Is this an effective way to learn physics/maths/chemistry?
  • Thread starter annoyinggirl
In summary, this student finds that he does better when he works problems with help and that memorizing the steps is not a good way to learn. He recommends that students find a textbook with problems that relate to their course material and solving as many as they can. If they get stuck, they should use the textbook, but be aware that getting stuck is a part of the learning process.
annoyinggirl
218
The classical physics textbook my professor has chosen has problems that don't match the text at all. I've discovered that the only way to learn now is to learn by reading the examples, then covering the steps up with a piece of paper to try to do it myself. Then check the answer. If it's wrong, i could see where i messed up and i could do it write. Then cover the solutions again, and do it again until i get the right answer.
Is this an effective way to learn for math-based courses, if this is ALL i do? In other words, does the brain learn well like this? Or does it need to practice with other practice problems where it forces to solve new problems whose solutions you have never seen before?
Different methods work well for different people, but it is my experience that you need to practice a wide variety of problems.
Memorising the steps needed to solve a problem allows you to solve that problem and others like it with ease, but minor changes can throw you off balance and leave you unprepared.
So, it is my advice (and I say this only as a student) that you are probably better off finding a classical physics textbook that has a lot of problems that relate to your class material and solving as many as you can.
Study closely each step and find what has done and why it has to be done to get the final answer. Sometimes you wseamlessly to go in the reverse direction from the final answer. Abyway you have to understand the answer properly.
Then try to construct the full answer (more logically less memorizing)all by yourself without looking at the solution.
Try this until you completely understand all the steps. If you don't understand a step refer to a textbook or ask it here.
If you understand the problem move on to more problems until they become quite easy for you. Apply logic + memory on and on.
Read online materials which will motivate you through the studies. Make studies your lyfestyle. And good luck !
If you are going into law or psychology, I would think reading textbooks would dominate your college career.
In science and engineering (physics, math, chemsitry), I find that 95% of what you do is working problems...with very little reading. Working lots of problems with help greatly with exams and so forth. Also, working the problems with make you a very good problem solver in the real work world.
So to answer your question, yes working problems the way you describe is the way to go...you are on the right track!
You might try jumping straight to the 2nd approach, at least some of the time (covering it up and solving it for yourself before reading the textbook solution). Use the textbook when you get stuck. But be aware that dealing with being stuck is one of the crucial parts of your education, so it's actually good to get stuck sometimes.
Also, I think it's good to think about the concepts and not just solve problems, although you can think about the concepts simultaneously with doing the problems (or whenever). My method of learning is to be like the kid who is just asking, "Why, why, why, why?", until everyone else is sick of me.
Why is this true? That's my big question.
One caveat, though. People like Feynman get away with this attitude, but if you're not Feynman, sometimes, it can be a bit ambitious if you take it too far. I was good enough to get a PhD in math, but I think I took it a little too far, at least as far as success within the system is concerned because that's as far as I got. I'm a bit of a failure by mathematician's standards, partly because of getting too discouraged, partly because I'm not good at teaching, but partly because I took it a little too far with the whole asking why business (which was not necessarily a mistake in a perfect world, I think, but lead to me being too unfocused to do well within the system).
Oh i think i wasn't clear. Sorry. I didn't mean to just merely memorize. I'll try to understand each step while reading the examples for the first time, before covering up the solutions to do it myself. I will use logic instead of just memorization to do it. Would this method be adequate if it's ALL i do?
It's not adequate. You must practice solving other questions whose solutions you have never seen before.
I don't think so , but let me tell you a fact , all people on this sphere are unique , hence you're the only one can decide what is most effective way to learn something..
thank you. Just the response i was looking for :)
FAQ: Is this an effective way to learn physics/maths/chemistry?
1. Is hands-on learning an effective way to learn physics/maths/chemistry?
Yes, hands-on learning has been proven to be an effective way to learn physics, maths, and chemistry. It allows students to actively engage with the subject matter, making it more memorable and easier to understand.
2. How does using technology enhance the learning of physics/maths/chemistry?
Using technology can enhance the learning of physics, maths, and chemistry by providing visual aids, simulations, and interactive activities that make the subject more engaging and easier to comprehend.
3. Can group work improve the understanding of physics/maths/chemistry?
Yes, group work can improve the understanding of physics, maths, and chemistry. It allows students to collaborate and learn from each other, which can lead to a deeper understanding of the subject matter.
4. Is repetition an effective study technique for physics/maths/chemistry?
Yes, repetition can be an effective study technique for physics, maths, and chemistry. Repeating and practicing problems can help reinforce concepts and improve retention of information.
5. Are real-world applications important for learning physics/maths/chemistry?
Yes, understanding the real-world applications of physics, maths, and chemistry is crucial for a deeper understanding of the subject matter. It allows students to see the practical uses of what they are learning and how it relates to their everyday lives.
