need for such a device arises in situations where superconductors are impractical. Overall, the feasibility of active diamagnets is still uncertain within current technology.
cuallito
Does something like an active diamagnet exist for when you need to block external magnetic fields, but a superconductor wouldn't be practical?
What do you mean by "active" diamagnet?
If by ‘active’ you mean something that requires a power source (e.g. requires a current), then I’’ve never heard of one. For simple magnetic shielding, an alloy called ‘mu-metal’ is often used. E.g. see https://en.wikipedia.org/wiki/Mu-metal.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
