Is this proof of x² - y² = 270 being unsolvable valid?
  • MHB
  • Thread starter SweatingBear
  • Tags
    Proof Review
In summary, the conversation discusses a proof that there are no positive integer solutions to the equation x^2-y^2=270, using different methods such as examining different cases and using the fact that every square integer gives a remainder of either 0 or 1 when divided by 4. The conclusion is that the approach is valid and there are no alternative ways to solve the problem.
SweatingBear
119
Forum, I would love if you had a look at my proof below and gave me some feedback. Is the approach valid? Perhaps you have an alternative way to solve the problem? Anything helps!
Problem: Prove that there exist no positive integers \(\displaystyle x\) and \(\displaystyle y\) such that \(\displaystyle x^2 -y^2 = 270\).
Proof: Given that \(\displaystyle x, y \in \mathbb{N}\) where \(\displaystyle \mathbb{N} = \{ 1, 2, 3, \ldots \}\), we can infer that \(\displaystyle x\) and \(\displaystyle y\) respectively will be either even or odd. That means we have four different cases to examine.
Case #1: \(\displaystyle x\) even, \(\displaystyle y\) even. Let \(\displaystyle x = 2k \) and \(\displaystyle y = 2p\) (\(\displaystyle k,p\in\mathbb{N}\)); this yields
\(\displaystyle (2k)^2 - (2p)^2 = 270 \iff 4k^2 - 4p^2 = 270 \iff k^2 - p^2 = \frac {270}4 \, .\)
Note now that \(\displaystyle k^2 - p^2\) itself is in an integer but \(\displaystyle \frac {270}4\) is not, which clearly is nonsensical. \(\displaystyle k\) and \(\displaystyle p\) can therefore not be integers and consequently neither \(\displaystyle x\) and \(\displaystyle y\) (at least not even integers).
Case #2: \(\displaystyle x\) even, \(\displaystyle y\) odd. Let \(\displaystyle x = 2k \) and \(\displaystyle y = 2p-1\) (\(\displaystyle k,p\in\mathbb{N}\)); this yields
\(\displaystyle (2k)^2 - (2p-1)^2 = 270 \iff 4(k^2 - p^2 + p) - 1 = 270 \iff k^2 - p^2 + p = \frac {271}4 \, .\)
Similarly, \(\displaystyle k^2 - p^2 + p\) is integral but \(\displaystyle \frac {271}4\) is not; nonsensical of course and thus \(\displaystyle k\) and \(\displaystyle p\) cannot be integral (and consequently neither \(\displaystyle x\) and \(\displaystyle y\)).
Note: the case \(\displaystyle x\) odd and \(\displaystyle y\) even is analogous and will therefore be skipped.
Case #3: \(\displaystyle x\) odd, \(\displaystyle y\) odd. Let \(\displaystyle x = 2k - 1 \) and \(\displaystyle y = 2p-1\) (\(\displaystyle k,p\in\mathbb{N}\)); this yields
\(\displaystyle 4(k^2 - k - p^2 + p) = 270 \iff k^2 - k - p^2 + p = \frac {270}4 \, .\)
Again, this leads us to the conclusion that \(\displaystyle k\) and \(\displaystyle p\) cannot be integers and therefore neither \(\displaystyle x\) and \(\displaystyle y\). \(\displaystyle \text{Q.E.D.}\)
Any thoughts?
Mathematics news on Phys.org
That argument looks fine. The key to it is the fact that 270 is a multiple of 2 but not a multiple of 4. In fact, if $x^2-y^2 = (x+y)(x-y) = 270$ then one of the factors $x+y$, $x-y$ must be even and the other one odd. But $x+y = (x-y) + 2y$, so $x+y$ and $x-y$ have the same parity (either both even or both odd), so their product cannot be 270.
Any thoughts?
it looks good
a shorter proof shall be
x^2 - y^2 = (x-y)(x+y) = (x- y)(x- y+ 2y)
either both are odd or even so product is odd or multiple of 4 if even,
270 is multiple of 2 and not 4 and hence not possible
I am sorry. I had not seen Oplag's proof which is almost same.
Fantastic, thank you!
Hi everyone, :)
Another method to prove this is to use the fact that every square integer when divided by \(4\) gives a remainder of \(0\) or \(1\). That is, \(x^2\equiv n\mbox{(mod 4)}\) has solutions if and only if \(n\equiv 0,\,1\mbox{(mod 4)}\). Hence the remainder of \(x^2-y^2\) divided by \(4\) should be either \(0,\, 1\) or \(3\). But the remainder of \(270\) divided by \(4\) is \(2\). Hence we arrive at the conclusion that \(x^2-y^2=270\) has no integer solutions.
FAQ: Is this proof of x² - y² = 270 being unsolvable valid?
What is the purpose of a proof review?
A proof review is a process in which a scientist or mathematician examines the logic and evidence presented in a proof to ensure that it is valid and accurate. It is an important step in the scientific method to ensure that conclusions drawn from the proof are reliable and can be replicated by others.
How do you determine if a proof is correct?
A proof is considered correct if it follows a logical sequence of steps that lead to a valid conclusion. This means that each step must be supported by evidence and the conclusion must be supported by the previous steps. The proof should also be free of errors and clearly explain the reasoning behind each step.
Can a proof be proven wrong?
Yes, a proof can be proven wrong if it contains errors or if the logic and evidence presented are flawed. This is why it is important to thoroughly review and scrutinize a proof before accepting it as valid.
What is the importance of reviewing mathematical proofs?
Reviewing mathematical proofs is crucial in ensuring the accuracy and reliability of mathematical theories and concepts. It also allows for the identification and correction of errors, leading to a better understanding of the subject matter and potential advancements in the field.
How does proof review contribute to the scientific community?
Proof review contributes to the scientific community by promoting the dissemination of accurate and reliable information. It ensures that scientific discoveries and theories are based on sound evidence and logic, leading to more credible and trustworthy research in the future.
