Is this constraint nonholonomic or not?
In summary, the conversation discusses whether an equation is nonholonomic or not. The Nonholonomic constraint includes a term of velocity and is non-integrable, but the formula in question does not depend on a path. The correct answer is that it depends on the function used, with some functions resulting in a holonomic constraint and others resulting in a nonholonomic constraint.
qwerfdsazxcv
I really want to know whether this equation is nonholonomic or not.
(As far as I know, Nonholonomic constraint has a term of velocity and do non-integrable. But this formula does not dependent on a path, because it is a total differential form.)
It is nonholonomic, for the reason you gave. Note that the second part of the constraint ##df=\frac{\partial f}{\partial q}dq + \frac{\partial f}{\partial q'}dq'+\frac{\partial f}{\partial t}dt=0## is redundant, as it follows from the first constraint.
Sorry for digging up old story but the correct answer on OP's question is as follows: it depends on the function ##f##. For example, if ##f=\dot x## then the constraint is holonomic; if ##f=\dot x+y\dot z## the the constraint is nonholonomic.
Related to Is this constraint nonholonomic or not?
1. What is the definition of a nonholonomic constraint?
A nonholonomic constraint is a mathematical condition that restricts the possible movements of a physical system to a lower-dimensional subspace, typically by constraining the velocities rather than the positions of the system's components.
2. How do I determine if a constraint is nonholonomic?
To determine if a constraint is nonholonomic, you must analyze the system's equations of motion. If the constraint can be expressed as a linear combination of the system's velocities, then it is nonholonomic. If not, it is holonomic.
3. Can a holonomic constraint become nonholonomic under certain conditions?
Yes, a holonomic constraint can become nonholonomic if certain conditions, such as the presence of external forces or the system's motion being constrained to a curved surface, are present.
4. What are some examples of nonholonomic constraints?
Some examples of nonholonomic constraints include rolling without slipping, double pendulum systems, and systems with friction or contact forces.
5. How do nonholonomic constraints affect the dynamics of a system?
Nonholonomic constraints can significantly impact the dynamics of a system by limiting the range of possible motions and introducing additional forces or torques. This can result in complex and non-intuitive behavior, making the analysis and control of such systems challenging.
  • Classical Physics
  • Classical Physics
  • Classical Physics
