MHB Is this correct?How much work is needed to compress a spring and lift a mass?
  • Thread starter Thread starter ineedhelpnow
    Work
To determine the work needed to compress a spring and lift a 20 kg mass 1 meter, the spring constant (k) must first be calculated using the equilibrium condition where the gravitational force equals the spring force. The work done to lift the mass involves both the work against the spring and the gravitational force. The calculations yield a total work of 294 J when considering the initial stretch of the spring and the additional lift. The original problem was deemed poorly worded, leading to confusion about the setup. Clarifying the context of the spring and mass is essential for accurate calculations.
ineedhelpnow
a mass of 20 kg can be stretched 1 m from the equilibrium position. how much work is needed to compress the spring and lift the mass 1m.
what i did:
$W=F*d=m*g*d$
$=(20 kg)(9.8 \frac{m}{s^2})(1m)=196 J$
is this correct?
a spring on a horizontal surface can be stretched 5m from its equilibrium position with a force of 50 N. how much work is done stretching it 3m from its equilibrium position?
what i did:
$W=50*5=250 J$
then i cross multiply
$5m \to 250 J$
$3m \to W_3$
$W_3=150 J$
correct?
what i did:
$W=F*d=m*g*d$
is this correct?
You need to reword this. Is this is vertical spring? How can you "stretch" a mass??
what i did:
$W=50*5=250 J$
$5m \to 250 J$
$3m \to W_3$
$W_3=150 J$
correct?
How about
[math]F = kx[/math]
[math]50 = k \cdot 5[/math]
Find k, then use [math]W = (1/2)kx^2[/math].
"Cross multiply??"
-Dan
by a mass it means an object with a mass of 20 kg
and for the second one that would mean $W=0.5*10*3^2=45$
so it can also be done this way?
$W= \int_{0}^{3} \ 10x dx$
you wrote:
"a mass of 20 kg can be stretched 1 m from the equilibrium position."
Please explain this sentence!
Is there a spring here? Vertical? Is the equilibrium the point where the mass is hanging stationary on the spring? We need details!
Yes.
-Dan
- - - Updated - - -
And also yes. (Nod)
-Dan
an object with a mass of 20kg can be stretched 1m from its equilibrium position (idk why we need to know that)? how much work does it take to compress the spring and to lift the mass UP 1m.
Is this the actual problem as it has been given to you? It stinks.
Let me try to re-word this to make some kind of sense. If it's not your given problem, just let us know.
A vertical spring with spring constant k has a 20 kg mass hanging from it such that the spring is stretched 1 m from its equilibrium length when the mass hangs freely. How much work is done to lift the mass 1 m above the equilibrium position?
We need k. We know that the object is hanging in place at the start, so we know that mg = F_s. This will give you k.
Now use [math]W = (1/2)kx^2 - (1/2)kx_0^2[/math] to find the work.
-Dan
that's how the problem was given. he actually brought the exact same question on the test. turns out the answer was 294 J :/
Hmmm...And that isn't the solution to the problem I wrote for you. I have no idea what the problem should look like.
Kick your instructor in the shins for me.
-Dan
It's been a long time since I did physics, but I'll give it a try.
So it's a badly written question, but I think I understand what it wants.
As Dan says, work is given by the following:
$$W = \frac{1}{2}kx^2$$, but we need to first determine $$k$$. That is simple, by equating the gravity force with the spring force.
$$(20)(0.8)=k(1)$$, k = 196. Plugging that back into the equation for work, we can see that the work is 98 J.
So the work needed to lift the mass back to its equilibrium position, and then 1 more meter up is:
W = F_s + F_g = 98 + mgd = 98 + 20(9.8)(1) = 294 J$$
