I Is thermal noise a statistical uncertainty?
  • I
  • Thread starter Thread starter kelly0303
    Set theory
The discussion centers on whether thermal noise constitutes statistical uncertainty in a measurement system defined by the equation y=ax. The parameter x, representing the position of a particle in a thermal bath, has an associated uncertainty due to its probabilistic nature described by a Boltzmann distribution. The user suggests that measuring multiple y values can help refine the estimate of the true y value, assuming Gaussian noise rather than thermal noise. Clarification is sought regarding the distinction between Gaussian noise and thermal noise, with the latter also being characterized by a Gaussian distribution. The conversation emphasizes the relationship between measurement repetitions and the convergence to an average value.
kelly0303
Hello! I have a system described by ##y=ax##, where a is the parameter I want to extract and y is the stuff I measure (we can assume that I can measure one instance of y without any uncertainty). x is a parameter I can control experimentally but it has an uncertainty associated to it. In a simplified form (but enough for my question), x is the position of a particle (classically) in contact with a thermal bath at temperature T. For example we can assume that the energy of the particle is ##kx^2/2##, where k is a known constant and for each measurement of y, x has a different x, where the probability of an x is given by the probability of having that given energy based on a Boltzman distribution at temperature T. I am not sure if this is a statistical uncertainty or not. I would say it is, because if I measure many y values, I can narrow down the true y value (if I assume I have Gaussian and not thermal noise, that would go down as ##1/\sqrt{N}##, where N is the number of measurements, right?), but I wanted to make sure this makes sense.
What do you mean by "Gaussian and not thermal noise"? The thermal probability distribution in your case is proportional to
$$e^{-\beta E}=e^{-\beta kx^2/2}$$
which is also Gaussian. Besides, by the "true" value, do you mean the average value?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
