Is this a misconceptin? Moment of inertia
In summary: It's okay, no need to apologize. It's just easier for us to understand and help if you explain your question in a clear and organized way.
flyingpig
2,579
If an object is not spinning, does that mean the object's moment of inertia is 0? I've always thought that it is. But is it only not spinning when the object is at the moment arm?
Whether an object is spinning or not has nothing to do with its moment of inertia about some axis, which is a property of its mass distribution. (That's like asking, "If an object is not moving, is its mass 0?")
:confused:
Let's say I have a pulley spinning on its center (the axis is perpendicular to the pulley) and attached to the pulley is a block of mass.
Clearly, the pulley has a moment of inertia, but does the block too?
Sure it does. But who cares, since it's not rotating?
So it is zero right? That's my question. The object is not rotating, but does that mean the moment of inertia is 0? Even though the radii from the axis clearly is not?
It seems to me that you're straining to make an analogy between moment of inertia and linear momentum. A better analogy would be between moment of inertia and mass. Mass doesn't "disappear" when velocity is zero, and the moment of inertia doesn't "disappear" when the angular velocity is zero.
Both mass and moment of inertia are properties of things, the former depending upon the total quantity of matter while the latter depends upon that as well as its spatial distribution.
No. The fact that it's not rotating means that its rotational kinetic energy is zero, not that its moment of inertia is zero.
You have a misconception about what "moment of inertia" is.
but we can fix that !
The basic analogy is to mass.
Mass is a characteristic of an object that describes its resistance to movement in space, i.e move up/down, sideways and forwards/backwards.
Thus, "moment of inertia" is a characteristic of an object that describes its resistance to movement around a certain axis.
Does an object which is standing still have no mass? obviously it has. because when you star to move it - it resists you according to it's mass (this is by definition of classical mechanics).
Does an object which is not spinning have no "moment of inertia"? obviously it has. because when you star spinning it around some axis - it resists your spin according to it's "moment of inertia" at that axis.
This is the "intuition" behind it.
For more mathematical depth:
http://en.wikipedia.org/wiki/Moment_of_inertia
What if the block is descending down? Clearly it has a velocity downwards (or same as the "tangenital velocity" in this case).
Treat the block as mr^2
So wouldn't the linear kinetic energy now be mv^2?
What do you mean by: "Treat the block as mr2"? In what way and by what laws of physics?
As in point mass,moment of inertia
Seems like a very convoluted way to approach the problem. What's 'r' measured with respect to? It would not be constant as the mass descends. What would be the angular velocity? The radial velocity?
No. When all is said and done, the kinetic energy would still be 1/2mv^2, like always.
Glad you cleared that up. :wink: It would really help if you would explain what you're thinking in more detail, even if you think it's obvious what you mean. We can't read your mind, and to us, these little fragments you post, whose meaning may be obvious to you, are often meaningless at worst and confusing at best.I'm still not sure what you are asking, but based on what Doc Al posted, I have a guess. Let me describe a less complicated situation which I think illustrates your basic question:
Let's consider the Earth orbiting the Sun. On the one hand, we can say it moves with speed v at a distance R from the Sun. The kinetic energy of the Earth due to its linear motion would then be given by KL = ½mv2. On the other hand, since the Earth is going around the Sun, we can also say the Earth is undergoing rotational motion. It has an angular speed of ω=v/R, and its moment of inertia would simply be I=mR2. The kinetic energy due to this rotational motion is then KR = ½Iω2 = ½(mR2)(v/R)2 = ½mv2. Therefore, the Earth's total kinetic energy should be K = KL+KR = ½mv2+½mv2 = mv2, but it's not. The kinetic energy is simply K = ½mv2. Is that what you're confused about?
Yes vela! That's a similar way of my question! Sorry for the messy question guys
FAQ: Is this a misconceptin? Moment of inertia
What is moment of inertia?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is determined by the mass and distribution of the object's mass around its axis of rotation.
How is moment of inertia different from mass?
Moment of inertia and mass are related but distinct concepts. While mass measures an object's resistance to linear motion, moment of inertia measures its resistance to rotational motion.
Is moment of inertia the same for all objects?
No, moment of inertia varies depending on the shape, size, and mass distribution of an object. Objects with more mass concentrated at the outer edges have a higher moment of inertia compared to objects with the same mass but more evenly distributed.
What units are used to measure moment of inertia?
Moment of inertia is typically measured in units of kilogram meters squared (kg·m^2) in the SI system. In the imperial system, it is measured in units of slug feet squared (slug·ft^2).
How is moment of inertia calculated?
The moment of inertia of a point mass is given by the formula I = mr^2, where m is the mass and r is the distance from the axis of rotation. For more complex objects, the moment of inertia can be calculated using integration or by using tables of known moments of inertia for common shapes.
