Is this a valid representation of a derivative?
  • Thread starter docnet
  • Tags
    Derivative
In summary, the discussion revolves around whether a specific depiction accurately represents the concept of a derivative in calculus. It examines the graphical and mathematical aspects of derivatives, highlighting the importance of limits, slopes of tangent lines, and the relationship between functions and their rates of change. The validity of the representation is assessed based on its adherence to these fundamental principles.
docnet
486
The standard definition of the derivative is ##f'(x) = \lim_{h\to 0} \frac{f(x+h)-f(x)}{h}##.
What would happen we replace the term ##f(x+h)## inside the limit with a function composition ##f(g(x))##, with ##\lim_{h\to 0} g(x) = x##? Then ##f(g(x))## converges to ##f(x)## as ##h\to 0##.
If ##f(g(x)) =f(x+h)##, then ## \lim_{h\to 0} \frac{f(g(x))-f(x)}{h}= \lim_{h\to 0} \frac{f(x+h)-f(x)}{h}=f'(x) ##.
What if we let ##g(x) = x+\sin(h)##?
Then ## \lim_{h\to 0} \frac{f(g(x))-f(x)}{h}= \lim_{h\to 0} \frac{f(x+\sin(h))-f(x)}{h}##
This is not equivalent to that the standard definition of ##f'(x)##. It seems very similar because ##\lim_{h\to 0} x+\sin(h)=x## makes the numerator of the limit converges to ##0## just differently than with ##f(x+h)##. Can we also call this ##f'(x)##?
Thanks for commenting!
My immediate observation is that in this "alternative" definition, the derivative in ##x=0## is identically ##0##. This is a problem.
Likes docnet
Sorry! Do you mean that it wouldn't work because ##\lim_{h\to 0} x(1-\cos(h))=0##? Thank you for pointing out the example was a bad one. I was thinking more like ##g(x) = x + \sin(h)##. Would this work for a derivative? Thanks.
Just for the record, the example I referred to, was ##g(x)=x(1-\cos(h))##.
With the new example, I don't see how it differs from the standard definition. You could define there, ##h = \sin(p)##.
Likes docnet
I want to add some extra 'conclusions' related to the 'alternative definition of derivative'. I am aware that anything I cooked up this quickly has a high probability of being wrong, and I'm not attaching anything of value in these statements. If this is correct, then,
If ##\lim_{h\to 0} g(x)=x##, then ##\lim_{h\to 0}\frac{f(g(x))-f(x)}{h}=f'(x).##
If ##\lim_{h\to 0^+} g(x)=x## but ##\lim_{h\to 0^-} g(x)= \text{undefined},## then ##g(x)## can be used to exactly describe the right derivative of ##f## at ##x##.
If ##\lim_{h\to 0^-} g(x)=x## but ##\lim_{h\to 0^+} g(x)= \text{undefined},## then ##g(x)## can be used to exactly describe the left derivative of ##f## at ##x##.
docnet said:
Relevant Equations: .
##f(g(x))## is a constant. It is not a function of ##h##. If you want it to change as ##h \to 0##, you will have to specify how that happens. You might be interested in the chain rule: ##(f\circ g)' = (f' \circ g) \cdot g'##. So the result depends a lot on ##g'##.
Likes docnet
Okay. I'm having a difficult time understanding. Can you explain more? Thank you.
Also, Is it fair to say ##f(g(x))## is a function of ##x## with a parameter ##h##, which is also the parameter that the limit is with respect to?
I'm a bit confused by why we have to differentiate ##g##. Are you implying that ##g## needs to be continuous and differentiable with respect to ##h##, as well as converging to ##x## as ##h\to 0##?Thank you.
Why do you think this will be useful? g(x,h) is always going to have to look like x+h for small h.
Likes docnet
Still a problem.
For example, let ##g(x)=x##.
Then ##\lim_{h\to 0} g(x)=x##.
But ##\lim_{h\to 0}\frac{f(g(x))-f(x)}{h}=\lim_{h\to 0}\frac{f(x)-f(x)}{h}=0##.
Likes FactChecker and docnet
I'm not sure if it's useful on its own. The reason I asked is because there was a similar formulation in a stochastic analysis homework at school, and I just wanted to understand it correctly.
An informal comment. There's this integral called the Stieljes Integral. Yours is a sort of Stieljes derivative. Or maybe a sort of directional derivative.
Likes docnet
You are replacing ##x+h##, a function of ##x## and ##h##, with ##g(x)##, a function only of ##x##. So ##f(g(x))## has nothing to do with ##h## and never changes as ##h \to 0##.
UPDATE: If you really meant ##\lim_{h \to 0} \frac {f(g(x+h))-f(g(x))} {h}## then you have the chain rule:
##(f\circ g)' = (f'\circ g)\cdot g'##
Finding counter examples is trivial. If you take ##g(x) = x + 2h## you get twice the usual derivative. If you take ##g(x) = x + h^2## you get zero.
Likes FactChecker
FAQ: Is this a valid representation of a derivative?
What is a derivative in calculus?
A derivative represents the rate at which a function is changing at any given point. It is a fundamental concept in calculus that measures how a function's output value changes as its input value changes.
How do I determine if a representation of a derivative is valid?
To determine if a representation of a derivative is valid, ensure that the function is differentiable at the point in question. This means the function must be continuous and smooth (no sharp corners or cusps) at that point. Additionally, the representation should correctly follow the differentiation rules and formulas.
Can a derivative be represented graphically?
Yes, a derivative can be represented graphically. The derivative of a function at a point is the slope of the tangent line to the function's graph at that point. If the graph of the function is given, you can draw the tangent line at the point of interest and measure its slope to represent the derivative.
Is the notation dy/dx a valid representation of a derivative?
Yes, dy/dx is a valid and commonly used notation for representing the derivative of a function y with respect to x. It indicates the rate of change of y with respect to x and is read as "dy by dx."
Can a derivative be represented using limits?
Yes, a derivative can be represented using limits. The derivative of a function f(x) at a point x is defined as the limit of the difference quotient as the interval approaches zero: f'(x) = lim(h→0) [f(x+h) - f(x)] / h. This limit-based definition is fundamental to understanding and calculating derivatives.
