Is this relationship directly proportional?
In summary, the author suggests that if you introduce a new variable in an equation, the equation won't be proportional anymore. However, if you take the derivative of the equation with the new variable, the equation will still be proportional.
bonbon22
92
If i had an equation y=3x^(2/3) would this relationship be directly proportional? as y/x^(2/3) = 3 so the gradient is constant
if thats the case would y =3x^2 be directly proportional also ??
no equations
I was confused by the question below
http://www.antonine-education.co.uk/Pages/Physics_4/Tests/Test%20on%20Fields.pdf
if you look at question at question 1 section B same reasoning is used to answer this question as you can see the graph is a straight line??
but plotting r against T ^2/3 or any two variables shouldn't give you a straight line?
If you introduce a new variable ##u=x^{\frac{2}{3}}## then ##y \sim u## is directly proportional, but this is not the case for ##y## and ##x##. The same is true for ##y \sim x^2##.
In the first case we have ##y^3=3x^2## so ##y^3## and ##x^2## are directly proportional.
if you check out the link , the graph does not seem to add a new variable yet the line is directly proportional.
also does directly proportional not mean the graph has to be straight line going throuugh the origin so y^3 = 3x^2 on a graphing calculator online is not a straight line?
A line can't be "directly proportional." When you have two quantities A and B that are proportional, it means that their ratio is constant. IOW, that ##\frac A B = k##, where k is a constant. Another way to say this is that A = Bk.
They are not saying that y is proportional to x. The equation you wrote is equivalent to ##y = 3^{1/3}x^{2/3}##. This means that y is proportional to ##x^{2/3} = \sqrt[3]{x^2}##. Here the constant of proportionality is ##\sqrt[3] 3##.
i see now cheers m8
one question m8 my equation was y = 3x^(2/3) is this the same as y= 3 * 3 sqaure root ( x^2) ??
how come you cube rooted the 3 also ??
##a^{\frac{1}{n}} = \sqrt[n]{a}##. Just take this to the power of ##n## to see it is the same. Thus ##3\sqrt[3]{x^2}=3\sqrt[3]{x}^2 =3x^{\frac{2}{3}}##.
mark 44 said that that equation 3x^(2/3) is the same as 3 root (3) * 3root ( x^2)
bit confused on that . thanks for the reply tho.
which means the constant here wasn't three - sorry, but your inline formulas are hard to decode - but ##3^{\frac{1}{3}}= \sqrt[3]{3}## which is a special case of what I wrote with ##a=n=3##. Hence ##y=\sqrt[3]{3}x^{\frac{2}{3}} \sim x^{\frac{2}{3}}## with proportionality factor ##3^{\frac{1}{3}}##.
Related to Is this relationship directly proportional?
1. What does it mean for a relationship to be directly proportional?
When two variables have a directly proportional relationship, it means that as one variable increases, the other variable also increases in a linear fashion. In other words, the ratio of the two variables remains constant.
2. How can I determine if a relationship is directly proportional?
A relationship can be determined to be directly proportional by plotting the data points on a graph and observing if the resulting trendline is a straight line passing through the origin. Alternatively, you can also calculate the ratio of the two variables and see if it remains constant for all data points.
3. What is the difference between a directly proportional and an inversely proportional relationship?
In a directly proportional relationship, as one variable increases, the other variable also increases. In an inversely proportional relationship, as one variable increases, the other variable decreases. This means that the ratio of the two variables is not constant in an inversely proportional relationship.
4. Can a relationship be both directly and inversely proportional?
No, a relationship can only be either directly proportional or inversely proportional. If the ratio of the two variables remains constant, it is directly proportional. If the ratio is not constant, it is inversely proportional.
5. How can I use the concept of direct proportionality in scientific experiments?
Direct proportionality can be used to predict the behavior of one variable based on the behavior of another variable in a controlled experiment. By understanding the relationship between the two variables, scientists can make accurate predictions and analyze the data collected from the experiment.
