Is there work for object moving at a constant speed?
In summary: And I understand now that net work is the total amount of work done on an object, taking into account all the individual forces acting on it. In this scenario, the net work would be zero since the forces are balanced and the object's speed remains constant. In summary, the net work done on an object can be calculated by taking the difference between the final and initial kinetic energy, and it differs from work as it takes into account all the individual forces acting on the object.
miyayeah
27
An object of mass 100kg is acted on by a constant force as it moves through a displacement at a constant speed of 7.2m/s. What is the net work done on the object?
Wnet = ΔK
Fnet = 0
I know that the answer is zero because the equation, expanded, is: ½mvf2-½mvi2. Since final and initial velocity is the same, the net work will be zero... but I'm having difficulty trying to conceptualize the idea. So is kinetic work only present if the object is accelerating, either speeding up or slowing down? How does net work differ from work?
Imagine a car driving on a (horizintal) highway. To keep it at constant speed, you need to burn gas by pushing down the pedal. But the energy supplied by the gas and transformed into work by the engine does not increase the kinetic energy (which is approximately constant, when neglecting the mass reduction of the car due to the burned gas). The kinetic energy also is present, if the car is proceeding at constant speed, the difference of the kinetic energy at two different times indicates the variation of speed and/or mass. Net work is the difference of the work done on the system and the work done by the system and it and any net work done corresponds to a variation of the stored energy of the system. Since the energy of the car on the highway in our case is constant (constant speed, constant height, ...), the net work equals zero. That means all the work done by the engine does not remain in the car, but is expended again and exits the system. But what for?
It seems to suggest a nonzero constant net force, as a vector, and a nonzero time, but in that case I do not understand how the speed can be constant. So the question is either flawed or deceptive.
What's kinetic work? Do you mean the change in kinetic energy? If so, that's not work.
The same way a force differs from the net force on an object.
Wnet = ΔK
Fnet = 0
If a body has several forces acting on it, if its velocity is constant, each individual force does work on the body, but the sum of these amounts of work must be zero (since the sum of the forces is zero). So even though the individual forces do work on the body, there is no net work done by the combined forces on the body.
Wnet = ΔK
Fnet = 0
The only way the scenario make sense is that if the object is subject to something like friction, so a force is needed to maintain its constant speed. If the force is applied (for example) through a cable pulled by a motor that burns fuel (or by you tugging on the cable), the motor (or you) expends energy in keeping the object moving. So work is being done on the "system", which is object + its environment.
vela said:
What's kinetic work? Do you mean the change in kinetic energy? If so, that's not work.The same way a force differs from the net force on an object.
Yes, sorry, I meant kinetic energy.
Related to Is there work for object moving at a constant speed?
1. What is constant speed?
Constant speed refers to the movement of an object at a consistent rate, without any changes in its speed or direction. This means that the object is moving at the same speed throughout its entire journey.
2. How is constant speed different from average speed?
Constant speed and average speed are two different concepts. While constant speed refers to the consistent rate at which an object is moving, average speed takes into account the total distance traveled and the total time taken, and calculates the average rate of speed over that entire journey.
3. Can an object be moving at a constant speed and still be accelerating?
No, an object cannot be moving at a constant speed and accelerating at the same time. Acceleration is defined as a change in an object's velocity, which includes both changes in speed and direction. If an object is moving at a constant speed, its velocity remains unchanged and therefore it is not accelerating.
4. What factors affect an object's ability to move at a constant speed?
An object's ability to move at a constant speed can be affected by various factors such as friction, air resistance, and the presence of external forces. These factors can either increase or decrease the object's speed, making it difficult to maintain a constant rate of movement.
5. How is constant speed related to Newton's First Law of Motion?
Constant speed is related to Newton's First Law of Motion, also known as the law of inertia. This law states that an object will remain at rest or in a state of constant motion unless acted upon by an external force. Therefore, if an object is moving at a constant speed, it will continue to do so unless a force is applied to change its speed or direction.
