MHB Is this a typo in IP networks?
  • Thread starter Thread starter find_the_fun
    Networks
The discussion centers on a potential typo in an answer key regarding Class C IP addresses. It highlights that Class C addresses consist of a 21-bit network number and an 8-bit local address, leading to confusion over the calculation presented in the answer key, which uses 2^12 instead of the expected 2^21. Participants confirm that the correct formula for the number of Class C addresses should indeed be 2^{21}(2^8-2). The discrepancy raises concerns about the accuracy of the answer key, particularly since the calculated result is significantly smaller than those for Class A and B networks. Overall, the conversation emphasizes the importance of accuracy in educational materials related to IP addressing.
find_the_fun
I think the answer key contains a typo but I want to confirm.
In the internet each network interface of a computer is assigned one or more internet addresses. The nature of these internet addresses is dependent on the networks size. For the internet standard regarding reserved network number each address is a 32-bit string which falls into one of the following three classes...[got first 2 right] class C addresses are used for the smallest networks.These addresses consist of the three-bit string 110 followed by a 21 bit network number and then an eight-bit local address. Once again the local addresses of all 0's or all 1's are excluded. How many different addresses of each class are available on the internet, for this internet standard.
The answer key has [math]2^12(2^8-2)[/math] but where does 12 come from? Shouldn't it be 21 since that's how long the network number is? I'm surprised because the answer key solved it to the integer and it is 3 orders of magnitude smaller than the class A and B networks.
Mathematics news on Phys.org
Re: Is this a typo?
You're quite right. The number of C class addresses is [math]2^{21}(2^8-2)[/math].
Just a comment here: $\LaTeX$ only understands one symbol at a time to go into an exponent. If you want more than one symbol to appear in an exponent, then enclose that in curly braces thus: 2^{12}. Result: $2^{12}$. Otherwise, you get what you wrote: $2^12$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
