Is this even solvable? Kinematics.
In summary, a ball is thrown vertically upward from ground level with an initial velocity V0 and rises to a height h before landing on the roof of a building with a height of 1/2h. Using kinematics equations, it is possible to find the values of V0 and h, but one must be careful in selecting the correct final velocity to use in the calculations, as the process of the object stopping is not free-fall motion. There is a numerical solution involving algebra and logical deduction.
tophat
A ball is thrown vertically upward from ground level with an initial velocity V0. The ball rises to a height, h, then lands on the roof of a building of height 1/2h. The entire motion requires 10s. Find the height, h, and the initial velocity, V0.
Kinematics.
I can't come up with anything, I'm using a final velocity of 0 m/s when running everything through and none of the values are making sense. I just need to know if it's actually solvable for real values. I'm in a hurry for work right now, but I will check back later.
I'm using: t2: 10s
t0= 0s
v1= 0 m/s (turning point)
a = -g
y1= h
y2= 1/2h
v2= 0 m/s (stop)
y0 = 0 m
I think using that as your final velocity is your main problem so far. Yes, the final velocity will be zero once the ball hits the building and stops, but you can't use that value because the process of the object stopping isn't free-fall motion. You have to use the value of the velocity just before it lands as the final velocity.
You've just jotted down some trivial equations so far; you haven't actually written the proper kinematic equations involving distance as a function of time.
Yes, there is a numerical solution for V0 and h, and there is a fair amount of algebra and logical deduction involved in obtaining it.
[tex]s(t)=v_0t-1/2gt^2, s(t)_{\text{max}}=h=f(v_0,g),[/tex] solve [tex]s(t)=\frac{h}{2}[/tex] for t, and then plugin t=10s, get the larger answer
(ground level)
Yes, this problem is solvable using kinematics equations. However, it is important to first clarify some assumptions and clarify the problem statement.
First, it is important to note that the problem does not specify the value of acceleration due to gravity, g. This value can vary depending on the location on Earth, so it is important to clarify which value should be used. For simplicity, let's assume g = 9.8 m/s^2.
Next, the problem states that the ball is thrown vertically upward, but it does not specify the angle at which it is thrown. This means that the initial velocity, V0, can have both a vertical and horizontal component. Let's assume that the ball is thrown with a vertical velocity component only, meaning that the horizontal component is 0 m/s.
Now, let's use the kinematics equations to solve for the unknowns, h and V0. We can use the following equations:
1. v = u + at
2. s = ut + 1/2at^2
3. v^2 = u^2 + 2as
Using the first equation, we can solve for the initial velocity, V0:
0 = V0 + (-9.8)(10)
V0 = 98 m/s
Next, we can use the second equation to solve for the height, h:
h = (98)(10) + 1/2(-9.8)(10)^2
h = 490 m
Therefore, the height, h, is 490 m and the initial velocity, V0, is 98 m/s.
In conclusion, this problem is solvable using kinematics equations, but it is important to clarify some assumptions and carefully apply the equations to find the correct values.
Related to Is this even solvable? Kinematics.
1. Is kinematics a solvable problem?
Kinematics is a branch of physics that studies the motion of objects without considering the forces that cause the motion. It deals with concepts such as displacement, velocity, and acceleration. While kinematics problems can be challenging, they are solvable using mathematical equations and principles of physics.
2. What are some common examples of kinematics problems?
Kinematics problems can include finding the position, velocity, or acceleration of an object at a specific time, calculating the time it takes for an object to reach a certain position, or determining the maximum height of a projectile. Other examples can include calculating the displacement of an object moving in a circular motion or analyzing the motion of objects on an inclined plane.
3. How do you solve kinematics problems?
To solve kinematics problems, you first need to identify the known and unknown variables in the problem. Then, you can use kinematic equations, which relate the variables of displacement, velocity, acceleration, and time, to calculate the unknown quantity. It is important to remember to use the correct units and apply the correct equation based on the type of motion (e.g. constant velocity or acceleration).
4. Are there any limitations to using kinematics to describe motion?
Kinematics only considers the motion of objects without taking into account the forces that cause the motion. This means that it cannot be used to accurately describe the motion of objects in situations where forces such as friction, air resistance, or gravity are significant. In these cases, other branches of physics, such as dynamics, must be used.
5. Can kinematics be applied to real-life situations?
Yes, kinematics principles can be applied to real-life situations such as analyzing the motion of vehicles, projectiles, or sports players. It is also used in fields such as engineering, robotics, and animation. By understanding kinematics, we can better understand and predict the motion of objects in our everyday lives.
