Is this a characteristic function?
In summary, the answer to the first question is yes, as e^{\phi-1} is a continuous limit of the product of \phi_n(t)^n, where \phi_n(t) is a characteristic function. For the second question, the function \phi(t)=\frac{e^{-t^2}}{1+\sin^2(t)} is not a characteristic function for a discrete distribution, and its inverse Fourier transform is too difficult to obtain. The general definition of a characteristic function is the Fourier transform of the density function or the integral of e^{itx}dF(x), where F(x) is the distribution function.
malami
1. If [tex]\phi[/tex] is a characteristic function, than is [tex]e^{\phi-1}[/tex] also a characteristic function?
I know some general rules like that a product or weighted sum of characteristic functions are also characteristic functions, also a pointwise limit of characteristic functions is one if it's continuous at 0.
So I think the answet is yes, because [tex]e^{\phi-1}[/tex] is continuous at 0 and it's a limit of the product [tex]\phi_n(t)^n[/tex]
where
[tex]\phi_n(t)=1+\frac{\phi(t)-1}{n}[/tex],
and [tex]\phi_n[/tex] is obviously a characteristic function.
Is this correct?
2. Is [tex]\phi(t)=\frac{e^{-t^2}}{1+\sin^2(t)}[/tex] a characteristic function?
Here I can only prove, that it's not a characteristic function from a discrete distribution. I tried integrating it to get the inverse Fourier transform, but it's too difficult.
I know of several different definitions of "characteristic function". What is your definition?
In probability theory, the characteristic function is the Fourier transform of the density function. More generally it is ∫eitxdF(x), where F(x) is the distribution function.
The answer for 1. is yes. You can use the weighted sum, where the weights are > 0 and the sum = 1.
eφ-1 = 1/e{1 + φ + φ2/2 + ...φn/n! ...}.
Each φn is a characteristic function (note 1 is the ch. f. of unit dist. at 0) and 1/n! sums to e.
1. Yes, your answer is correct. The product of two characteristic functions is also a characteristic function, and since e^{\phi-1} is a continuous function at 0 and a limit of characteristic functions, it is also a characteristic function.
2. No, \phi(t)=\frac{e^{-t^2}}{1+\sin^2(t)} is not a characteristic function. A characteristic function must satisfy certain properties, such as being continuous and having a value of 1 at 0. Your attempt to find the inverse Fourier transform is a good approach, but as you mentioned, it may be too difficult. Another approach could be to check if \phi(t) can be written as the Fourier transform of a probability distribution, which would also indicate that it is a characteristic function. However, in this case, it does not seem to have a corresponding distribution. Therefore, \phi(t) does not satisfy the necessary conditions to be a characteristic function.
Related to Is this a characteristic function?
1. What is a characteristic function?
A characteristic function is a mathematical function that describes the probability distribution of a random variable. It is used to fully characterize the properties of a random variable, including its mean, variance, and higher moments.
2. How is a characteristic function different from a probability density function?
A probability density function describes the probability distribution of a random variable in terms of its probability mass or density. A characteristic function, on the other hand, is a function of the random variable's Fourier transform and provides a more complete description of the random variable's properties.
3. What are some common examples of characteristic functions?
Some common examples of characteristic functions include the Gaussian function, the exponential function, and the Poisson function. These are used to describe the probability distributions of commonly occurring random variables such as normal distributions, exponential distributions, and Poisson distributions.
4. How are characteristic functions used in statistical analysis?
Characteristic functions are used in statistical analysis to calculate moments of a random variable, which can then be used to determine its mean, variance, and other properties. They are also used in hypothesis testing and parameter estimation, as they provide a more comprehensive description of the random variable compared to probability density functions.
5. Can characteristic functions be used for any type of random variable?
Yes, characteristic functions can be used for any type of random variable, including discrete, continuous, and mixed random variables. They are a fundamental tool in probability theory and are applicable to a wide range of statistical analyses and models.
