Is this right? chem heat of combustion
In summary, the heat released by the reaction 2C + 2H2 = CH4 is 74.8kJ/mol. The heat of combustion for the burning of methane to form CO2 and H2O(g) can be determined using a table of standard enthalpy of formation values. The formation of CH4 is 74.8 kJ mol-1, while the formation of CO2 and H2O is -679.5 kJ mol-1. The formation of O is not counted as it does not change. This results in a total heat of formation of -754.3 kJ mol-1. However, further discussions and calculations reveal that the actual heat of formation is either -
joejo
150
Hi guys can you please check if this is right...thanks in advance
The heat released by the reaction 2C + 2H2 = CH4 is 74.8kJ/mol. Using this information and a table of standard enthalpy of formation values, determine the heat of combustion for the burning of methane to form CO2 and H2O(g).
C02 = -393.3 kJ/mol
H20 = -286.2 kJ/mol
2C + 2H2 = CH4 H1 = 74.8
C + O2 = CO2 H 2= -393.3
H2 +1/2 O2 = H2O H3 = -286..2
CH4 +3O2 = CO2 + 2H2O -H1 + H2 +2H3 = -1040.5 Kj/mol
can anyone help me out?
I may be incorrect but I got -754.3 kJ mol-1.
The formation of CH4 is 74.8 kJ mol-1.
The formation of CO2 and H2O is -679.5 kJ mol-1.
The formation of O is not counted due to it not changing.
This means that -74.8 kJ mol-1 + (-679.5 kJ mol-1) = -754.3 kJ mol-1.
The Bob (2004 ©)
Bob, you are wrong.
joejo, the H1 is negative -74.8 kJ/mol.
It should be -890.9 kJ.
Viet Dao,
VietDao29 said:
Bob, you are wrong.
Viet Dao,
It was. See?
The Bob (2004 ©)
Now I have had another look, I am going to agree with joejo. Why? because he is right. :biggrin: It is -1040.5 kJ mol-1.
Sorry
The Bob (2004 ©)
P.S.
joejo said:
-1040.5 Kj/mol
Just as a small hate of mine, can you please use the correct capitals?? Cheers. :biggrin:
. That means [itex]\Delta H_1 = -74.8 \mbox{ kJ/mol}[/itex].
So [itex]-\Delta H_1 +\Delta H_2 + 2 \Delta H_3 = -890.9 \mbox{ kJ}[/itex].
Am I missing something?
Viet Dao,
VietDao29 said:
Bob, you are wrong.
Although this did not affect what I thought or wrote, it normally gets people's defenses up and does not allow them to see errors. May I ask that you address the issue in a lighter-hearted way?
Nothing is missed. You are correct. I did the missing. However, both of us have done something wrong. joejo has (perhaps) lost some experience here because we both told him what had to be done. Although I was wrong, as was joejo, our methods were correct. What joejo really needed was some aimed help, not the answer. Of this we are both guilty and here is a point where we must learn to help (not tell the answer and method), not to argue and to have a bit of fun along the way.
I will take responsibilty if joejo is confused (not insult intended) due to my incorrect posts.
The Bob (2004 ©)
I just want my posts to be neat, short, but also contain enough information. So others can finish it in a glance. :biggrin: . Anyway, I'll take your advice. Thanks :smile:
Viet Dao,
Exothermic reactions should always be negative enthalpy.
Absolutely correct. So what is a reaction with a positive enthaply?
The Bob (2004 ©)
Endothermic!
NewScientist said:
Endothermic!
Another correct answer. :smile:
The Bob (2004 ©)
i think its still wrong...
shouldn't it be... -802.3kJ
How?
The Bob (2004 ©)
By definition the burning of methane to make CO2 and H2O is...
CH4 + 2 O2 --> CO2 + 2 H2O
The heat for this reaction is 2(-286.3) + (-393.3) -(-74.8) - 0 = -891.1 kJ.
right??
Your answer keeps on changing.
Which is it?
The Bob (2004 ©)
the bob...read above...i'll post it below just in case u never saw it.
right??
I did not miss it. I saw it. I was commenting on this:
and
These ARE two different answers, both posted by you.
The next problem is also by you. Your original post states:
joejo said:
H2 +1/2 O2 -> H2O is -286.2
yet you said in your last post:
You have got a difference for the formation of water. You said it was 286.2 and now you say it is 286.3. Please make up your mind.
If the value is 286.2 then me and VietDao29 are right. If it is 286.3 then you are right.
This is why I asked. Ok?
The Bob (2004 ©)
P.S. May I ask you not to be sarcastic in future. It makes me, if no one else, very on edge and will explain all of the boldness in this post. I was annoyed due to your sarcasm.
i wasn't being sarcastic...sorry for the misunderstanding...so was my second answer right...
In which case I apologise. I did misunderstand.
Your answer is correct if the Enthalpy change of Formation for water is -286.3 kJ mol-1. If it is -286.2 kJ mol-1 then VietDao29 and me are correct.
The Bob (2004 ©)
P.S. Apologise again.
thank you...just to verify...my second answer (-891.1 kJ.) right?? sorry I am getting confused and I can imagine you are too! thanks again
Yes, if the enthaply change of formation of water is -286.3 kJ mol-1.
The Bob (2004 ©)
thanks again! :)
Related to Is this right? chem heat of combustion
1. What is the heat of combustion?
The heat of combustion is the amount of heat released when a substance undergoes complete combustion, typically measured in joules per mole or joules per gram.
2. How is the heat of combustion calculated?
The heat of combustion is calculated by measuring the energy released during the combustion reaction and dividing it by the amount of substance consumed. It can also be calculated using standard enthalpy of formation values.
3. What factors affect the heat of combustion?
The heat of combustion can be affected by the type of fuel being burned, the amount of oxygen available for combustion, and the temperature and pressure of the surroundings.
4. Why is the heat of combustion important?
The heat of combustion is important because it provides information about the potential energy of a substance and can be used to compare the efficiency of different fuels.
5. How does the heat of combustion relate to global warming?
The combustion of fossil fuels releases carbon dioxide, a major contributor to global warming. By measuring the heat of combustion, we can estimate the amount of CO2 released and its impact on the environment.
  • Chemistry
13K
