Is this possible without a calculator?
  • Thread starter Procrastinate
  • Tags
    Calculator
In summary, the conversation was about a problem involving optimization, specifically finding the maximum value of a function. The derivative of the function was derived to be R' = (1-lnx)/x^2, and the conversation discussed how to find the stationary points of the function, which occur when R' = 0. The conversation also mentioned using the null factor law to solve for x, and eventually found the correct answer of x=2.71. The conversation concluded by discussing the value of e (2.718281828...) as the base of the natural log and how it relates to the problem.
Procrastinate
158
I was doing this problem about optimization and I derived it to:
R' = (1-lnx)/x2
(This was the right derivative by the way as the maximum on the R function was the same answer as when R' = 0)Anyways as R' = 0 when stationary points occur:
0 = (1-lnx)/x2
I was wondering whether it was possible to do that without the help of a graph/graphics calculator because of the zero there. I managed to get the correct answer which was x=2.71 but I couldn't do it manually because of the zero even when I used the null factor law (1-lnx) = 0 or 1/x2 = 0.
2.718281828... is the base of the natural log.
Plug ln(x) = 2.718281828 into your calculator. The answer should be close to 1.
R' = (1-lnx)/x2
0 = (1-lnx)/x2
1-lnx=0 or lnx = 1
[tex]lnx = \log_e{x} = 1[/tex]
It is true when x = e = 2.71.
Thank you.
FAQ: Is this possible without a calculator?
Can complex calculations be done without a calculator?
Yes, complex calculations can be done without a calculator. However, it may require a significant amount of time, effort, and knowledge of mathematical concepts and formulas.
How accurate are calculations done without a calculator?
The accuracy of calculations done without a calculator depends on the individual's mathematical proficiency and attention to detail. While it may not be as precise as using a calculator, it can still provide accurate results.
Is it faster to use a calculator or do calculations by hand?
Generally, using a calculator is faster than doing calculations by hand. However, for individuals who are skilled and comfortable with mental math, doing calculations by hand can be just as quick.
Can all types of calculations be done without a calculator?
Most types of calculations can be done without a calculator, but some may be more difficult or time-consuming. It is important to have a strong understanding of mathematical concepts in order to do calculations without a calculator.
Is it necessary to learn how to do calculations without a calculator?
While it is not essential for everyday life, learning how to do calculations without a calculator can improve one's mental math skills and understanding of mathematical concepts. It can also be useful in situations where a calculator is not available.
