Is this question possible without having learnt derivatives?
In summary, the conversation discussed finding a value of b that would result in the line intersecting the parabola at one point. It was suggested to isolate b in the equation and solve the quadratic equation for b, with the condition that the discriminant, b^2-4ac, equals 0.
ottoic
nvm got it
ottoic said:
-2x+b=3x^2+4x-1
0=3x^2+6x-1-b
Right, well when you reach here, you will get
[tex]3x^2+6x-(1+b)=0[/tex]
Now if we solve for x using the quadratic equation we'll get
[tex]x=\frac{-b \pm \sqrt{b^2-4ac}}{2a}[/tex]
If the line intersects the curve, you'll get two real values for x right? (in the form a±b)
Now for a tangent, the line intersects the curve once. So what condition should you put so that in the quadratic formula above, to get only value for x?
Suggestion (without working it all out): Look for a value of b such that the line intersects the parabola at one point.
From where you were:
0=3x^2+6x-1-b
Isolate b:
b = 3x^2+6x-1
Solve the quadratic equation for b. Does that work?
0=3x^2+6x-1-b
Isolate b:
b = 3x^2+6x-1
No, tha'ts not a quadratic equation "for b"- and it is already solved for b.
rockfreak667 suggested the right method: the equation [itex]ax^2+ bx+ c= 0[/itex] has a single solution if and only if the "discriminant", [itex]b^2- 4ac= 0[/math]. For this equation that would be 36+ 12(b+1)= 0. Solve that equation for b.
FAQ: Is this question possible without having learnt derivatives?
Can I understand the concept of derivatives without any prior knowledge or learning?
Yes, it is possible to have a basic understanding of derivatives without any prior knowledge or learning. However, a deeper understanding and application of derivatives requires learning and practice.
What are derivatives and why are they important?
Derivatives are mathematical tools used to measure the rate of change of a function with respect to its independent variable. They are important because they have various applications in fields such as physics, economics, and engineering.
Are there any real-life examples that illustrate the concept of derivatives?
Yes, there are many real-life examples that involve the use of derivatives. Some examples include calculating the speed of a moving object, determining the rate of change of stock prices, and finding the maximum profit for a business.
Is it necessary to have a strong mathematical background to understand derivatives?
Having a strong mathematical background can certainly make understanding derivatives easier, but it is not necessary. With proper explanations and practice, anyone can grasp the concept of derivatives.
Can I use derivatives in my everyday life?
While derivatives may not be directly applicable in everyday situations, having a basic understanding of them can help in making decisions and solving problems that involve rates of change. Additionally, derivatives are used in many industries, so having knowledge of them can be beneficial in various careers.
