Is this a way to stimulate an alpha emitter?
  • I
  • Thread starter Spinnor
  • Tags
    Alpha
In summary: I am interested in how quantum mechanics or quantum field theory is properly applied to this thought experiment.I don't think quantum mechanics is critical for this experiment.
Spinnor
431
Say we can create a high energy particle beam of radioactive alpha emitting nuclei (all the same kind). Let the particle beam have an energy such that if an alpha particle is emitted in the direction opposite to the beam direction the alpha particle will appear in the lab frame to be almost at rest. Now have this high energy particle beam be directed at a meter cubed volume of liquid helium-4 which is so cold that nearly all of the helium is in the ground state. Does the liquid helium-4 in this situation stimulate the alpha emitting nuclei to emit an alpha particle as they pass through the liquid helium even if only a small amount? Reading Feynman's lectures on bose particles (https://www.feynmanlectures.caltech.edu/III_04.html) I might naively think there would be a factor of N enhancement of alpha emission (in the direction opposite the beam direction) while the nuclei passed through the liquid helium where N is the number of helium-4 atoms in the Bose-Einstein condensate, which for a meter cubed volume of liquid helium-4 is a large number, but I'm not sure that is correct for this situation. I know Quantum Mechanics always gets it right as long as you analyse the problem properly.
Thanks for any help.
I don't think there will be any effect. Among other problems, alpha particles are helium nuclei while your superfluid helium consists of atoms.
Even if there is an effect it would be completely negligible.
  • The phase space of alpha decay is really large compared to the phase space of the liquid helium.
  • Making a beam with just the right energy needs applied magic.
  • The first scattering process - still within the container walls - will ruin your magic beam.
  • Further scattering process in the helium will ruin the liquid helium
I get the first bullet point. In a proper calculation though would the number of ground state helium-4 atoms in the meter cubed target volume be used, if so that is quite an enhancement factor?
Is there a quantum limit on how precise particles can be accelerated? I practice can we get close to that limit?
Thanks.
No.
In particular, there is nothing special about a cubic meter.
Momentum can be very sharp if the position is spread out, but accelerators are nowhere near such a limit. Beams are "hot".
Related to Is this a way to stimulate an alpha emitter?
1. What is an alpha emitter?
An alpha emitter is a type of radioactive material that emits alpha particles, which are made up of two protons and two neutrons. These particles have a relatively large mass and a low penetrating power, making them less harmful to living organisms compared to other types of radiation.
2. How does stimulating an alpha emitter work?
Stimulating an alpha emitter involves using external sources such as heat, electricity, or other types of radiation to induce the emission of alpha particles from the nucleus of the radioactive material. This process is known as alpha decay.
3. What are the potential applications of stimulating an alpha emitter?
Stimulating an alpha emitter can be used for various purposes, including medical treatments such as targeted radiation therapy for cancer, industrial applications such as detecting leaks in pipelines, and scientific research to study the properties of different elements.
4. Is stimulating an alpha emitter safe?
When done properly and in controlled environments, stimulating an alpha emitter is generally considered safe. However, as with any type of radiation, it is important to follow safety protocols and minimize exposure to protect both humans and the environment.
5. How is stimulating an alpha emitter different from other types of radiation?
Stimulating an alpha emitter is different from other types of radiation in terms of the properties of the emitted particles. Alpha particles have a relatively low penetrating power, meaning they can be stopped by a sheet of paper or even the outer layer of skin. Other types of radiation, such as beta and gamma particles, have higher penetrating power and can be more harmful to living organisms.
