I Is this conditional expectation identity true?
The discussion revolves around the validity of the conditional expectation identity E(f(X,Y) | Y=y) = E(f(X,y) | Y=y). The author expresses concern about this identity, referencing Breiman's work which suggests that E(f(X,y) | Y=y) may not be well defined. Breiman's Proposition 4.36 indicates that while E(f(X,Y) | Y=y) can be expressed through a regular conditional distribution, the substitution with E(f(X,y) | Y=y) is problematic. The author is seeking clarification on how to approach proving the identity given these concerns. The thread highlights the complexities of defining conditional expectations in probabilistic contexts.
psie
TL;DR Summary
I am working an exercise to show a conditional expectation identity, but I'm not sure if it is true at all.
I'm working through an exercise to prove various identities of the conditional expectation. One of the identities I need to show is the following $$E(f(X,Y)\mid Y=y)=E(f(X,y)\mid Y=y).$$ But I am a little concerned about this identity from things I've read elsewhere. I am paraphrasing from Breiman's book Probability:
Proposition 4.36: Let ##X## and ##Y## be random variables. Let ##f(X,Y)## be a real valued, random variable such that the expectation of the absolute value of ##f(X,Y)## is finite. If ##Q(\cdot\mid Y=y)## is a regular conditional distribution for ##X## given ##Y=y##, then, $$E(f(X,Y)\mid Y=y)=\int f(x,y) \, dQ(\cdot \mid Y=y)\quad \text{a.s. with respect to the law of }Y.\tag{4.37}$$
Again, paraphrasing Breiman in section 4.3, page 80:
It is tempting to replace the right-hand side of (4.37) by ##E(f(X,y)\mid Y=y)##. But this object cannot be defined through the standard definition of conditional expectation (4.18) [defined below].
Definition 4.18: ##E(X\mid Y=y)## is any random variable on ##\mathbb R##, where ##Q(B)=P(Y \in B)##, satisfying $$ \int_B E(X\mid Y=y) dQ = \int_{Y \in B} X dP,$$ for all Borel sets ##B##.
Thus, does ##E(f(X,Y)\mid Y=y)= E(f(X,y)\mid Y=y)## make sense? Breiman seems to suggest that ##E(f(X,y)\mid Y=y)## is not well defined, so I'm not sure how to proceed.
I think this pdf clarified things a bit.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
