B Is this equation at all sensical?
The discussion revolves around the interpretation of a logical expression involving time and conditions, specifically ∀t(T(x,t)⟹(¬H(x,t)∨H(x,t+Δt))). Participants note the lack of context makes it challenging to derive meaning, with some suggesting it may relate to formal hardware description languages or theorem proving systems like ACL2. The expression implies relationships between variables over time, indicating transitions in truth values. There is also mention of its potential connection to logical operators and the Boyer-Moore Theorem Prover. Overall, the conversation highlights the complexities of interpreting abstract logical statements without sufficient context.
DaveC426913
TL;DR Summary
This looks like nonsense, or at least nothing meaningful.
(Yes, I'm guilty of passing along something incomplete and of utterly unknown provenance that someone saw somewhere and didn't understand. I feel dirty.)
Certainly, without specifying any of the variables, it's got to be useless. At least we can assume t and Δt refer to time/delta time - which is my rationale for posting here in the physics subforum)
Chat GPT made a broad guess but couldn't make heads or tails of it either. Don't judge me.
I would normally interpret those symbols as logical operators, so you might be better asking in the relevant maths forum. Difficult to tell without context, though.
For all t, T(x,t) implies ( NOT( H(x,t) ) OR H(x,t+Δt) )
T(x,t) is FALSE if H(x,t) was TRUE, and H(x,t+Δt) is FALSE.
T(x,t) is FALSE when H(x,t) transitions to FALSE in next sample.
A negative edge in H causes T to go low for one cycle.
Maybe it is from a formal HDL used to describe logic functions.
Likes SammyS, Ibix and PeroK
It looks a bit like input code for a Boyer-Moore Theorem Prover.
Example here: https://en.wikipedia.org/wiki/Nqthm#Theorem_formulation
"(IMPLIES (AND (NOT (ZEROP X)) (p (SUB1 X) Z))"
ACL2 or "A Computational Logic for Applicative Common Lisp", an applicative (side-effect free) variant of Common LISP. ACL2 is both a programming language which can model computer systems, and a tool to help proving properties of those models.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
