Is this a good substitution that will work
In summary: The integrand is 1/\sqrt{x^2+ 6x+ 25} and dx= 4 sec(\theta) d\theta so the integral is [tex]\int \frac{4sec^2(\theta)}{\sqrt{16tan^2(\theta)+ 16}} d\theta= \int \frac{4sec^2(\theta)}{\sqrt{16(\frac{x+3}{4})^2+ 16}} d\theta.= \int \frac{4sec^2(\theta)}{\sqrt{(x+3)^2+ 16}} d\theta= \int \frac{4(\frac{x^2+ 6x+ 25}{
rock.freak667
6,223
31
Prove [tex]\int_0^{1} \frac{1}{\sqrt{x^2+6x+25}} = ln(\frac{1+\sqrt{2}}{2})[/tex]
= \int_0^{1} \frac{1}{\sqrt{(x+3)^2+16}}[/tex]
Let [tex]x+3=4tan\theta[/tex] so that [tex]dx=4sec^2\theta d\theta[/tex]
and so the problem becomes
[tex]\int \frac{4sec^2\theta}{\sqrt{16tan^2\theta+16}} d\theta[/tex]
giving [tex]\int sec\theta d\theta = ln|sec\theta + tan\theta|+ K[/tex]
Isolate theta in the substitution you made i.e. [tex]\theta=arctan\frac{x+3}{4}[/tex]. From there, you should be able to evaluate the definite integral, and come to the required solution.
You are correct so far, now just change the bounds accordingly to your substitutions. The first bound, x=1, so put that into your subsitution, tan theta = 1, ie theta = pi/4. Do the same for the other bound, and evaluate from your last line.
It is not absolutely necessary to let
(and then use trig identities). Imagine a right triangle with one angle [itex]\theta[/itex] since you know
[tex]tan(\theta)= \frac{x+3}{4}[/tex],
the triangle has "opposite side" of length x+3 and "near side" of 4.
By the Pythagorean theorem, the square of the hypotenuse is [itex](x+3)^2+ 16= x^2+ 6x+ 25[/itex].
Then [itex]sec(\theta)[/itex], hypotenuse over near side is [tex]\frac{x^2+ 6x+ 25}{4}[/tex]
and
[tex]tan(\theta)[/tex]
is, of course,
[tex]\frac{x+3}{4}[/itex].
FAQ: Is this a good substitution that will work
Is this substitution safe?
The safety of a substitution depends on the specific ingredients and their compatibility in the experiment or recipe. It is important to thoroughly research and understand the properties of each ingredient before making a substitution. If you are unsure, it is best to consult with a more experienced scientist or follow a tested and trusted substitution guide.
Will this substitution affect the outcome of my experiment or recipe?
Yes, most substitutions will have some impact on the final result. Some substitutions may have a minor effect, while others may significantly alter the outcome. It is important to carefully consider the purpose and function of the ingredient being substituted and how it may affect the overall experiment or recipe.
Can I make this substitution with a different unit of measurement?
It is generally not recommended to make substitutions based on different units of measurement, as this can greatly affect the accuracy and precision of your results. If possible, it is best to use the same unit of measurement as specified in the experiment or recipe.
Can I substitute multiple ingredients at once?
Substituting multiple ingredients at once can be risky and may result in unpredictable outcomes. It is best to make one substitution at a time and carefully observe the effects before making any additional changes.
Are there any potential allergic reactions or dietary restrictions associated with this substitution?
It is important to consider any potential allergic reactions or dietary restrictions when making substitutions. Make sure to thoroughly research the ingredients and any potential allergens or dietary concerns before making a substitution. It is also a good idea to inform others about any substitutions made in case of allergies or dietary restrictions.
