Is this a valid DIY quantum eraser?
In summary, there was a discussion about the legitimacy of an experiment related to quantum mechanics. After a Mentor discussion, it was concluded that the experiment demonstrated the interference of two orthogonally polarised beams, which is a classical phenomenon. It is not a quantum eraser as it uses intense beams rather than individual photons.
alikim
Hi,
I found this video and there is some argument about the experiment being legit, can anyone with enough understanding of quantum mechanics comment on that?
Thank you!
Thread closed temporarily for Moderation...
Thread re-opened after a Mentor discussion. :smile:
I think the experiment is a demonstration of the following fact:
Two orthogonally polarised beams can interfere if bought together in the same plane if they come from the same initial polarised beam.
In this case the initial beam is the laser and the beams are bought together by the third polarising filter.
Therefore it is a demonstration of polarisation and interference and is more of a classical experiment. It is not a quantum eraser. Also, eraser experiments use very low illumination which can be described as "one photon at a time", each photon being converted to two entangled photons. I don't know how they could be adapted to deal with intense beams of the type used in the video.
Related to Is this a valid DIY quantum eraser?
1. What is a quantum eraser?
A quantum eraser is a device used in quantum physics experiments to study the phenomenon of wave-particle duality. It is used to erase or alter the information about the path of a particle, thereby changing its behavior and demonstrating the effects of quantum mechanics.
2. Can a DIY quantum eraser be considered valid?
It depends on the specific design and construction of the DIY quantum eraser. If it follows the basic principles and functions as a quantum eraser, it can be considered valid. However, it may not be as precise or reliable as a professionally-made quantum eraser.
3. What materials are needed to make a DIY quantum eraser?
The materials needed for a DIY quantum eraser vary depending on the design, but generally include lasers, beam splitters, polarizers, and mirrors. It also requires knowledge in quantum physics and electronics to properly construct and operate.
4. How does a quantum eraser work?
A quantum eraser works by using a series of mirrors, beam splitters, and polarizers to manipulate the path of a particle. It essentially erases or alters the information about the particle's path, causing it to behave differently and demonstrate the principles of quantum mechanics.
5. What are the potential applications of a quantum eraser?
Quantum erasers have various potential applications, particularly in quantum computing and communication. They can also be used in experiments to further understand the properties of quantum mechanics and potentially lead to new technologies and advancements in the field.
