Is this equation from my lecture notes wrong? (RE: Transfer Functions)
In summary: You also need to take into account the amplitude and phase of the input signal. Thanks for your help!
CraigH
222
Mistake 1.
In the lecture slides from my university it says that:
"The response of a stable first-order transfer function to a unit sine wave input is:"
[itex]Y(s)=\frac{1}{s+a}*\frac{\omega}{s^2+\omega^2}[/itex]
Isn't this missing an [itex]a[/itex] in the numerator since the standard form of a first order transfer function is:
[itex]H(s) = \frac{1}{\tau s +1} = \frac{a}{s+a}[/itex]
where [itex]\tau=1/a[/itex]
and the laplace transform of the sine wave input is:
[itex]\frac{\omega}{s^2+\omega^2}[/itex]
Mistake 2.
The lecture slides also say that:
"The response of a stable second-order transfer function to a unit sine wave input is:"
[itex]Y(s)=\frac{1}{s^2+2\zeta\omega_n+\omega_n^2}*\frac{\omega}{s^2+\omega^2}[/itex]
Similarly, isn't this missing an [itex]\omega_n^2[/itex] in the numerator as the standard form of a second order transfer function is:
[itex]H(s) = \frac{\omega_n^2}{s^2+2 \zeta \omega_n s + \omega_n^2}[/itex]
For your first two cases, I wouldn't necessarily call them mistakes. Your quotes do not mention anything about standard form. The systems do not have unity DC-gain, but there's nothing inherently wrong with that.
I can't really guess as to what's going on in your last case without seeing some context.
Thanks for your answer. The last case was just the same equation split into partial fractions. I misread the addition for multiplication. I've deleted that part of the question now.
As for the first two transfer functions, I'm still really confused. I don't even know what questions to ask, I'm really struggling in this module. I'll just ask this though:
In the equation for "The response of a stable second-order transfer function to a unit sine wave input" is the natural undamped frequency [itex]\omega_n[/itex] still given by the [itex]\omega_n[/itex] in the equation, even though it is not in standard form? and likewise for the damping coefficient [itex]\zeta[/itex]?
Could this equation be re-written in standard form so that it has [itex]\omega_n^2[/itex] in the numerator so that the actual natural undamped frequency can be found?
If the numerator in the given transfer function represents the DC-gain, then what represents the DC gain in the standard form equation?
Thanks again!
Since your systems don't have any zeros, their dynamics is determined fully by their pole locations. The poles are the roots of the denominator of the transfer functions of your systems, and since you aren't altering them in any way, nothing changes in terms of the dynamics. All that changes is the (frequency-dependent) gain.
You don't have to rewrite it.
A system represented in the standard form always has unity DC-gain. You can easily determine this yourself using the final value theorem. Edit: The numerator alone doesn't represent its DC-gain.
where \zeta is the damping ratio and \omega_n is the natural frequency?
After reviewing the equations provided in your lecture notes, it appears that there are indeed mistakes in both the first and second-order transfer functions. In the first equation, the numerator should include an "a" term to match the standard form of a first-order transfer function. Similarly, in the second equation, the numerator should include an \omega_n^2 term to match the standard form of a second-order transfer function.
As a scientist, it's important to always double-check and verify equations and information presented in lecture notes to ensure accuracy. I would recommend bringing these mistakes to the attention of your professor or teaching assistant so that they can be corrected for future lectures. It's also a good practice to consult with other reliable sources, such as textbooks or reputable online resources, to confirm the correct equations and concepts.
Related to Is this equation from my lecture notes wrong? (RE: Transfer Functions)
1. Is it possible for an equation from my lecture notes to be incorrect?
Yes, it is possible for an equation from your lecture notes to be incorrect. Professors and textbook authors are human and can make mistakes. It is always a good idea to double check your lecture notes and consult with your professor or classmates if you are unsure about an equation.
2. How can I tell if an equation from my lecture notes is wrong?
If you are familiar with the topic and have a good understanding of the concepts, you can review the equation and see if it makes logical sense. You can also try plugging in different values to see if the equation produces the expected results. Additionally, you can consult with your professor or classmates to get their input.
3. What should I do if I think an equation from my lecture notes is wrong?
If you believe an equation from your lecture notes is incorrect, it is important to bring it to your professor's attention. They may be able to clarify the equation or confirm if there is an error. It is also helpful to provide evidence or examples to support your claim.
4. Can a wrong equation in my lecture notes affect my understanding of the topic?
Yes, a wrong equation in your lecture notes can affect your understanding of the topic. It can lead to confusion and incorrect interpretations of the concepts. This is why it is important to address any potential errors in your lecture notes as soon as possible.
5. How can I prevent relying on incorrect equations from my lecture notes?
To prevent relying on incorrect equations from your lecture notes, it is important to actively engage in the learning process. This includes attending lectures, participating in class discussions, and seeking clarification from your professor. It is also helpful to review your notes regularly and check them against reliable sources, such as textbooks or online resources.
  • Sticky
  • Science and Math Textbooks
  • Electrical Engineering
