Is this an acceptable way to describe gravity
  • Thread starter 49ers2013Champ
  • Tags
    Gravity
In summary, the Theory of Everything is a theory that attempts to unite all the forces of the universe into one theory.
49ers2013Champ
31
Instead of saying that matter and energy curve spacetime, could one say: space and time curve around the presence of matter and energy?
I see literally no difference in those two statements.
Ha! That's good. Because when I read the second way of describing gravity, it makes things much clearer.
No, I think the second part needs to be " ... spacetime curves around ... "
I don't think "space and time" is the same as "spacetime" since the former implies that they are separate things and that is NOT a good way of looking at things in GR.
Newton:
Do you agree with Phinds?
Honestly, I'm not a fan of putting things in words. The wording of physical principles can be quite subjective and ambiguous. As far as general relativity is concerned, ##G_{ab} = 8\pi T_{ab}## is the fundamental relationship between the matter fields and the space-time metric. You can decorate that statement however you like if it makes things clearer but the basic principle is as stated above. It is certainly true that space-time is a single entity but the semantic details can, as I said, be quite subjective and ambiguous. This is why things are presented mathematically.
Newton, I have another question, and I'll just ask it here instead of start another thread. I'm watching a DVD and it is discussing, among other things, the "Theory of Everything" and the way in which we'll arrive at it. Below is the graphic presented in the DVD.
Electricity...Magnetism (separation between these two) Gravity
Electromagnetism...Weak force
Electroweak force...color force
Grand Unified Force
Theory of Everything (arrows connecting gravity with Grand Unified Force)
Where are the strong and weak nuclear forces?
Just FYI, it is strongly discouraged on this forum to start a new question in the same thread. Start a new thread for a new question.
Also, Google is your friend. Strong and weak forces are very well-known terms.
Okay, Phinds. I'll ask it on another thread. I was just trying not to take up too much room.
Also, this is probably not the best forum to post questions about the strong and weak forces; either the quantum physics forum or the high energy particle physics forum would probably be better, if you have questions after you've Googled.
When you repost your question send me a PM and I can assist you on the TOE and GUT
FAQ: Is this an acceptable way to describe gravity
What is gravity?
Gravity is a natural phenomenon that causes objects with mass to attract each other. It is one of the four fundamental forces of nature and is responsible for keeping planets in orbit around the sun and objects on Earth from floating away into space.
How is gravity described in science?
In science, gravity is described as a force that results from the curvature of space and time caused by the presence of mass. This was first described by Sir Isaac Newton in his law of universal gravitation, and later expanded upon by Albert Einstein's theory of general relativity.
Is gravity constant?
Yes, gravity is a constant force. However, its strength varies depending on the mass and distance between objects. This means that while the force of gravity on Earth is relatively constant, it may be different on other planets or in different locations within the universe.
Can gravity be explained by other theories?
While gravity has been explained by various theories, the most widely accepted and proven theory is Einstein's theory of general relativity. However, there are ongoing efforts to reconcile it with other theories, such as quantum mechanics, to create a more comprehensive understanding of gravity.
How do we measure gravity?
Gravity is typically measured using a device called a gravimeter, which measures the acceleration of a falling object due to gravity. Other methods include using pendulums, satellite observations, and the measurement of the gravitational constant, which is a fundamental constant of nature.
