Is this mastering physics problem incorrect?
In summary, the conversation revolves around a problem involving interference of wave fronts emitted by two wave sources. The problem asks for a table with rows labeled P, Q, and R and columns labeled r1, r2, Δr, and C/D. The chart should have values for distances in multiples of λ and indicate whether the interference at that point is constructive or destructive. The final column should have C for constructive and D for destructive. After some discussion, it is determined that the values for the chart should be adjusted to account for the phase difference between the two sources.
Second_addition
[/B]
This is the Diagram-The figure shows the circular wave fronts emitted by two wave sources.
https://session.masteringphysics.com/problemAsset/1383558/3/21.EX26.jpg
part B is the one with trouble it asks "Make a table with rows labeled P, Q, and R and columns labeled r1, r2, Δr, and C/D. Fill in the table for points P, Q, and R, giving the distances as multiples of λ and indicating, with a C or a D, whether the interference at that point is constructive or destructive."
The given wave lengths to fill in the charts blank spaces are (1/2)λ,,,λ,,,(3/2)λ,,,2λ,,,(5/2)λ,,,(3)λ and then c for constructive and D for destructive for the last column.
abs(r1-r2)=Δr and for C/D and Δr that is a natural number is C all decimal numbers are Destructive //sorry don't know how to put that into more mathematical format//
3. The Attempt at a Solution [/B]
the chart should look like- Unfortunately their is no 3.5 fraction 7/2 is missing^
r1 r2 Δr D/C
P 2λ 3.5λ 1.5λ D
Q 3λ 2λ 1λ C
R 2.5λ 3.5λ 1λ C
Hello and welcome to PF!
To my eyes, the first wavefront surrounding source 1 is a full wavelength from source 1. But the first wavefront surrounding source 2 is not a full wavelength from source 2. Could it be that the two sources are not in phase?
Likes Second_addition
Yes your right so instead of 3.5 it would be 3 making it work thank you
Related to Is this mastering physics problem incorrect?
1. Is it possible for a mastering physics problem to be incorrect?
Yes, it is possible for a mastering physics problem to be incorrect. While the majority of problems are carefully tested and reviewed, mistakes can still occur in the creation or editing process.
2. How can I tell if a mastering physics problem is incorrect?
If you are unsure about the correctness of a problem, you can try checking the solution or asking for assistance from your instructor or peers. Additionally, if multiple attempts at solving the problem using different methods consistently give incorrect answers, it is likely that the problem is indeed incorrect.
3. What should I do if I think a mastering physics problem is incorrect?
If you believe a problem is incorrect, you can report it to your instructor or the technical support team for the mastering physics platform. They will investigate the issue and make necessary corrections if needed.
4. Can a mastering physics problem be partially correct?
Yes, it is possible for a problem to have a partially correct solution. Some problems may have multiple correct answers or may require a specific amount of significant figures to be considered fully correct.
5. How often are mastering physics problems reviewed and updated?
Mastering physics problems are consistently reviewed and updated to ensure accuracy and effectiveness. However, the frequency of updates may vary depending on the specific platform and publisher.
14K
